Old 09-12-2003, 12:23 PM   #1
hys420
Member#: 18315
2008 STI ON ORDER
DGM - STILL WAITING!!
Default Does AccessECU Stage 2 help prevent backfiring?
I am running a TurboXS Stealthback (with hi-flow cat) + Prodrive axle-back, TurboXS uppipe, stock ECU and no boost controllers. Occasionally, after a hearty first gear run followed by a quick shift to 2nd, you will get a small backfire (followed closely by a P0420 ). I guess it is running richer than really necessary because the ECU doesn't fully adjust for the new exhaust piping properly?
Although I'm really enjoying the new power, I feel like my car has lost some of the factory smoothness, everything is a bit harsher now, and it'd be sweet if a good ECU tune could fix that up for me. I'm strongly thinking I want to get an AccessECU stage 2 (based on price/reputation, though not totally hot on the idea of shipping my ECU across country.. ), anyone have a similar setup and find that it helped smooth out the power flow and cut down on the backfiring?
thanks,
hys
hys420 is offline   Reply With Quote
Old 09-12-2003, 12:38 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
do you have an atmospheric BOV?
Old 09-12-2003, 12:53 PM   #3
hys420
Member#: 18315
2008 STI ON ORDER
Negative -- stock.
Old 09-12-2003, 02:48 PM   #4
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
I'm about to go plug mine in and go out to lunch...I'll get back to you!
mexicanpizza is offline   Reply With Quote
Old 09-12-2003, 04:37 PM   #5
hys420
Member#: 18315
2008 STI ON ORDER
Nice. Were you getting occasional backfiring before?
Old 09-12-2003, 07:55 PM   #6
SilverBoosted
Member#: 7764
11 Edge Sport
Kona Blue Metallic
PDE uppipe Stromung Downpipe and 3rd cat eliminator pipe with a prodrive muffler. Also running a COBB Stage 2 93 octane map reflash and it is very smooth...I can get a backfire ocassionally but no CELs......
SilverBoosted is offline   Reply With Quote
Old 09-12-2003, 11:24 PM   #7
AndyWRXWG
Member#: 23784
2005 M3
Tiag
your back fireing is more to do with the free flowing exhaust than with ecu tuning. I just had an axel back and was getting backfireing before I got accessecu. put your cats back on and I'd bet your back fire problem will get a lot better.
AndyWRXWG is offline   Reply With Quote
Old 09-13-2003, 12:45 AM   #8
hys420
Member#: 18315
2008 STI ON ORDER
Thumbs up
Thanks all. I had the Prodrive installed a month and a half before putting on the turboback, never had any backfire. Obviously removing the cats is the cause, guess I could put them back and less backfire.. also less acceleration.. hmm.. NOT! Anyhow I think I am learning how to drive it to prevent the backfire more now anyhow, I'll definitely be going with a Stage 2 flash too.
Old 09-13-2003, 07:28 AM   #9
Delicious Tuning
Member#: 1990
Do you have any cats? I have noticed from tuning many Subaru's that if the car has no CATS at all it will backfire. There is a force from the pistons firing and the turbo forcing air creates a pressurized system. When you let off the gas the pressurized system rapidly becomes a vacuum and therefore you get a pop. With a cat, it will break up that pressure system, as it is very hard for a pressurized system to flow through a CAT. Also there are of course unburnt fossil fuels that with the pressurized system a little oxygen, right after the exhuast and you get a little explosion out the tail pipe.
My $0.02
Bill @ I-Speed USA
Delicious Tuning is offline   Reply With Quote
AccessECU stage 2 vs. Vishnu EcuTek stage 1 jblaine Engine Management & Tuning 28 03-05-2004 01:33 PM
AccessECU Stage 2 Exhaust? IndyRacer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-03-2003 10:33 AM
AccessECU Stage 2 93 octane questions... Hank3 Engine Management & Tuning 14 05-17-2003 05:03 PM
COBB AccessECU stage 2 in seattle area sb253 North West Impreza Club Forum -- NWIC 6 05-11-2003 05:15 AM
Cobb Tunning AccessECU Stage 2 Lordhowe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-10-2003 12:21 PM
