Old 09-12-2003, 02:23 PM   #1
S-Rex
Member#: 19204
WR Blue
Default best oil filter wrench
What is the best oil filter wrench?
I've bought the different adjustable types from Pennzoil and they can't seem to tighten the oil filter. I also have the one that exactly clamps directly to the filter without adjusting. There is a slight oil leak.
I buy my oil filter from my local subaru dealer for an '02 wrx.
S-Rex is offline   Reply With Quote
Old 09-12-2003, 04:03 PM   #2
Karl
Member#: 13110
Hand tighten the filter. Filter wrench should be used to loosen only.
Karl is offline   Reply With Quote
Old 09-12-2003, 04:06 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Exactly. Tighting the filter with a wrench can cause the seal to leak. The rubber is supposed to be able to expand and contract as temperature changes.
Old 09-13-2003, 12:23 AM   #4
S-Rex
Member#: 19204
WR Blue
Thx for the replies.
Originally, I hand tightened the oil filter and it also leaked. That was when I started buying different types of wrenches.
Old 09-13-2003, 12:30 AM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
Either something is wrong with the mounting surface for the oil filter or the leak is from somewhere else. Others dont have this problem, and youve tried different filters so it has to be something else.
Old 09-17-2003, 10:52 PM   #6
gator
Member#: 18296
2004 STi
WR Blue
Make sure the gasket seating surface on the filter mounting boss is clean and lube the gasket on the filter with motor oil. Some filters do have to be tightened with a wrench, however it's generally specified on the filter or the box it comes in. Usually the ones that need to be that tight are on diesel trucks which have LARGE filters. Lilse makes a pretty good filter wrench.
gator is offline   Reply With Quote
Old 09-19-2003, 02:03 AM   #7
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
If you're having trouble getting a good hand grip on the filter, take a strip of medium sandpaper in your hand and wrap it around the filter -- that should stop any grip slipping problems.
Old 09-19-2003, 07:24 AM   #8
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
Can we get back to the question at hand? I'm looking for a filter wrench too, and am wondering if anyone has any experiences with one that will fit through a skidplate? Mine has a hole in it for removing the filter, but I can never get the filter to turn, so I always have to take the skidplate off to get more leverage.
TimStevens is offline   Reply With Quote
Old 09-19-2003, 09:01 AM   #9
MattWRX
Member#: 10144
07 - 496 of 800
(nuff said) ;)
I picked up a 4-in-1 filter "socket" from Wal-Mart. It's orange, has 2 parts, and works with a socket wrench (with entension bar). I found it with the other filter wrenches. I'm not sure how much clearance you need around the filter with the skidplate, but the socket is maybe an inch wider in diameter than the filter.
My only gripe about this one is it has to be PERFECTLY centered and angled, or else it slips like a peel.
I could take a pic of it this weekend if needed.
Matt
MattWRX is offline   Reply With Quote
Old 09-19-2003, 04:36 PM   #10
bluesubie
Member#: 767
04 FXT
Old 09-19-2003, 11:50 PM   #11
phantasm
Member#: 10008
2002 WR Pearl Blue
Impreza WRX
Go to Pep Boys or Walmart and get a filter socket that attaches to your socket wrench. Works beautifully.
phantasm is offline   Reply With Quote
what size oil filter wrench? njkayaker Service & Maintenance 24 08-13-2014 08:27 AM
new STi oil filter wrench...where can i get one??? db97 Service & Maintenance 3 07-09-2006 01:32 PM
OEM Oil Filter Wrench mike270 Service & Maintenance 20 07-09-2004 06:30 PM
What's the point of getting a oil filter Wrench? SubaruImpreza_power Newbies & FAQs 12 10-27-2003 04:12 PM
Oil Filter Wrench jonney_boy Service & Maintenance 11 01-31-2003 03:20 PM
