Old 09-12-2003, 04:08 PM   #1
Davenow
Member#: 23676
Default Replacement pistons (upgrades) that are direct replacements?
Whats out there and how much are we talking for pistons/rings.???
Old 09-12-2003, 04:29 PM   #2
STEALTH-WRX
Member#: 7822
Multi layer snot green
JE, Ross, Arias to name a few. Call them up and see what they have to offer. I am sure they have something. The price's will range from $500-$800 for forged aluminum.
STEALTH-WRX is offline   Reply With Quote
Old 09-12-2003, 06:03 PM   #3
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Dynoflo ( I think that is their vendor name) sells internals.
Need4Boost is offline   Reply With Quote
Old 09-12-2003, 10:42 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Easiest way to find out who makes internals is to do a Google search for say WRX internals or wrx pistons maybe even search under ej20 then internals or pistons. I have found numerous companys this way and many internal kits and five or six stroker kits as well. All kinds of valves and springs as well. so....
good luck to you, Micah
P.S. I'm looking to do an internal build up as well.
Old 09-30-2003, 09:13 PM   #5
dynoflo
Vendor
Member#: 37053
Default engine internals
Hello,
we do have engine internals available depending on what you need Eagle JE Arias...etc etc.. let me know and please don't be shy let me know you saw us on NASIOC. Je pistons are $396 std bore rings are $65
thanks,
Keith
p.s please make sure whoever you buy the pistons from that the price includes wrist pins ($$$$) and spirolox
dynoflo is offline   Reply With Quote
Old 10-01-2003, 02:28 PM   #6
EJ20K
Member#: 23058
STi v4 RA-M800ecu
STi7 shortblock & 1100kg.
Keith (dynoflo) I need to replace the pistons on a SPEC C engine, don't know if they are the same as the US WRX pistons (sure they are 92m) .....
What do you think about the WISECO pistons ?
EJ20K is offline   Reply With Quote
Old 10-01-2003, 02:42 PM   #7
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Ive heard that wiseco is good; as for JE overpriced....
I have a some friends that have used wiseco, and they seem to like them.
While you got it apart you might as well get a Cometic gasket.
Old 10-01-2003, 03:15 PM   #8
jinxproof99
Member#: 21497
i am using je pistons, stock bore and compression and they are a perfect fit. i mated them to pauter rods and a stock sleeved block. 500 hp to the wheel on c16 is 100% possible.
jinxproof99 is offline   Reply With Quote
Old 10-01-2003, 03:26 PM   #9
EJ20K
Member#: 23058
STi v4 RA-M800ecu
thing is that I "think" that the head volumen of the spec C heads is a little big bigger than that of the regular US WRX ..... and also does anyone have an idea of the height of the spec C headgaskets (0.6mm ?) ?
Old 10-01-2003, 04:08 PM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
call rallispec,axis or mike at spdusa... one of them would be able to tell you...
What Piston to use to replace piston slap brett-01 Normally Aspirated Powertrain 18 12-20-2011 06:19 PM
For all you STI owners that are getting trannies rebuilt/replaced under warranty... sonic03rex Transmission (AT/MT) & Driveline 3 02-07-2008 08:56 PM
Turbos that will directly replace a GT35R w/GT ballistics back side InfamousDX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-04-2006 12:21 PM
Are there any Mitsubishi Turbos that are direct bolt-on? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 03-25-2003 09:02 PM
any carbon fiber trim kits that are replacements for the stock dash pieces? dark knight Interior & Exterior Modification 5 02-08-2002 10:13 AM
