Old 11-11-2000, 08:12 PM   #1
Ethan
Member#: 246
Post Fuel Pressure Regulator?
Ok I keep seeing these words pop up on every search I do. I know what a Fuel Pressure Riser is and a Rising Rate one, but I don't know about this.
First off, what does it do and Does our car come with one? If so where is it? Thanks.
Ethan is offline
Old 11-13-2000, 01:11 PM   #2
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
First of, what does "bump" mean on the BB. And a FPR just keeps the PSi at a constant rate, like the Weapon R ones. You can use it to raise the pressure too.
STiShawn is offline
Old 11-13-2000, 01:29 PM   #3
Jay_UK
Member#: 296
Post
Bump is what someone types when they want the thread/post to become active and at the top of the list
A rising rate reg, increases the fuel pressure in relation to boost pressure.
You can get ratios for regs...some are adjustable..
J.
Jay_UK is offline
Old 11-13-2000, 01:53 PM   #4
Ethan
Member#: 246
Post
Thanks
Ethan is offline
Old 11-14-2000, 12:27 AM   #5
Ethan
Member#: 246
Post
BUMP, ok now that everyones at work, I'm sure someone can help me out!
Ethan is offline
HTML code is On
fuel pressure regulator with OBX high flow fuel rails question subypal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-09-2009 10:39 PM
FS: MA Perrin Fuel Rails & Aeromotive Fuel Pressure Regulator climberd Engine/Power/Exhaust 5 05-05-2009 12:07 AM
BDL fuel rails and fuel pressure regulator living4surf Engine/Power/Exhaust 2 09-29-2007 09:38 AM
Fuel Pressure Regulator and/or Fuel Rails? mav1c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-19-2003 03:23 PM
SVX Fuel Pressure Regulator Solved Idle Pressure Problem the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 23 11-05-2001 09:20 PM
