09-13-2003, 12:13 AM | #1 |
Member#: 2213
NESIC
Vehicle:1995 Impreza w/EJ257 Brilliant Red |
Is the WRX turbo a direct swap with a legacy turbo?
I have the JC Sports kit with a legacy turbo, and I think my turbo might be going will know for sure tomorrow after further inspection. Besides the obvious need to clock the turbo would a WRX turbo be a direct bolt on?
Joshua
09-13-2003, 12:26 AM | #2 |
Member#: 1676
NESIC
Vehicle:98RS w/ EJ257/Dom 2014 Tesla Model S P85 |
pretty sure it is. I sent you a PM.
09-13-2003, 12:32 AM | #3 |
Member#: 4562
NWIC
Vehicle:2014 Electric Datsun 2005 Adventure van |
I think the DP flange is different.
09-13-2003, 02:21 AM | #4 |
Member#: 756
Vehicle:2003 Legacy L wagon 2009 Kawasaki C14 |
The DP flange is the same, but the legacy turbo has a 90 degree elbow on it that won't work with the WRX turbo (unless it's an old one).
09-13-2003, 07:43 AM | #5 |
Member#: 20508
Vehicle:1998 Red Wagon New Turbo Project... |
The downpipe flange should be different. The legacy RBH5 turbos use a 4 bolt flange, whereas the WRX TD04 has a 5 bolt, non-compatible flange.
-Brad Weingartner |
09-13-2003, 09:46 AM | #6 |
Member#: 2213
NESIC
Down Pipe Flange
Okay I went outside and looked because I thought it was a 5 bolt flange I had and it deffinately is. I borrowed this from unique motor sports :
This is a picture of the IHI downpipe flange associated with the WRX and the same one that my car uses. This is the flange associated with the legacy turbo and not what I have. Does that now mean a WRX turbo will bolt on? Darshu, What does the down pipe flange on your turbo look like? Thanks Guys Joshua |
09-13-2003, 10:16 AM | #7 |
Member#: 756
My RBH5 turbo that I had on my car definately had a 5 bolt flange, and bolted directly to a WRX downpipe that I was using for my turbo set up.
09-13-2003, 03:02 PM | #8 |
Member#: 1676
NESIC
yeah both the WRX and the legacy turbos I have use a 5 bolt flange like you showed above.
09-13-2003, 11:33 PM | #9 |
Member#: 4562
NWIC
Hmmmm must be a difference year to year,the two legacy turbochargers in my toolbox have four bolt flanges and look a bit more like a loyale turbo. Hmmmmmmmm.
MY00 w/MY02 WRX swap, 90-94 Legacy Turbo XMember, swaybar bushings fail every 3wks | erice1984 | Subaru Conversions | 11 | 09-17-2005 02:21 PM |
is the STi radiator a direct fit into a WRX? | angus | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 12-08-2004 05:28 PM |
are current model Legacy Head units a direct swap with current Impreza units? | STiTuner | Car Audio, Video & Security | 1 | 01-19-2004 12:32 PM |
Is the VF 22 a direct bolt on on the STI ?? | carguy19 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 01-12-2004 09:22 PM |
where is the ebrake wire that i splice with the gray wire from my turbo timer??? | wrx182 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 10-12-2001 01:03 PM |
