Old 11-11-2000, 07:14 PM   #1
rubbersidedown
Member#: 2900
Question poor gas mileage - any ideas?
Hello!
I'm new the the Suby scene after just purchasing a '97 Legacy GT sedan with 39,000 miles (automatic).
I really enjoy the car a lot, but I'm somewhat alarmed at how it seems to drink gas. With my wife driving (very conservative), we got 21mpg. I understand that 'less conservative' driving will put a dent in gas mileage, but it seems much worse than other (large V6's) cars I've owned.
So far, I've checked the air cleaner at it seemed fine. Next thing I plan to replace is the fuel filter.
Will resetting the ECU maybe help?
Thanks in advance -
RSD
rubbersidedown is offline
Old 11-11-2000, 07:47 PM   #2
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Post
Check your spark-plugs also. At 30k miles the gap on mine was really large. Way beyond spec. and very worn.
Shawn
spshultz is offline
Old 11-11-2000, 08:44 PM   #3
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
Post
I just bought an RS last week and I've noticed that it really gets bad city MPG. But, once it's on the highway doing distance driving, its great. This seems strange since my former car was a 1995 Impreza L 1.8 with AWD. No how hard or gingerly I drove, gas mileage was pretty much the same. I think the RS just needs to break in, but your Legacy already has 39k on the clock so I don't think break-in is the problem. I'd check to see if a 30k service was completed, you could have clogged injectors, bad plugs, or a fuel filter. I'd check on the service stuff first, then go from there.
Congrats on the purchase too.
Matt
Matt is offline
Old 11-11-2000, 10:15 PM   #4
Lifino
Member#: 2787
01 RS Black
I like to eat ants.
Post
Perhaps...
My girlfriend and I were talking earlier tonight and she was telling me about some lady who bought a car from the Police Auction... She said she was getting horrible mpg, took the car to the dealer... They found a third of the gas tank was full of Marijuana... But I doubt a gas tank can double as a bon&.
-Silas
Lifino is offline
Old 11-12-2000, 05:19 AM   #5
rubbersidedown
Member#: 2900
Post
Thanks for the info, I'll check the plugs today. Anyone have a particular flavor? I prefer Bosch platinums...
Regarding injectors - I was thinking they could be part of the problem (we have that damn oxygenated gas here, too!) but don't know how to clean them. I don't think much of those 'one tank wonder' fuel additives, but don't know any other way.
Wow, pot in the tank. I would like to see someone light that stuff up. HA! They'd have to douse them with a full halon extinguisher!
Thanks again!
RSD
Old 11-12-2000, 05:59 AM   #6
kpratte
Member#: 2760
'08 4Runner V8 Ltd
'10 Tundra Ltd CrewMax
Post
Most of Subie people seem to like the NGKs. I've used them previously on Integras and they were great. I've had problems on some cars with the Bosch platinums because they require increased power to jump the gap. Normal copper NGKs have been first rate.
For fuel injector cleaner, only two products I have seen recommended. Redline's SI-1 and the "Techron" stuff. Techron is patented and is the only thing the BMWs are recommended using. Most dealers will charge an arm and a leg for "fuel injector cleaning" when all they do is dump a thing of Techron in the tank. Read the bottle before putting in! I believe it says to put in on a 1/4 tank, fill it, then change the oil. They want the oil changed because of all the containments that you can losen up.
- Ken
kpratte is offline
Old 11-12-2000, 07:21 AM   #7
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Post
I was getting bad gas milage when one of my wheel barings went bad. Listen for tire noise that sounds like if you have snow/mudder tires on... that is a sign.
Rich L is offline
Old 11-12-2000, 07:24 AM   #8
Matt
Allergic to turbos
Member#: 181
2009 Forester
Cool
I'd have to agree. NGK seem to work the best. I've used Bosch and I haven't really felt any difference. Try the NGK and see what you think.
Matt is offline
Old 11-12-2000, 06:02 PM   #9
Scooby do
Member#: 1217
2005 9-2X
Artic Silver
Angry
I usually get 19 - 22 no matter what kind of driving (Mobil or Shell 89 and 87 octane). I have a MY00 RS, 5- speed. I once even got 12mpg. I just figure since it all wheel drive it gets crappy mileage.
Scooby do is offline
Old 11-12-2000, 06:39 PM   #10
philrb
Member#: 2547
Post
As with any poor gas mileage vehicle:
change your plugs. Check your sparkplug wires...pick a dark place, open hood with engine running, check for arcing.
Add a can of BG44K to the gas...or a double dose of Chevron Techron and do an "Italian tuneup"....keep it in second gear at 45 mph for 15 minutes. This really helps get valves etc. cleaned up.
Check your timing. Change the oil...it may have straight 30 wt. or 20w-50....both are to heavy for the cold months.
If that doesn't improve your mpg then change the O2 sensor.
philrb is offline
Old 11-12-2000, 06:43 PM   #11
vt00rs
Member#: 2235
Post
I almost always get around 24 mpg with my MY00 RS. And I don't drive that slow. My wife has a MY01 L and her O2 sensor went. Her gas mileage dropped significantly but it also triggered the check engine light. 21 mpg isn't that bad, but if the basics don't work I'd look into the emissions.
vt00rs is offline
Old 11-12-2000, 07:17 PM   #12
rubbersidedown
Member#: 2900
Post
Awesome info guys (and gals maybe?)
I'll be looking into all the good suggestions and hopefully find a few more mpg...
Can't wait for the first real snowfall to give the AWD a workout!
RSD
Old 11-13-2000, 12:16 AM   #13
suby2nr
Member#: 2231
Post
Alignment can effect mileage, a good 4 wheel alignment might help.
Tire presure also!
There is a label on your car when you oper the drivers door that recomends the factory tire presure, for the original equipment tires. The tires also have a max inflation presure for a max tire weight rating on the sidewall. Your original equipment tire may have a max presure of 35 or 32 at 1100 lbs max weight(just an example), and the present tires on your car have a max presure of 44 lbs at 1100 lbs, you`re tire presure may need to be adjusted accordingly. Check the tire side wall rating, you can inflate each tire up to its max presure, higher presure may help gas milage, but too high a presure can cause tires to wear in the center of the tread faster, as under inflation will cause wear on the outside tread and decrease gas mileage. Ride and handling are effected by adjusting tire presure also, higher presure may give a harder ride.
Hope this helps
[email protected]
http://www.autocaresubaru.com
suby2nr is offline
HTML code is On
Poor gas mileage in my '03 WRX joeyvaz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 03-22-2013 02:31 PM
cobb poor gas mileage maxler3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 08-17-2005 09:28 PM
Poor Gas Mileag and Trouble Codes dreaminsubys Service & Maintenance 4 11-11-2004 10:36 PM
Drop in Gas Mileage - Any Ideas? zarseven Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-03-2003 10:52 AM
Poor gas mileage from GC8 imprezey Normally Aspirated Powertrain 13 12-21-2002 01:00 AM
