Old 09-13-2003, 02:36 PM   #1
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Default Initial hesitation on cold engine acceleration
For the past 6 months my wife's 98 Legacy GT wagon auto has developed a huge stumble/hesitiation upon initial acceleration just as she puts the car into drive after backing out of the driveway. It fells really weird. You slid the car into drive and push the gas and the car accelerates very slowly and then it takes off fairly quickly (because you push down on the gas a lot to get going). After about 30 seconds, the problem is disappeared. Anyone have any clues? It's not a major issue, but the car hasn't always done this.
Thanks.
Dave
MaddMax is offline   Reply With Quote
Old 09-13-2003, 03:58 PM   #2
2002 GT LTD
Member#: 19144
2002 Legacy GT Sedan
Titanium
My Legacy has done the same thing from day one.
cold starting I assume is the first drive after a long period of it "not" running.
What I did to fix my problem was to install the grounding kit for the motor. You can look around anywhere on this board for purchase or making your own. If you make your own I would invest in better quality materials (which might bring the price into an already made system that has a warranty )
It not only took the hesitation away but the motor idles a whole lot better now.
In case you are not sure what the grounding kit is, essentially it makes your sensors more accurate by properly grounding out the motor to different areas of the frame. I am not going to go into specifics here because there are ton's of places that can explain better than I can.
Maybe others will comment, or have other suggestions. You should have a dealer look at it or a mechanic you think that there is really something gravely wrong. Don't take chances with your beloved suby.
Just a couple of cents from another enthusiast
2002 GT LTD is offline   Reply With Quote
Old 09-14-2003, 03:36 AM   #3
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Thanks for the insight. I know about the grounding kits and may consider it. Her 98 GT has about 80K miles and is still on the stock wires. I'll probably change those out because I believe they're suppose to be changed every 3-4 years.
Dave
Old 09-14-2003, 10:28 PM   #4
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
My car used to be very grumpy upon a cold start. This was when I was using 93 octane. I have since switched to 89 octane and have not had the problem since...
Just a thought
DerFahrer is offline   Reply With Quote
Old 09-14-2003, 11:32 PM   #5
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
If you've done all the basic stuff- sparkplugs, plug wires, fuel filter- and still have the problem, it's possible it might be the coolant temp sensor.
There's a big thread on that in the "Service & Maintenance" forum. They seem to go slowly, and what you're describing sounds a bit familiar. Did you get a CEL yet?
-Brian
KD7000 is offline   Reply With Quote
Misfire cyl#4 ONLY on cold engine Aleksey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 06-23-2009 03:00 AM
Loud clacking noise on cold engine startup with video deepsouthwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 04-10-2009 09:36 PM
Fluctuating idle/hesitation on cold starts Dutchman1101 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-21-2009 11:49 PM
Flat spot on cold engine jemyers 'Old School' Subaru Forum 6 01-18-2008 08:02 PM
Accessory noise, metallic "chirp" when blipping the throttle on cold engine? Davemeister Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-09-2006 04:06 AM
