Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 09-13-2003, 02:06 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Cross Post: IC leak help!
I have an IC leak and I need some suggestion on how to address it. It's not visable, it's somewhere down in the core. Is there some sort of liquid sealing option? If it needs to be sent out any recommendations, any local shop I can bring it to?
Joshua
yebokmj is offline   Reply With Quote
Old 09-13-2003, 03:01 PM   #2
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Im guesing it needs to be welded.
~v6
V6TurboTA is offline   Reply With Quote
Old 09-13-2003, 09:48 PM   #3
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
liquid sealing isn't an option as anything you put in will find it's way into your motor. If you can't afford to have it welded and can pin point the leak (and the leak is small) you can mickey mouse it and try JB weld... lot of if's there though.
What kind of intercooler are you using?
Fitz
Fitz is offline   Reply With Quote
Old 09-13-2003, 09:57 PM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
I'm curious how you know the intercooler is leaking. I'm pretty sure I have the same one you do, the JC Sports kit one right?
lotusTT is offline   Reply With Quote
Old 09-14-2003, 12:08 AM   #5
Mumbles
Member#: 248
You could maybe pinpoint it a little better by pouring some gasoline through there, and looking for exactly where the leak is coming from. There is a radiator repair place near my house, it's in South Boston, called "Albany Radiator". You can give them a call and maybe they can help you...
B
Mumbles is offline   Reply With Quote
Old 09-14-2003, 01:45 AM   #6
yebokmj
Member#: 2213
Brilliant Red
Default How I know about the leak
Yes it is the JC sports IC. I know I have a leak because all of a sudden I found oil on the IC fins and not anywhere near where it could come out an exhisting opening. Then there was the less boost shown on the gauge and less power. I have since taken off the IC sealed it up and pumped air into it under water. The leak is somewhere in the core. I am not sure how I would get at it if I was to use the JB weld approach. I will call some radiator places on monday since I will be up at Amherst. I might also look up the place you suggested. I am intrested in your gas approach?
Thanks,
Joshua
Old 09-14-2003, 02:58 AM   #7
Mumbles
Member#: 248
I just suggested gas over water. Gas won't ruin a motor.
It also has the benefit of cleaning any built-up oil inside there.
IC leak Help! yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 3 09-14-2003 08:21 PM
Cross Post: IC leak help! yebokmj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-13-2003 02:30 PM
Cross Post: Help! Please tell me what this noise is. yebokmj New England Impreza Club Forum -- NESIC 5 07-22-2003 06:53 PM
Cross Post: Help! Please tell me what this noise is. yebokmj Legacy Forum 1 07-22-2003 10:57 AM
Cross post: Looking to buy an Impreza for a relative, please help me in my search! Samirr76 Tri-State Area Forum 2 09-01-2001 11:02 AM
