Old 09-13-2003, 09:27 PM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default need help on cable-> hydro clutch pedal swap
hey- i was wondering what bits i would need for a cable to hydro pedal box swap, do i need all 3 pedals?
ive got all 3 DM RHD bits, but ive found out taht they wont work. - any suggestions? anyone know if the MC is compatible, or the gas/brake pedals are?
h
supermoose is offline   Reply With Quote
Old 09-14-2003, 11:36 PM   #2
RedBrighton96
Member#: 1246
2011 WRX
Replied to your PM, wanted to add that you only need to replace the clutch/brake pedal assembly, the accel pedal is independant of the other two.
Here is what i used for my conversion.
-RS pedal box
-RS master cyl
-WRX hardline (had to be bent some and basically customixed to fit properly, don't know if the RS hardline would be a better choice or not)
-WRX flex line
-WRX slave
My reason for using the WRX stuff is because I have WRX tranny in the car now since I decided to break the stock one. Need more info, PM me
Rob
RedBrighton96 is online now   Reply With Quote
Old 09-14-2003, 11:41 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
RS pedal set, clutch master cylinder, RS Slave Cylinder, RS clutch line(both the rubber and the steel line) and obiously the trans to use it. what trans are you going with?? THe RHD pedals will not work as their positions on the firewall mounting rail are complete different.
Jeremy
Old 09-15-2003, 09:45 AM   #4
supermoose
Member#: 9093
swap starr
Default m
hey- im using the JDM 4.11 94 wrx trans, i think i found a pedalbox assembly, any idea if my MC will work? im guessing it should work fine
- any pix of the USA 2.5rs MC taken outa the car? im wondering if the push rod is the same
h
Old 09-15-2003, 01:29 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
the masters themselves are probably identical, the RS or WRX clutch master will work for you, you are going to need a WRX slave cylinder, RS clutch hard line(they bolt in a slightly different spot from what i remember), WRX clutch hose(i rec the stainless braided one). and don't forget you'll need the WRXclutch
Old 09-15-2003, 10:50 PM   #6
supermoose
Member#: 9093
swap starr
Default length of shaft
hey can somone measure the shaft of their MC? from the edge of the rubber boot till where the thread starts happening for the nuts?
boot--------------thread/nut/thread
the length of the ---------------
i think ive got to shortern mine, and have to figure out how much?
h
i got the WRX trans, clutch, flyhweel, and a stainless steel custom line all lined up in my car:P
h
First generation Legacy hydro clutch pedal - are other hydro pedals compatible? ciper Transmission (AT/MT) & Driveline 2 07-09-2009 11:47 AM
Wanted - Hydro clutch pedal and grey gear shift trim for first generation Legacy ciper SCIC Private Classifieds 0 07-08-2009 08:03 PM
Cable vs hydro clutch questions kingbobdole Transmission (AT/MT) & Driveline 1 12-19-2006 07:42 AM
PLEASE HELP! Need help on 97 Leg. Engine Swap FastBlackLegacy Subaru Conversions 2 03-18-2005 04:38 PM
need help with cable modem, digital cable. trying to split signal STEALTH-WRX Off-Topic 9 08-18-2003 04:43 PM
