Old 09-14-2003, 07:56 PM   #1
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Corolla GT-S Hachi Broku
Default EJ22T Swap into MY99
For those with an EJ22T... Do you regret doing the legacy turbo engine instead of an EJ20?
How easy was the EJ22T swap?
What parts did you use?
Where'd you get the engine? How much?
How involved was wiring?
Any advice?
Soon2BturbodRS is offline   Reply With Quote
Old 09-16-2003, 11:55 AM   #2
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
i would also like to know all the above questions.
soon2bturbodrs: let me know if you find any information at all. im looking to do this as well with my 2002 2.5rs. i will let you know as well.
darioc is offline   Reply With Quote
Old 09-16-2003, 05:46 PM   #3
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
search....search....search....
it's all out there if you look
Scoobyslack1 is offline   Reply With Quote
Old 09-16-2003, 07:08 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Its asked every other week so ya I know its out there
Old 09-16-2003, 07:24 PM   #5
serious
Member#: 22879
I would agree with the other people on the search function. You will come across many post that you can read. Here's my two cent on it:
I bought a 93 turbo sports sedan for my 96 legacy conversion. After about 3 months of searching and debating i finally convinced myself to get a 2.0 engine. Why? Several things. Performance parts are not easy to find for the 2.2, stuff like pistons, roads etc...
For what you'll pay to have a high milage engine rebuild on top of the cost to buy the motor you might as well get a 2.0 that runs with low milage. But then agian if you can find a great deal on one then that opens up a lot of options to you.
I just sold a complete package for 950 that included just about everything you needed to put in a 2.2.
There will be just as much work putting in this engine as there would be a 2.0 so you might as well do the engine you want to do first.
Brent
serious is offline   Reply With Quote
Old 09-16-2003, 07:56 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
What? Thats not right.
Just to give you an idea, I just saw a 2.4liter WRX that was using the 2.2t block. The car looked TOTALLY stock, he was even still using the stock intercooler. Passed smog too. Used the WRX heads on it.
The same parts you use for the 2.0 are usually applicable to the 2.2 , give me an example of what doesnt fit? Hell even WRX headers and up pipes are a direct bolt on. I know because Im going to use some WRX headers and up pipe on my 2.2 turbo engine! Not only that but even a WRX sway bar on the legacy turbo cross member.
Old 09-17-2003, 06:09 PM   #7
imposter
Member#: 10642
95 Impreza EJ22T
I went with the 2.2 b/c its nearly indestructible, and its widely agreed that the EJ22 and the EG33 are the best two engines that subaru has ever built. I also wanted to be different. WRX swaps into old school imprezas are a dime a dozen. To answer your first question, I dont regret it a bit.
As for your other q's-same as a WRX swap
-Jim
imposter is offline   Reply With Quote
Old 09-17-2003, 09:24 PM   #8
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
ej22T swap is what i did, and i am glad i did it. yea the wrx has lots of parts butmost of them can be moded to fit right onto the ej22t excluding the intake.
subiekid is offline   Reply With Quote
Old 09-17-2003, 10:29 PM   #9
koolaid
Member#: 43491
1997 Impreza Outback
Red
how much is a good EJ22-t
koolaid is offline   Reply With Quote
Old 09-17-2003, 11:52 PM   #10
subiekid
Member#: 25516
just depends, some times you can get an entire 91 to 94 turbo legacy with damage for 900 bucks. most of the time you only find the motor for about 800 to 1100.
Old 09-18-2003, 02:08 PM   #11
subiekid
Member#: 25516
Miata or EJ22T swap into OBDI Impreza? PumaTurbo Off-Topic 28 05-26-2006 07:05 PM
Need help with 92' ej22t swap into 94 impreza ej18 lotus2843 Subaru Conversions 6 01-04-2005 10:54 PM
ej22t swap into 95 leg... ecu? legacy2003 Pre-2002 Factory Turbo Powertrain 6 10-01-2003 07:37 PM
EJ22T Conversion into MY99 2.2L... Can anyone here do it? Soon2BturbodRS North West Impreza Club Forum -- NWIC 1 07-03-2003 12:30 AM
EJ22T swap into RS, tranny question? ImprezedRS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-05-2002 09:16 AM
