Old 09-14-2003, 10:28 PM   #1
dknc
Member#: 8165
2001 RS 2.5
Asspen White
Default car won't start, dip stick indicate no oil.
This morning my car doesn't start, dash board has a repeated clicking sound, lights comes on fine, no engine sound at all. I checked the dip stick, no oil level, it's like the dip stick is dry. I poured 1.5 bottle of castro engine oil in, check the dip stick, the level is above full?! Start engine again, no luck, holding on to the key at start position, kept starting, it finally cranked and go, then I check engine oil again, it's all black.
Now I think I need to change engine oil, but, how come the engine oil light doesn't come on to warn me that engine oil is low and needs to be changed? what could be the problem?
dknc is offline   Reply With Quote
Old 09-14-2003, 10:35 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The oil warning light is for oil pressure, not level. The light will only come on when the oil pressure is dangerously low, just a few PSI. If you ever see that light while driving pull over and stop the engine immediately.
If 1.5 qt. of oil brought your oil level to well above full then you weren't that low on oil to begin with.
Your starting problem sounds like it may be a weak battery, bad starter, or poor battery/ground connections.
Old 09-15-2003, 04:57 AM   #3
dknc
Member#: 8165
2001 RS 2.5
Asspen White
Default changed
Ok, I changed the engine oil now, starting just fine, but only started the car 3 times, the first time right after engine oil changed, the start seemed sluggish, like it cranked 1 or 2 times then start, I'll try again in the morning see if it starts smoothly.
Old 09-15-2003, 11:37 AM   #4
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
It has nothing to do with your oil. Your battery is probably getting old.
I try to check my oil at least once a week. I have two cars that are over 10 years old, however, so this is a habit and necessity for me...
DerFahrer is offline   Reply With Quote
Old 09-15-2003, 04:17 PM   #5
dknc
Member#: 8165
2001 RS 2.5
Asspen White
Yeah, it still doesn't start... it's not the oil. Eventhough the lights and all the electrical stuff seems to look bright and no dimmering, I'm thinking it could be the starter...
Old 09-15-2003, 08:51 PM   #6
DILLIGAF Racing
Member#: 29440
2015 WRX
try smacking the started with a screwdriver or something. My work truck is doing this.
DILLIGAF Racing is offline   Reply With Quote
Old 09-15-2003, 11:47 PM   #7
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
Is it a manual? If so, pop-start it. If it starts and runs good, then it's either the battery or starter, and nothing else...
Old 09-17-2003, 08:55 PM   #8
dknc
Member#: 8165
2001 RS 2.5
Asspen White
Default yup... and thankyou all.
Well, yesterday my dome light starts to look dim, and this morning when I jump started my car, the jump start went smoothly, and culprit is the battery! Brought it to the dealer have it replaced under warranty. Heard another person with the same situation with the battery same year car. what's up with that? any thanks all for the help.
Old 09-17-2003, 11:46 PM   #9
gator
Member#: 18296
2004 STi
WR Blue
It's more than likely a nearly dead battery. The clicking you hear are the relays for various pieces of equipment in the car latching and dropping out due to low voltage.
gator is offline   Reply With Quote
Old 09-18-2003, 06:33 PM   #10
Skyline
Member#: 6074
2002 Impreza WRX
Sedona Red Pearl
I already changed the battery in my MY02 earlier this year. Sad to say, the OEM battery is crap and it's under powered. I dropped in a $40 battery from BJs Wholesale and it starts like a champ.
Skyline is offline   Reply With Quote
My car won't start, no spark boost_wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-07-2009 10:07 AM
Fuel pump won't start, blown fuse SBF 2, car won't start ClassicGC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-29-2008 10:18 PM
Car won't start - cranks but won't start dave_88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-12-2007 11:29 PM
How to read the oil dip stick??? Is my oil level low?? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 08-10-2005 03:09 PM
car won't start - no fuel pump sound driver8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-13-2004 08:21 PM
