Old 09-15-2003, 12:13 PM   #1
simwahWRX
Member#: 20870
Midnight Black mica
Default ecu and coolant temp
I'm thinking about a cooling system upgrade, i.e., the Evan's System.
This system potentially has a much higher operating temperature than an ordinary system, because it sucks a lot more heat off the engine (and it boils at 375F, greatly reducing vapor problems).
It also runs at very low pressures.
Will this screw up anything my ECU does?
I imagine I'd throw a coolant temp or thermostat code. Maybe there's a work around like the resistor fix for the EGT sensor?
I figure I can work around fan issues, but am concerned about such high temps messing with my tune.
simwahWRX is offline   Reply With Quote
Old 09-15-2003, 04:33 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I installed the PWR radiator. Bigger, better and you can install the stock fans to it. I like the idea of this stuff
But this stuff sounds pretty good as well.
Mick
mick_the_ginge is offline   Reply With Quote
WTB: 52mm Omori Full Color Coolant Temp and EGT DeusExMachina Private 'Wanted' Classifieds 0 10-07-2006 01:56 AM
WTB: Powersteering reservoir, MAF hose, clock and Coolant Temp sensor yebokmj Private 'Wanted' Classifieds 3 07-04-2006 12:45 AM
FMIC's, summertime roadracing and engine coolant temps.... 04STiguy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 09-13-2005 12:26 PM
Swap and higher coolant temps xcntrk75 Subaru Conversions 10 05-16-2005 05:06 PM
UTEC shows NO TPS signal NO MAP, and no air or coolant temps. jared nelson Engine Management & Tuning 4 12-20-2004 05:47 PM
