Old 09-15-2003, 01:36 PM   #1
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Question 16" tire size preference for rallycrossing?
Are there other conditions, besides snow, where one would prefer a 205/55 (or narrower) over a 225/50 "all-season" tire when rallycrossing?
Would (water truck induced) mud over hardpack dirt disadvantage a 225 over the 205 since the 205 might bite through a little better?
Other conditions anticipated: sand, silty flour sand, gravel over hardpack, hardpack. Not much loam or snow anticipated, but who knows?
Coati is offline   Reply With Quote
Old 09-16-2003, 07:11 PM   #2
Coati
Member#: 9106
2015 FXT - DGM
Bump!
Old 09-16-2003, 07:40 PM   #3
Craig W
Member#: 643
1999 2.5RS
WRX powered
From what I've seen on the WRC and at SCCA Pro-Rally events, the pros always run tires w/ smaller width on loose surfaces. They only run wider tires on tarmac. There must be a reason.
Craig W is offline   Reply With Quote
Old 09-16-2003, 07:53 PM   #4
Coati
Member#: 9106
2015 FXT - DGM
Thanks! I was observing the real rally tires were tending towards narrower, too.
Time to ditch my bald-cornered 225/50 Dunlop SP-5000s for some 205/55 KDWS, maybe...
Old 09-17-2003, 01:00 PM   #5
10th Warrior
Member#: 2230
2000 2.5RS
Silverthorn, PGT #671
Dunlop SP-5000s
this tire just plain sucks on gravel or dirt. good on clay or wet tarmac though.
10th Warrior is offline   Reply With Quote
Old 09-17-2003, 01:28 PM   #6
Coati
Member#: 9106
2015 FXT - DGM
Thanks!
It was pretty amazing at the transformation: During real runs (where a water truck went through, then a grader, then one car then me -- in near 100-degree heat), the slurry on the surface was basically frictionless and my tires wouldn't bite through.
However, at the end of the day there were (water truck-less and grader-less) fun runs and the tires comparitively HOOKED up on the exposed, rutted surfaces. I shoulda hung at the back of the run group and let the others sweep the mud off.
It seems like the 205s might carry a relative advantage over the 225s in the looser conditions (soft over hard and soft over soft), and maybe the KDWS over the Dunlop in the same?
STU STI tire size preference makofoto Motorsports 41 04-19-2006 10:55 PM
+0 tire sizing questions for 16"s... Siper2 Tire & Wheel 15 01-04-2006 11:37 AM
16" tire size question ImprezedRS Tire & Wheel 1 04-15-2004 02:31 AM
Alternate 16" tire size larryg Tire & Wheel 27 11-11-2003 03:50 AM
Need a tire size recommendation for rims pio!pio! Brakes, Steering & Suspension 1 06-30-2002 05:22 AM
