Old 09-15-2003, 07:32 PM   #1
MidRex
Member#: 32841
2007 STI (Sold)
03 WRX FP Green PPG (RIP)
Default Starting UP and Down Pipe Install
Just wondering...do I really need to remove the front passenger wheel to access the front O2 sensor. The reason that I am asking is because If I don't have to remove the wheel...I was just going to drive the car up on Rhino Ramps to do the install. Has anyone done it without removing the wheel?
MidRex is offline   Reply With Quote
Old 09-15-2003, 07:49 PM   #2
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
I think I removed the wheel when I did my uppipe. What you want to do is turn the wheel all the way to the right so you have as much access to the wheel well as possible. Can you crank the wheel when it's on Rhino Ramps?
02R6 is offline   Reply With Quote
Old 09-15-2003, 07:50 PM   #3
doogdog
Member#: 29308
2005 Outback XT LTD
Champagne Gold Opal
Assisted in countless uppipe installations, here's the easiest way...
Drive up on your Rhino ramps and then put a jack under the jack point on the passengers side and put the car on a jack stand. Make sure you break loose the lugs while it's still on the ramps. when you're done, reverse the process. Make sure you have the offset O2 wrench too, the straight one will not work.
Best of luck, don't forget to replace all the gaskets you take off.
DD
doogdog is offline   Reply With Quote
Old 09-15-2003, 07:59 PM   #4
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
DD
Amen.
wcbjr is offline   Reply With Quote
Old 09-16-2003, 01:12 AM   #5
MidRex
Member#: 32841
2007 STI (Sold)
Once I have it up on the ramps how could I get a jack underneath the passenger side jack point because the ramp is in the way unless there is another jack point other than the one it shows in the manual.
DD
Old 09-16-2003, 01:35 AM   #6
ccdelro
Member#: 14398
2003 White Wag Wrx
Stage Dos
Just put it on jack stands with the wheel(s) removed. I think it's a 100% times better/easier. You'll need to take off the fender lining anyways, and it's easier without the wheel there.
ccdelro is offline   Reply With Quote
Old 09-16-2003, 01:42 AM   #7
Black-X
Member#: 31702
2013 WRX
there is a jack point in the middle, front of the car. it is a 4X6, black plate of metal. hmmm... maybe i can get pics tomarrow if you need one.
Black-X is offline   Reply With Quote
Old 09-16-2003, 01:43 AM   #8
Yungimoto
Member#: 14940
Put it on jackstands if you have them.
Yungimoto is offline   Reply With Quote
Old 09-16-2003, 02:02 AM   #9
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
I did it on ramps. Did not remove the wheel. Had no problem accessing the O2 sensor through the little cut-out without removing the wheel or the wheel well liner. Didn't have to turn the wheel at all either, was fine working from below.
I used the Perrin instructions:
http://www.scoobymods.com/forums/sho...=&threadid=194
Macabre is offline   Reply With Quote
Old 09-16-2003, 02:07 AM   #10
Black-X
Member#: 31702
2013 WRX
definatly get the offset o2 sensor socket. i tried a straight one first. no go. had to take the girlfreind's car to the parts store.
Old 09-16-2003, 08:09 AM   #11
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
if you get the car high enough, you can get to it from the bottom and inside the wheel. you do not have to take it off. also, the higher you can get the car the better because you need room to work around under there. the O2 removal tool is key, but if you have to, you can hack the heat shiled with a dremil tool and remove the shield, then the manifold and never mess with the O2. as a suggestion, hack the heat shield anyway so the next time you don't have to mess with the O2.
andif you are doing this on a sedan...be prepaird...the O2 socket is a very tight fit. you might be better off with buying a crows foot wrench of some kind that will fit the sensor.
and use lots of liquid wrench...it is your friend.
Wheeler Bement is offline   Reply With Quote
Old 09-17-2003, 03:21 AM   #12
MidRex
Member#: 32841
2007 STI (Sold)
OK...all done. It wasn't that bad and all I used was ramps. One question. I didn't install that heat shield that was connected to the stock uppipe because I couldn't find a place for it to go.
Also...It might be just because it is really late, but if you are facing the front of the car...the left intercooler mount. Is there an extra hole there to the left of the mount? I just can't remember if there was anything there...if there was...I have nothing to put there.
Thanks
Old 09-17-2003, 05:30 AM   #13
Subiemax
Member#: 30691
2013 FRS
RED
Thanks
Been a long time, but I think it is a heat shield for the turbo.
I could be wrong though.
Subiemax is offline   Reply With Quote
Old 09-17-2003, 06:57 AM   #14
VetteVert
Member#: 5961
2005 STi
CGM
Talking about this hole? If so, it was blank from the factory (or at least mine was )
VV
Thanks
VetteVert is offline   Reply With Quote
Old 09-17-2003, 09:58 AM   #15
Turbo4Life
Member#: 22036
2002 WRX Wagon
WR Blue Pearl
That extra hole is for a larger intercooler. (ie...Sti Intercooler, etc)
Turbo4Life is offline   Reply With Quote
Old 09-17-2003, 10:45 AM   #16
MidRex
Member#: 32841
2007 STI (Sold)
Thanks for the pic. That solves one problem, now for this stupid little heat shield that was bolted to the stock uppipe with 2 10mm screws. Anyone?
VV
Old 09-17-2003, 11:19 AM   #17
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I have no more shield on my uppipe.
Old 09-17-2003, 11:27 AM   #18
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
maybe you could use the ramp on just the left side and jack up the right side?
spankaveli is offline   Reply With Quote
Old 09-17-2003, 11:31 AM   #19
CyC
Member#: 23499
2006 Saabaru
I didnt put back the turbo heat sheild or the heatshield on the passenger exhaust manifold. I haven't burned through anything yet and the car runs like a champ Anyone think I'm going to get into any big trouble?
CyC is offline   Reply With Quote
Anyoen gonna wanna sit in on an up and down pipe install? njskatchmo Tri-State Area Forum 11 05-04-2006 12:11 PM
04 up pipe and down pipe install needed jimtweet Tri-State Area Forum 11 02-24-2005 08:04 PM
up and down pipe install samagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-17-2005 09:37 PM
up and down pipe install jeffsnyder Forester Forum 1 06-28-2004 03:36 AM
up and down pipe post install overheating! michael skalyo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-02-2003 12:40 PM
