Old 09-16-2003, 03:38 AM   #1
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Default Anyone is using an Apexi turbo timer in their STi? Does it work with the stock alarm?
Like what the title said.
Anyone is using the Apexi turbo timer in their STi?
I am wondering if it is compatible with the factory Subaru upgraded security system.
Thanks.
ADDICT
JDM addict is offline   Reply With Quote
Old 09-16-2003, 11:12 AM   #2
Hungbee112
Member#: 43572
2003 Evolution
Lightning Yellow
I don't think your car needs a turbo timer. A friend of mine emailed subaru about that for his STI, and they said it was unecessary. Something about a gate that opens and drains the oil out of the turbo when its shut off. You should try contacting them, they could probably explain it better.
Hungbee112 is offline   Reply With Quote
Old 09-16-2003, 11:15 AM   #3
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
IBJDM Addict rails him for not "just answering the question" and posting "opinion not fact"
Hungbee is right though...don't waste your moolah
Neek is offline   Reply With Quote
Old 09-17-2003, 01:56 AM   #4
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
My question was whether the Apexi turbo timer is compatible with the factory alarm.
I wasn't asking if the STi can benefit from a turbo timer.
ADDICT
Old 09-17-2003, 04:32 AM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
u might have to cut a wire
thats what i did on my rs but that apexi tt is badace
Old 09-17-2003, 01:02 PM   #6
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Thanks
ADDICT
Old 09-17-2003, 02:48 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
alright try this
look under ur instrument panel, like behind that bottom plastic piece where ur knees would be, i hope u know where im talkin about, pull that out <should already be out from the TT install unless u havent started>
look for the box that the security system uses
look for a pinout on it
if u see a number that says "ignition +12v" either cut that wire or pull it out of the harness
thats what i had to do and all it did was scare the poop out of me when i put the harness back into the box cause the alarm went off
How to read an Apexi Turbo Timer TimBeeno Electrical & Lighting 4 08-06-2007 02:37 PM
wire harness for apexi turbo timer for 04 sti ddman80 Electrical & Lighting 0 10-24-2006 04:30 PM
apexi turbo timer install 04 sti avengermike Electrical & Lighting 0 11-24-2005 01:14 PM
2004 Sti....does it come with an immobilizer for antitheft??? Maverick1 Electrical & Lighting 12 10-28-2004 08:43 PM
Anyone use an HKS Fuel computer in their car? BrysImpreza Normally Aspirated Powertrain 1 11-18-2001 12:04 AM
