Old 09-16-2003, 02:52 AM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default lemme hear your axel nut stories!!!
word. so i have these spare hubs from my JDM STI rite? nice and clean, correct bigarse brake heat shield with slots cut in for cooling/dust etc etc. i pull the axel/brake/struts off them to swap them in my car, and the BEARINGS ARE TOAST!. boooooo. being on a budget, and not feeling like taking it from my parts counter (i go there 3x a week already for expensive stuff (even on discount)), i have decided to pull the FWD axels outa my hubs (ARGH!) and put the nice AWD axels in my existing hubs (with good hub bearings). theyre outa the car already, rusted to poo, and not coming apart. ive tried the torch, the dremmel, the toarch, the dremmel, the wrench with breaker bar, the dremmel, the torch, the wrench. its not happening. i tried the drill and it broke me.
any suggestions>?
h
supermoose is offline   Reply With Quote
Old 09-16-2003, 10:56 AM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Are you sure the bearings are gone ? Sometimes when you pull the axle nut and the axle out, the bearing starts to come apart in the hub. Put back in the shaft and torque up the nut and check it again. It would be idea to put the upright in a vise and put the rotor and a wheel on and then check for play. That will tell you for sure.
Ver.III is offline   Reply With Quote
Old 09-16-2003, 11:05 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
mine were on the car
i took the center cap off of the rim
tightened the rim back down
lowered the car had some one stand on the brake and used a breaker bar with a 6' extension
Old 09-16-2003, 04:15 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Mine was only on a WRX with about 60k miles with a destroyed hub/bearing assembly. With the 650 ft-lb impact it came off in about 1 second.
Old 09-16-2003, 07:53 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Using a total length near 5 feet long and my 150lbs jumping on the end multiple times my axle nut slowly turned.
I had a breaker bar, not enough leverage. I had to visit home depot and find a pipe that would fit over it. The pipe was less than 10$. I doubt an impact wrench would have removed it, most likely it would have trashed the nut.
Old 09-17-2003, 12:01 AM   #6
RedBrighton96
Member#: 1246
2011 WRX
Mine never came off with an impact. Required a breaker bar and half of a jack handle and a couple hundred pounds of force at the end to get them to break loose.
Make sure you try to straighten out the spot where the nut is punched to keep it from spinning, one spot on the lip shoudl be bent in a bit. Take a screwdriver and pry that out.
Rob
RedBrighton96 is offline   Reply With Quote
Old 09-17-2003, 02:24 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
Remember that the axle nut should be replaced every time as well, usually your replacement axle comes with a new one.
Old 09-19-2003, 04:38 AM   #8
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
Holy cow! I had the same problem, couldn't get my nut off.
First attempt we broke a Craftsman breaker bar. This thing had broken many nuts in it's day. It met it's match that day. I suppose the 6' cheater bar had something to do with it.
Back from Sears with a fresh breaker bar (don't you love that), I'm stomping the brakes, and my buddy who is slightly over 200 #'s has the new breaker bar, 4' extension, and he's jumping up and down on it. Unreal.
Oh yeah, in between attempts we hit it with propane, then MAP gas, and an Impact driver. It scoffed at the Impact, many times.
In the end, a chissel, and two full hours of repeated hammering broke through the nut. Even when we had a full side of threads ripped off, the sucker held. It wasn't until we broke through the collar of the nut, did it come lose. Again, the breaker bar. ps, just shave one corner of the nut off, and the socket will still work.
Now, upon further examination, the last jackass who tightened this thing was obviously paranoid. Every thread on the sucker was squashed to the point that another half turn would have stripped it. I'd guess 200 #'s or more, and who knows how many miles .
All I can say, is I feel for you. Prepare to sweat. Best of luck with your nuts.
^ that guy looks like he might have just got a nut off. I present him to you for inspiration.
Streetman is offline   Reply With Quote
Lets hear your suby horror story?? Subey03 General Community 275 08-08-2013 11:12 PM
Once again, must hear your crazy secretary stories... Heavy Fuji Off-Topic 6 04-22-2007 01:52 AM
Lemme see your Tint wuncraziaznfoo Member's Car Gallery 7 09-15-2004 12:51 PM
Alrighty STi/04 Kids... Lemme see your body.... kits.. Midnight_Gold Member's Car Gallery 31 06-26-2004 05:34 PM
lemme hear about your top speed ekyub Texas Impreza Club Forum -- TXIC 66 05-11-2002 11:21 AM
