Old 09-16-2003, 06:18 PM   #1
cyberpest1
Member#: 42973
Default engine change WRX just will not start HELP
Just fitted a replacement engine.
Into a 1994 subaru impreza saloon.We have reset the ECU but just can not start the engine.
There seems to be a lot of pressure in the water system and loosing water but no sign of water in oil.
Also only firing on 2 plugs?The engine came out of Subaru 1994 which was in a smash.There was only 55000km on the clock.Could the cylinder walls have cracked in the crash or anything like that.
Any suggestions.Help
Report
cyberpest1 is offline   Reply With Quote
Old 09-16-2003, 09:19 PM   #2
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Probably not the best forum for this.. but we'll give it a go...
Please elaborate on this...
which 2?
What's a compression test showing you?
Have you verified mechanical timing? Are you getting fuel?
Fitz
Fitz is offline   Reply With Quote
Old 09-17-2003, 03:08 PM   #3
JSiwek
Member#: 14909
Did you pull the heads off and check the valves? Since the timing belt is on the front of the engine, it's really suceptible to getting hit in a crash. When that happens the belt stops, the cams stop, the valves stop wherever they happen to be, but the pistons keep going... and slam into the valves. It's hard to find a Subaru engine from a car which was hit in the front that doesn't have bent valves... if it's bad enough, it wouldn't start.
Dunno if it's the problem at all, but it's something you should check.
Jeremy
JSiwek is offline   Reply With Quote
Old 09-17-2003, 10:04 PM   #4
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
What does it sound like when it tries to start? Could be lifters if engine was sitting long. Does it turn over? Try to turn over? does timing belt move? so many questions man be more specific and I can help you.
AWJunkies is offline   Reply With Quote
I am desperate! My car will not start! HELP! KURB21 General Community 11 10-31-2006 06:53 PM
95 Impreza Will Not Start..... Help!!!!!!! EricClouser Newbies & FAQs 0 12-24-2005 10:32 AM
Car will not start! HELP! GMTarkin Engine Management & Tuning 1 09-18-2005 10:16 PM
Car will Not start, HELP PLEASE RandyAndy Off-Topic 36 03-26-2005 08:50 PM
engine change just will not start. Help? cyberpest1 Newbies & FAQs 1 09-16-2003 03:39 PM
Message Board Statistics All times are GMT -4. The time now is 09:20 AM.
