Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 09-16-2003, 08:00 PM   #1
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
Talking Welcome to the Old Skool Forum!
This forum is for discussion of any Old Skool Subaru (anything BUT Imprezas, Legacies and Foresters)
So get out your 4x140 Wheels and have fun!
WagonMonster is offline   Reply With Quote
Old 09-16-2003, 08:37 PM   #2
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
Longbed Brat!
Cool pics on this site too: Old Subarus in Australia
Matt is offline   Reply With Quote
Old 09-16-2003, 09:56 PM   #3
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
absolutely without a doubt the best idea evAr! Definitely a fair trade for the STi n00b forum
ws6fiero is offline   Reply With Quote
Old 09-17-2003, 12:46 AM   #4
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
The banana is doing about half as much dancing as I am right now! This is fantastic!!
DerFahrer is offline   Reply With Quote
Old 09-17-2003, 01:14 AM   #5
ImprezaRSinCT
Member#: 1810
14 Acura TL w Tech
15 Honda CR-V EX
Default Re: Welcome to the Old Skool Forum!
[i]...
So get out your 4x140 Wheels and have fun! [/b]
but my MY88 XT6 has 5x100 wheels damnit!
ImprezaRSinCT is online now   Reply With Quote
Old 09-17-2003, 10:51 AM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
my 1968 Scoob...
work in progress soon he'll look like this:
this is going to be so much FUN!!!
Jamie
www.subiegal.com
Old 09-17-2003, 01:47 PM   #7
steve_d
Member#: 315
INDEED...it's interesting to see the scooby folks taking an interest in restoring old scoobys...
sjd
in the market for an old 2 door GLF...
steve_d is offline   Reply With Quote
Old 09-17-2003, 02:03 PM   #8
Matt
Allergic to turbos
Member#: 181
2009 Forester
Default Re: Re: Welcome to the Old Skool Forum!
A while back, I actually saw an Impreza L with XT wheels on it. Looked awesome!
Old 09-17-2003, 03:00 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Thats because the XT6 was a test bed for alot of technology the legacy (and future subarus) use, including the bolt pattern/offset and front strut attachment style.
The XT6 is the cross over subaru, it doesnt really live in either generation.
Old 09-17-2003, 03:33 PM   #10
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
I received a little education on the XT6's power steering at the dealer. I needed steering bellows for my XT GL, and the guy held me up, saying "You have the 4cyl right? Coz if you have an XT6 you hafta use Subaru approved power steering fluid, not ATF or anything else. If you do, you'll screw up the whole system and cause thousands of dollars in damage"
Upon reading about it, I learned the XT6 has an electrically operated pump, not engine operated like other cars. So it's quite a fancy item which MUST receive the proper care to function correctly...
Old 09-17-2003, 04:08 PM   #11
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
One day at a time- she'll be white on Rally Blue Pearl (you know, real Rally Blue ) hopefully sometime this spring
Brian
Old 09-17-2003, 05:11 PM   #12
ImprezaRSinCT
Member#: 1810
14 Acura TL w Tech
15 Honda CR-V EX
taken from the www.xt6.net FAQ....
Q - My power steering works sporadically or is out entirely; I've heard the XT6 uses some sort of special power steering motor and fluid - how hard is it to repair or replace?
A - The XT6 uses a unique electrohydraulic system of providing power assist to the rack and pinion steering system. Subaru dubbed it Cybrid steering (whatever that was supposed to mean) and it is very precise and reliable. Making use of an optical sensor "watching" the movement of the steering wheel coupled with some electronic brainery under the hood the Cybrid system uses an electric motor to power a hydraulic ram system to pump the fluid where it's needed. With this system there is no belt driven power steering pump like that appearing on almost all other cars. The motor is highly reliable and generally performs flawlessly. However, recently a spate of owners have had problems with the electric motor's brushes wearing down to the point that they need to be replaced and this causes hesitation or it causes the unit to not function at all. Replacing the brushes is not too terribly difficult, and the brushes themselves are very inexpensive if you know the right place to get them (try Anthony's Subaru in Kelowna, BC - ask for Paul). Of particular note is the fact that there was a recall on the power steering motor to install a wire to correct similar sporadic operation... if your power steering motor has a long (usually blue) wire running from it to a wiring harness in front of the driver's side of the firewall, then you have had the recall done. If not, this may be the source of your hesitation troubles.
One last word on the XT6's power steering system: UNDER NO CIRCUMSTANCES - REPEAT - NEVER EVER use "regular" power steering fluid in the XT6's system. It WILL ruin it - period. The Cybrid power steering fluid (Subaru part # K0209A0080), although far more expensive (about $25US for a quart/liter) is the ONLY fluid that should ever be used. It apparently is so dramatically different in its chemical make-up that use of regular fluid will cause rubber O rings to deteriorate leading to pump failure, etc. Twenty five bucks is far less expensive than a new power steering system. If you take your car to a commercial establishment to have your oil and other fluids changed, it is advisable to instruct the technician not to touch the power steering fluid. You may even want to print a clear warning on a bright orange label affixed to the unit - it may sound extreme, but it's a small thing compared to the costly repairs and frustration it might avoid.
Old 09-17-2003, 10:38 PM   #13
ArcticWRX
Member#: 3328
1985 GL Wagon 4x4
Lightning Silver
Thumbs up
Woweee!! Our own little cubby hole at NASIOC for the old school types!
<-- (vroom, beepbeep!)
Have you hugged a Subaru today?
ArcticWRX is offline   Reply With Quote
Old 09-17-2003, 11:40 PM   #14
Matt
Allergic to turbos
Member#: 181
2009 Forester
Waves to guy with snow already in NWT.
It was 91F today at my house.
Old 09-20-2003, 05:09 PM   #15
Gremlin
Member#: 30950
Talking
YAY from me too! I now actually have somewhere to post!!
Gremlin is offline   Reply With Quote
Old 09-21-2003, 05:05 PM   #16
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Yay
I'll be happily trolling and posting here. Hail to the old-school scoobies.
Someday my 1989 XT6 will rip the poop out of some WRXs I hope. Someday!
Kevin Thomas is offline   Reply With Quote
Old 09-21-2003, 08:01 PM   #17
Machine Age Victim
Member#: 29961
2008 Honda Element
1975 Triumph Spitfire
wasn't it 4 x 130mm?!?!?
Machine Age Victim is offline   Reply With Quote
Old 10-01-2003, 06:03 PM   #18
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Originally posted by matt in fl
Longbed Brat!
That longbed brat was that long because it avoided massive tax for being a truck. but to be a truck it had to be a certain length... so they stretched the bed
My bobbed lifted brat would look SOO funny next to that... a good 6+ inches higher and 18-24 inches shorter
Flowmastered87GL is offline   Reply With Quote
Old 10-15-2003, 10:42 PM   #19
WRX CHIC
Member#: 35023
2003 Impreza WRX
Sonic Yellow
MY85 Subaru GL hatchback, 4WD
has about 130,000 miles on it
My first car, drove it for about 4 years till i got my rex and now my dad drives it. He just put a 3" exhaust on it with a glasspack as a muffler. doesnt sound bad at all.
has a new paint job about 2-3 years old
anyways...heres the pics (not such a great quality, scanner sucks)
~JEN
WRX CHIC is offline   Reply With Quote
Old 10-16-2003, 07:20 PM   #20
Kevin Thomas
Member#: 110
1989 1989 XT6
Thumbs up Nice
~JEN
Hello JEN,
That's not a bad looking scooby despite the scanner quality. I have no idea why I have a thing for the older, underrated, under-achieving subarus. My wife thinks I'm crazy/nuts. Oh well!
Maybe SubieGal can put an air/water intercooler and turbokit on that old 360 of hers. Now that's something that'll make me
Old 10-31-2003, 11:27 AM   #21
old school
Member#: 22647
2016 Crosstrek
CWP
I guess I named my self appropriately for this forum. hehe. . .
Good to see an old school forum. Hopefuly it will grow a little, attract folks interested in some of the older gen cars who would normally only post to see how to modify their MY04 cars. Maybe this is the bridge we've been wanting forever.
old school is offline   Reply With Quote
Old 11-14-2003, 01:15 PM   #22
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Well I guess I'll be hanging out here now, too. I just picked up a 1986 RX Turbo Sedan yesterday.
Pics coming soon...
Shane -- http://www.warpthree.com
Warp3 is offline   Reply With Quote
Old 11-14-2003, 06:50 PM   #23
techworkseng
Member#: 21604
Default Beater Wagon
It's the ultimate winter-beater, an '84 Turbo with a pushrod 1.8L.
In cab adjustable variable boost controler (11psi).
Bosch blow-off valve
Intercooler with custom heat shield and custom intake piping.
2.5" SS custom downpipe, high-flow cat, and muffler.
RS style fiberglass hoodscoop
5-speed conversion with 3.90 rear diff.
We hope to cage it soon for rally. We're warming up doing the local Winter Autocross Series. In the first event I believe it finished 4th behind a Mazda GTX, an Isuzu Impulse, and a WRX.
See below for more photos.
Any comments?
Keith
techworkseng is offline   Reply With Quote
Old 11-14-2003, 06:50 PM   #24
techworkseng
Member#: 21604
Default Beater Wagon Photo 2
In Action!
Old 11-14-2003, 06:53 PM   #25
techworkseng
Member#: 21604
Default Beater Wagon Photo 3
Under the hood.
Legacy Forum FAQ: WELCOME TO THE LEGACY FORUM, PLEASE READ FIRST. munkis Legacy Forum 1 03-30-2006 08:32 PM
Welcome to the STi Information Forum Nick STi Forum Archive 57 06-03-2003 10:09 PM
Welcome to the Dealership Review Forum Nick Dealership Reviews 1 08-14-2001 01:31 PM
Mixing the old skool with the new skool subies..something no one else has ever dared kevinsUBARU Tri-State Area Forum 3 08-08-2001 08:51 PM
Welcome to the WRX Countdown Forum! Imprezer WRX Forum Archive 1 01-24-2001 07:46 PM
