Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 07-18-2008, 10:03 AM   #76
Silonius
Member#: 104915
04 Focus
Mmmmmmm, dirt
Hey! First time I've ever ventured over to the Old Skool forum.
I just found a couple Subaru Justys for sale in the local Craigslist. The guy says they're front wheel drive but seems like a great old skool commuter Suby. I'm gonna try and find some more info about the Justys and see whats what.
-Seth
Right, here's the link but no pictures Greenville, SC Craigslist Justys
Silonius is offline   Reply With Quote
Old 08-02-2008, 08:48 PM   #77
loyaledan
Member#: 186013
nice to be here
loyaledan is offline   Reply With Quote
Old 08-07-2008, 02:04 AM   #78
blindrummer
Member#: 175155
Default 1985 GL Hatchback
i just purchased a 85 GL hatchback
i will post pics in the morning
i have many questions and hope someone can help out
its the EA81 1.8 over-head valve engine, hitachi carburetor
4WD dual range 4 speed trans
blindrummer is offline   Reply With Quote
Old 08-07-2008, 07:38 AM   #79
dibblejr
Member#: 94070
05 LGT
^^ Welcome to Old School, nice find.
Jay-R
dibblejr is offline   Reply With Quote
Old 08-08-2008, 05:53 AM   #80
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
Lots of pictures please.
Chris N is offline   Reply With Quote
Old 08-09-2008, 04:09 PM   #81
Tallowtree
Member#: 186515
1983 GL
Cosmic Blue
Just joined the Forum. I have a 1984 GL. I have had this little wagon since 1999. I have had very little trouble with it. One water pump about five years ago. I installed a Weber DGV carb and I think that this is a very good modification. The manuals, both Factory and Haynes, don't give much information about the fuel pump relay on these models, except to state that the carb equiped cars don't have them. This is not correct, I know mine does, I tempted fate and invoked the wrath of the little box this week. I won't waste everybody's time but if someone has any information, let me know. What happend is I disconnected the tach and the pump would stop in a few seconds; this tells me that there is a pulse counting relay somewhere, like VW Rabbits, etc. Thanks for allowing me to enter, I hope that I will be able to contribute something to these pages.
Tallowtree is offline   Reply With Quote
Old 08-10-2008, 09:54 AM   #82
blindrummer
Member#: 175155
sorry chris N how do i post pictures
Old 08-14-2008, 05:07 PM   #83
henrypaz
Member#: 158134
1989 Justy Gl 4WD
Tractor Red
Hi-- I am new to the forum, and I drive an old '89 Rusty Justy 4WD GL hatchback that runs pretty good. I did a lot of rust repair on it, some pretty serious on the frame, but got it past the inspector. Will gladly share my "trade-secrets" if any one wants to know how I did it. I need a little help from anyone out there that know where I can find a good used carb for reasonable price. It's a Hitachi DFC328 model. I particularly need the duty-solenoid for one. Thanks on that.
I saw this old post, and wanted to reply for the general edufication of the community. I hope it is helpfull:
Originally Posted by battlecat View Post
I have a 1980 Subaru 4wd wagon, GL, 1600 engine, 4 speed. Over the years I have had many front axle halfshafts replaced. I usually get a mechanic to do it (I notice that I occasionally have axle carrier bearing problems after I do), but now I am interested in doing it myself. I have a factory repair manual that indicates that you have to use a special tool to extract/replace the axle from the carrier (and I suspect none of the mechanics I have employed in the past have not used this tool, and they probably just use a hammer to drive the axle out, thus the damage to the carrier bearings). I have used Autozone axles (which can be poor quality, even though they may carry a lifetime warrantee. I notice they either click or the rubber boots go bad quickly; nevertheless, because the price is right, I may continue to use these unless anybody has a better idea. Thus, I need to be ready to replace the axles frequently). Does anybody have experience in this? Is it truly damaging to the axle bearing to drive out the axle with a hammer? Is so. what are my alternatives? (I doubt I will be able to get hold of one of those special pullers/drivers). Anybody have suggestions about a good source for axles?
Friend--I have done the job you want to do on my '86 GL-10 wagon. I used Subaru supplied re-built axels for about $150 each. They have not given any trouble.
Buy a BIG gear puller (with a pointed screw thing on the end-you turn it and it advances-right?) Take off the two ( or three ) big claw things by removing the bolts. Now replace the claws with pieces of chain that you can bolt to the studs and lug nuts of your hub. Take your time and get it set up right. Turn the screw and push those babies outta there! Of Course you have to get under the car and loosen /remove mounting bolts for the 'control' or 'A' arms, so the axel will have room to come out. Hold up the hub with wire so you don't hurt the brake-line.
Before you put your new axels in, just take some Emory Cloth about 120 grit, and carefully lap the new axel stubs down so the will just slide in the hubs. Work a little on all sides from the end, and keep trying the fit to see how you're doing. You will think you can't, but you can do it in 15-30 minutes per. Before you know it, it will start to go in and you will get so happy! It's easy! I think the only reason its a press fit is to keep you tied to the shop (Subaru shop. )
Good Luck
Last edited by henrypaz; 08-14-2008 at 05:28 PM. Reason: Just to introduce myself. Is that good?
henrypaz is offline   Reply With Quote
Old 09-11-2008, 02:08 AM   #84
ZUKIRU
Member#: 131505
1986 XT DL
Knightrider style...
rubber hammer FTW
ZUKIRU is offline   Reply With Quote
Old 11-15-2008, 01:04 PM   #85
myxtgl
Member#: 194365
Default 1989 XT GL Subaru
Nice to be here. Purchased from my Mom last March her 89 XT GL Subaru. Was her middle age crisis sporty car. Was garage kept and had 18k original miles.
It is in pristine condition inside and out.
myxtgl is offline   Reply With Quote
Old 12-15-2008, 06:03 PM   #86
Tori's Dad
Member#: 197566
09 Forrester
Default Just got here.
My Partner's son has a 87 Loyale with issues, but he is a cook so is good with knives and a grill. Not too good with the tool kit. After a year and a half it's lost power and other issues. Anyway, just got back from Nelson B.C. and helping him do the old Cap, Rotor ,plugs, air filter & fuel filter for a start. His 4wd seems to pop out sometimes, it's push botton and his Haynes manual has very little on it? Any ideas?
Tori's Dad is offline   Reply With Quote
Old 12-15-2008, 10:11 PM   #87
smb1989gl
Member#: 197464
1989 gl wagon
white
Default 1989 gl wagon with Ea82 ohc fi engine
Hey fellow old schoolers, I have an 89 gl wagon that I bought wrecked from a title pawn place near my work for $200. So over about 3 years I have been tinkering around and have finally got it all together and ready for the road. I have done the basics as far as a tune up: plugs, wires, distrib cap & rotor, timing belts. It has 217k on it starts and runs great maybe a bit of smoke when you first crank it up. After running a few minutes such as a trip around the block the check engine light comes on and will reset if shut off for a few mins. I live in the metro Atlanta Georgia area so the old girl still has to go through the old wand up the pipe gig (emissions testing) it actually did fairly well but failed the HC ppm (hydrocarbons) at idle 360/220. The level at 2500 rpm was really great though 59/220 way below alllowed level of 220. So i guess that would be the same as running ritch @ idle. I went to Auto Zone to see if they had a chance of reading the trouble code. I pretty much got the usual "Im sorry sir you want a part for what?" reply.
So if any of you old schoolers out there could give me some advice in which direction I should go in I would be greatly appreciative.
smb1989gl is offline   Reply With Quote
Old 12-24-2008, 06:06 PM   #88
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
Hey folks (especially the n00bs), this stickey is just for saying hi and stuff.
If you have questions about your Old School Subaru, please post them in the
regular forum. I rarely come here to read any of the post and I certainly wont answer any questions here. So post any questions or problems in the general
Old School Forum.
Thanks, have fun and please come again
TurboneX is offline   Reply With Quote
Old 12-27-2008, 05:47 PM   #89
gray
Member#: 198494
just got 1984 brat for $200 cant wate to get to work on it I love those brats
gray is offline   Reply With Quote
Old 12-31-2008, 10:59 PM   #90
CDRSAM
Member#: 198186
I always like the Brat, so much potential a friend of mine had one and it seemed to run forever.
CDRSAM is offline   Reply With Quote
Old 01-13-2009, 03:17 PM   #91
egowing
Member#: 199576
1983 GL 4wd wagon
Green
Default ignition switch
Have an '83 GL 4x4 wagon.......ignition switch on the column is wore out.....key just falls out......barely works to start the vehicle. Any ideas on where I may be able to find a new keyed ignition switch?
Ed
egowing is offline   Reply With Quote
Old 01-13-2009, 03:22 PM   #92
dibblejr
Member#: 94070
05 LGT
Too bad the post is late, I just through out my oem steering wheel, switch and 4 keys about 3 weeks ago while cleaning up my shed.
I may be wrong but maybe another subaru vehicle may fit. You could also always go with electric.
Ed
Old 01-13-2009, 03:26 PM   #93
egowing
Member#: 199576
1983 GL 4wd wagon
Green
Electric? What kind of ignition would that be dibblejr? Keyed? All I have ever dealt with are keyed ignitions.........
Old 01-13-2009, 03:33 PM   #94
dibblejr
Member#: 94070
05 LGT
If you cant find anything you could use a toggle switch and button, or just push button.
I know I have seen generic keyed switches at autozone, napa but not sure how they work.
I have toggle/ PB on my 73 DL but its a race car.
Jay-R
Old 01-13-2009, 03:35 PM   #95
dibblejr
Member#: 94070
05 LGT
Here's an ebay link with a lot of subaru ignition switches
http://shop.ebay.com/items/__subaru-...=p3286.c0.m104
Old 01-13-2009, 05:44 PM   #96
egowing
Member#: 199576
1983 GL 4wd wagon
Green
WOW......lots of great stuff on ebay......but nothing that will fit my application. I will continue the search.....
The Dirty South? Dirtier than Georgia red clay?
Old 01-13-2009, 10:32 PM   #97
dibblejr
Member#: 94070
05 LGT
Pretty much the same, red clay Alabama.
GL with the search, I will keep an eye out.
Jay-R
Old 01-14-2009, 09:19 PM   #98
g gischer
Member#: 200091
Default hi i'm new
does this post count as one of my three posts before i can ask a question?
have a great day! thanks in advance...-gwen
g gischer is offline   Reply With Quote
Old 01-14-2009, 09:30 PM   #99
dibblejr
Member#: 94070
05 LGT
^^ Ask away
Old 01-29-2009, 06:42 PM   #100
egowing
Member#: 199576
1983 GL 4wd wagon
Green
Is there a market for an '81 Brat without a motor?
Legacy Forum FAQ: WELCOME TO THE LEGACY FORUM, PLEASE READ FIRST. munkis Legacy Forum 1 03-30-2006 08:32 PM
Welcome to the STi Information Forum Nick STi Forum Archive 57 06-03-2003 10:09 PM
Welcome to the Dealership Review Forum Nick Dealership Reviews 1 08-14-2001 01:31 PM
Mixing the old skool with the new skool subies..something no one else has ever dared kevinsUBARU Tri-State Area Forum 3 08-08-2001 08:51 PM
Welcome to the WRX Countdown Forum! Imprezer WRX Forum Archive 1 01-24-2001 07:46 PM
