Old 02-17-2001, 07:46 AM   #1
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Post technical details of a 4eat? what is overdrive..
technical details of a 4eat? what is overdrive..bye this i mean there is 4 gears but what is over drive?>
Greg
GregBolby is offline
Old 02-17-2001, 09:58 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Post
over drive is a swith to make the gearshift go to 4th gear. when you are in the high way and going 60 mhp, if you turn it off you will notice that the RPM is higher than usual. if you push that button on or as in Subarus 3rd gear and shift up to "D" that works like over drive.
Toyotas have a push botton over drive.
Subarus one the other hand have something like this
P
R
N
D
3
2
1
when you put it on the "D", you can shift it to "N" and "3" without stepping on the brake.
Subarus don't have push button like Toyotas so they are operated be just simply shifting it to "3" or just leaving it on "D"
hope you get what i'm saying
Good Luck
FuJi K
FuJi K is offline
Old 02-17-2001, 10:42 AM   #3
V6
Member#: 2703
Y2K GC8
Silver forever
Post
So is that the fourth gear is equal to the over drive?
Then is that 4EAT (D,3,2,1) with over drive is equal to 3 speed automatic plus one addition gear for overdrive? (D,S,L)?
V6 is offline
Old 02-17-2001, 01:09 PM   #4
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Post
The reason Subaru doesn't have a button like Toyota is becuase its 4EAT computer is smart enough that if you quickly slam the accelerator down the floor, it will down shift to 3rd gear for more power. Overdrive is in almost all the auto tranny. The last gear is called over drive because it locks torque converter to save gas at high speed. As for the other shift positions, they are for different driving conditions. 3 means it will never shift into 4th gear. It is good in slippray road for better engine braking force. 2 is used to lauch the car in snow or ice for maximum traction. 1 for climb step slops. In normal driving, always put in D position.
Foxbat
Foxbat is offline
Old 02-17-2001, 01:27 PM   #5
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
The 4eat computer isn't smart enough, and it likes to continually destroy the transmission durring swift twisties, I hate the computer, it's stupid yea I do sound like a baby.
WRXwannbe is offline
Old 02-17-2001, 06:23 PM   #6
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Post
By 'smart enough', I mean I never feel the need for that special power button like Toyotas have. Smooth shifting it is not.
Foxbat
Foxbat is offline
Old 02-17-2001, 10:30 PM   #7
V6
Member#: 2703
Y2K GC8
Silver forever
Post
So is that after the 4 then it will "locks the torque converter to save gas at high speed"?
V6 is offline
Old 02-18-2001, 09:24 AM   #8
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Post
That will be after 3rd. 4th is the overdrive and will lock the TC. You know you're in 4th when gas pedal change does not chang engine RPM too much.
Foxbat is offline
Old 02-19-2001, 08:29 AM   #9
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Post
"Overdrive" simply means that 4th gear (or whatever the highest gear is) is OVER a 1:1 ratio.
subarumantoo is offline
Old 02-19-2001, 09:18 AM   #10
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
that's correct, meaning that there are more teeth on the input than the output.
ColinL is offline
HTML code is On
Technical Details of other AWD systems mr_yellow General Community 1 12-22-2006 04:24 PM
In process of painting sideskirts...what is this?? Sputt Interior & Exterior Modification 13 09-19-2005 11:38 AM
Smell in the Cabin of 04 WRX, What is it? shinsain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 08-22-2005 03:45 PM
Some Technical Details of the US 2005 Outback from AutoWeek Jon [in CT] News & Rumors 0 02-27-2004 09:14 AM
('93-'01) Subie of the Week? What is going on? WRX Fan Impreza Forum 6 08-01-2001 01:54 PM
