Old 09-17-2003, 03:00 PM   #1
JDMTEG98
Member#: 38671
2004 WRX STi
World Rally Blue w/ Gold
Default Need some Specs on Wheels for STi
Anyone know if the Off Set for the STi is the Same on the UK wheels. I assume they are since the wheels are same size ETC
This is what I have correct me if I am wrong but should be the exact same for both wheels (i.e. UK STi wheel and USDM BBS wheel)
17 x 7.5 JJ
Tires: 225/45/17
Offset: 53 < ?
5 x 4.00 Inches or 5 x 100mm
JDMTEG98 is offline   Reply With Quote
Old 09-17-2003, 03:09 PM   #2
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
bolt pattern is 5x100 last I checked, besides that it all looks right.
afpdl is offline   Reply With Quote
Old 09-17-2003, 04:24 PM   #3
JDMTEG98
Member#: 38671
2004 WRX STi
Yep your right. Anyone have the Off Set
Old 09-17-2003, 05:07 PM   #4
LimeyWRX
Member#: 15953
04 Impreza WRX STI
Aspen White/Gold w/Stg2
The offset of the Uk's is 53 its stamped on the inside. I'm pretty sure the USDM STI rims are the same. You could always take a wheel off and look on the inside?
Whats up with you selling the UKs so soon?
LimeyWRX
LimeyWRX is offline   Reply With Quote
Old 09-17-2003, 05:35 PM   #5
maengelito
Member#: 35404
2005 Forester XT
LimeyWRX
yep offset of 53 is correct for the usdm bbs wheels
maengelito is offline   Reply With Quote
Old 09-17-2003, 09:54 PM   #6
xraddoc
Member#: 36999
LimeyWRX
Are JDMTEG98's wheels the ones you sold?
Kim
xraddoc is offline   Reply With Quote
I need some specs on 1999 EJ22 BAJAGT Normally Aspirated Powertrain 18 05-31-2007 09:59 AM
SF5 Forester, need some advice on wheels/tyres.. Sambuca Tire & Wheel 2 01-13-2007 07:28 PM
need some input on wheel/tire problem wrxprowler Tire & Wheel 0 07-14-2006 01:49 AM
Need some specs on our driveshaft hanzo918 Transmission (AT/MT) & Driveline 4 08-11-2005 07:04 PM
need some opinions on wheels skyhigh420 Interior & Exterior Modification 12 06-23-2001 02:58 PM
Message Board Statistics All times are GMT -4. The time now is 02:50 PM.
