Old 09-17-2003, 05:25 PM   #1
dpjef
Member#: 18984
2002 Impreza 2.0
dark blue
Default WRX LSD swap
I don't know about the USDM n/a Imprezas, but over here the n/a Imprezas don't have a limited slip rear diff.
Would it be a straight swap from a WRX to my GX ?
(gear ratios between WRX and the GX are different, but the final drive ratio are both 3,900)
dpjef is offline   Reply With Quote
Old 09-18-2003, 09:21 PM   #2
serious
Member#: 22879
Here subaru uses a R160 differentail. If it's the same there then all you would have to do i just swap out the internals and make one or just bolt it in provided the axles are the same. Sometimes they are different.
Brent
serious is offline   Reply With Quote
Old 09-19-2003, 05:50 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Well the USDM WRX has a 3.90 final drive ratio, however the center diff has a 1.1 reduction for the rear requiring a 3.545 rear differential.
To know if they are interchangable, you would need to find out what the final drive ratio is for each car and then what the final drive ratio is on each rear differential. This information can be found in the FSMs.
-Jon
Old 09-19-2003, 06:07 PM   #4
dpjef
Member#: 18984
2002 Impreza 2.0
dark blue
FSM ?
Old 09-20-2003, 06:24 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
FSM = factory service manual
-Jon
03 WRX trans swap to 91 Legacy SS Turbo (Keep LSD?) orpyak Subaru Conversions 6 05-28-2009 11:05 PM
02 WRX 4EAT rear LSD swapped into a 02 Impreza OS 4EAT? Subpar Transmission (AT/MT) & Driveline 9 08-04-2008 03:10 PM
Anyone done a front LSD swap on a WRX? Soontobe Transmission (AT/MT) & Driveline 2 03-05-2004 02:19 PM
WRX LSD swap John*G Transmission (AT/MT) & Driveline 7 12-06-2003 02:05 PM
LSD swap? silverSurfer Legacy Forum 2 07-23-2000 01:22 AM
