Old 09-17-2003, 09:05 PM   #1
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Question wierd sounds when I turn
I started up my car while i was at work yesterday, Pulled out of my spot cranked the wheel and i didn't even hit the gas that hard and when it moved forward I head this strange sound come from the front of the car.
When I moved it sounded like a baseball card on the wheel of a bicycle. whatever it is it doesn't sound good--AT ALL.
Does anyone have an idea of what this is and how much it's going to cost me?
pilfflip is offline   Reply With Quote
Old 09-17-2003, 09:20 PM   #2
Jarvis
Member#: 8267
2010 MB E63
Black on Silver
Sounds like the CV joints to me. I did mine preventatively and I think it ran about $400-600. My boots were cracked and I just got the whole assembly on each side. So, to be clear, that's ~$300/side.
Jim
Jarvis is offline   Reply With Quote
Old 09-18-2003, 12:30 PM   #3
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I have low mileage axles for sale if it's your CV's. Just PM me if you want them.
garface is offline   Reply With Quote
Old 09-18-2003, 05:05 PM   #4
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
Sounds like the cv joints. Replace them yourself for about $50 per side for the whole axle. The job difficulty on a scale of 1-5 is about a 2 as long as everything goes ok. Look under the car and see if the boots are torn. If it's only mildly making noise then you can probably get quite a few miles out of them before they absolutely need replaced. If they are loud or make the car feel as though it's "binding" when turning, I would address it soon.
legacy92ej22t is offline   Reply With Quote
Old 09-21-2003, 11:33 PM   #5
Kohburn
Member#: 43493
99 Legacy GT Limit
I'm having a situation with my 99 2.5GT where the majority of the time its smooth and quiet - but on a rare ocassion when turning hard into a parking spot it'll feel a bit like its binding - for a while i thought it had to do with the differential - but i'm not so sure -- i hate intermittent problems they are impossible to diagnose
Kohburn is offline   Reply With Quote
Old 09-23-2003, 08:37 PM   #6
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
My 95 does it when I turn right, it clicks really loudly. Weird stuff.
BAC5.2 is offline   Reply With Quote
Old 10-14-2003, 10:30 PM   #7
Kohburn
Member#: 43493
99 Legacy GT Limit
boots look fine -
the binding when making sharp turns feeling is becoming more consistent - also have a lot of vibration around 60-80 mph and smooth the rest of the time - was once smooth all the time -
so i am suspect of the outer cv joints more so than a differential issue.. some have suggested the wrong fluid in the differential but are these not sealed units? or is that only the front mid dif on the manual..
also where do you find the axels for 50$ a peice? i've seen em for 4 times that much..
Old 10-14-2003, 11:17 PM   #8
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
IMO if your boots aren't torn then I wouldn't think it's the cv joint,
But stranger things have happened. If you're getting binding in sharp turns but no clicking during normal turning I'd say it's probably your center diff.. When you get severe binding it ruins your tires which may be why you're experiencing the vibration at cruising speed or your alignment may just be off. My wife drives a 98 Forester S and our center diff. is in pretty bad shape. Our tires
are on the outs and now every once and a while it makes a heavy clunk during tight cornering. Talked with a scooby mechanic
about it and he said it's about a $300 fix including labor or $180
if I do it myself. My Legacy turbo gets all my attention though
But I have to address it soon.
I got my axles local so I wouldn't have to pay shipping for the core charge but check out www.cvaxles.com . I think they're like $55 here and everyone that's dealt with them says really good things. They have a lifetime warranty also. Don't buy them from Subaru, they want way to much. You can probably get them for around $50 (after core charge) at your nearest auto parts store.
Old 10-16-2003, 11:02 PM   #9
Kohburn
Member#: 43493
99 Legacy GT Limit
not bad - so whats the fix for the center diff? what part is the 180$ paying for? i did pick up a warrantee so in 3 weeks anything like this will be covered.. 900$ for 2 year warrantee - 300$ center dif fix is step one heh..
Old 10-16-2003, 11:42 PM   #10
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
To be totally honest I'm not totally sure what's included in the $180 package. He said something about a recall at one point and a "kit" that would fix it for $180. I don't know if it's a rebuild or what. (Like I said I haven't seriously tried to address it yet). I figured I would go back and follow up when I decided to address the problem. I think it's a pretty common problem though.
Old 10-17-2003, 05:07 PM   #11
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
Default MORE INFO PLEASE
I'd be really interestedin knowing what exactly is causing this problem everyone is describing. Matches EXACTLY what I've been experiencing in my 99 GT. Please continue posting info... especially if there is a known TSB and/or Dealer fix. It is driving me nuts and I haven't isolated what's happening yet. I've seen this same issue described and posted in all the forums USMB, LegCntrl, Iclub\Legacy, newsgroups etc. etc. but no one has singled out a cause and effective solution. Who will be the first?
snowone is offline   Reply With Quote
Old 10-19-2003, 11:09 PM   #12
Kohburn
Member#: 43493
99 Legacy GT Limit
Default Re: MORE INFO PLEASE
yeah 99 GT
i've been researching and have had only oute cv joints and differential listed as potential problems.. however i am pretty sure its not cv's since the boots are undamaged and the feeling shakes the whole car feeling like it comes from front and rear almost equally maybe even more to the rear..
give me a month till my new warrantee kicks in and maybe i'll find the problem.
Wierd noise when only turning left around 5-20mph vcustoms Brakes, Steering & Suspension 9 03-25-2009 02:59 PM
wierd noise when i turn on my AC? SWCCurry Newbies & FAQs 8 05-26-2008 10:38 AM
wierd sound when i brake White06STI Newbies & FAQs 13 03-09-2006 12:11 PM
wierd sound when ac is on jeff1872t Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-08-2004 07:06 PM
Squeaking sound when engine turns off? AlexGeez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-20-2003 11:07 PM
