Old 09-17-2003, 09:43 PM   #1
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Default Well....Its Running....BUT
Only on 2 Cyl.....and I think the coolant temp sensor is bad...its hard to tell.....Felt good to crank it up....I did a compression test on #1 and only had 90psi......so I will also check the rest of the them tomorrow also...the plugs are a BIZNOTCH to get to on a GC chassis....that sux....Man I was soooooo excited to hear it crank...so I will be doing some mechanic stuff tomorrow...OH Well....It lookes so nice to...I have pics..but just not in the mood to post them..
more later
Bill
Old 09-17-2003, 10:06 PM   #2
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
Donít get discouraged Iím sure its just a couple little problems. Iím curious did you replace the sparkplugs before you put the engine in? Could be as simple as a bad sparkplug.
Good luck if you got the wiring job taken care of I know you can do this!
Can't wait for pics...
AndyM is offline   Reply With Quote
Old 09-17-2003, 10:29 PM   #3
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Yep... had new plugs....new coolant.. Man I am sooooo bummed right now....Beyond belief....thanks for the words of encouragement..tho..
Bill
Old 09-18-2003, 12:17 PM   #4
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Default Well ....Heres the pics
even tho its depressing to do all this work...and the motor is not good...its sure looks nice......I will fix it... the salvage yard has a 90 day warranty on the engine....so I am not to bad off....I guess...Enjoy...
Bill
Old 09-18-2003, 02:33 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yikies...
does your wireing go right over the turbo
hot hot hot!
Old 09-18-2003, 04:59 PM   #6
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
the wiring goes over the AC line...theres about 6 inches of clearance there....I am going to put heat shielding over that one harness...to answer your question...yes...and ...no.......
Bill ( Half boosted)
Old 09-18-2003, 10:17 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Plugs still possible with the EJ20? I forgot that they install at 90 degrees to the head, instead of at an angle.
Your car looks awesome though.
-Jon
Old 09-19-2003, 12:27 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Hi, I'm still having troubles with my A/C not working as well as my tach. Is yours? The temp unit is off in mine too due to the different resistance in the new and old units (they aren't compatible). also you probably won't know this but is your speed sensor working?
Take it easy, micah
the temp sensor is just different resistance so I'm bolting in an aftermarket gauge.
Don't get down on yourself. Just think of what it'll be like when you're done.
Old 09-19-2003, 11:20 AM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Micah, did you retain your mechanical speed sensor or did you convert it to electronic?
-Jon
Old 09-19-2003, 11:28 AM   #10
Homemade WRX
Member#: 33782
96 bastard child
I'm still mechanical but am trying to hook up the siganl coming off of the gauge cluster to the ECU.
Take it easy, Micah
Old 09-19-2003, 02:36 PM   #11
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
OK..I am using the RS tranny that had the speed sensor already....Tach works....no Speedo.....my factory temp gauge goes thru the roof....but my Autometer saids its still safe...Also had a meat themo in the coolant tank....read within 5 degrees of each other...My fans don't come on like they should..( I am thinking coolant sensor which is on order.)...also need to replace my thermo...just in case...my fuel gauge doesn't work....(Have to check the float to see if its hung up....
Bill
Old 09-19-2003, 02:45 PM   #12
AndyM
Member#: 3219
WR Blue Pearl
Hey man the wiring job looks great totally profeshÖI guess you have to go through the pain-in-the-ass of taking the motor out, but hey at least you donít have to go re-do the wiring. You never know you might get a engine with lower miles on it. Nice wiring job, the loom make it look factory.
:Thumbs Up:
Old 09-20-2003, 09:03 AM   #13
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
:Thumbs Up:
Thanks....ah...no biggie to take the motor out and fix it....(not trying to sound like I am a know it all)....but I figure the hardest part is over with....for the most part....the wiring....
Appreciate the positive feedback....but you are definately right...Thanks again..
Bill
Old 09-20-2003, 05:09 PM   #14
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
Thumbs up
Good Job.
Good luck getting the project finished up!
WRSport is offline   Reply With Quote
Old 09-20-2003, 05:28 PM   #15
Homemade WRX
Member#: 33782
96 bastard child
Don't worry too much about the temp sensor. Mine pegs the top temp as soon as the car turns on but have tested the actual temp with a laser temp gun and it is running at about 180-185-ish(after driving for a while).
Take it easy, Micah
Old 09-20-2003, 05:41 PM   #16
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Did you paint the Subaru stars on the intercooler or is that something else(dirt, water)?
How much time do you have left on your 90 day warranty? I'm assuming it's from time of purchase and not install.
So how hard are the spark plugs to get to? I was looking at mine and it looks pretty tight. I hope I don't have to pull the engine to change plugs.
garface is offline   Reply With Quote
Old 09-22-2003, 05:19 PM   #17
garface
Member#: 1581
MY00 RS/STi7
Oh and your BOV is going to destroy the insulation under your hood. Even if you point it to the side.
Old 09-27-2003, 07:24 PM   #18
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
I made a stencil..and painted it on the I/C....looks OK>..it should have been better...
about 1.5 monthes left....which I am good to go...
They are pretty much a pain....You will definately need a good swival for your socket rachet....the coil packs are a pain to get to also...
Bill
Old 09-27-2003, 08:43 PM   #19
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Bill
You forgot to ground one of the wires on the stock engine pig tail. The brown connector that you disconnected from the stock engine, you have to ground out the black/red wire. There are 4 thick ground wires on the bottom row of the connector. This ground is for the fuel gauge and coolant temp gauge.
On a side note, have you had the timing belt removed or changed ? Sounds like the cam timing is off.
Ver.III is offline   Reply With Quote
Old 09-27-2003, 10:09 PM   #20
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
hmmmmm...I will check that tomorrow....Good Advice for sure....
The car the engine came out of was rolled 4 times....and like an idiot..I trusted the bone yard for them saying its good to go...(note to self....ALWAYS check it Yourself)...so I think its got bent valves...I know..I know...I should have opened it up my self....and check the timing and everything...OH well...Thanks for that tip...I thought I grounded everything but maybe not...Coooooo...Thanks agian...
Old 09-29-2003, 11:41 AM   #21
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Well my car comes to the dealership tomorrow.....talking to the some of the techs...my motor could be just out of time buy a tooth or two....will know or later....hopefully thats all it is...man that would be sweeeeeet.....but I ordered all the other stuff just in case....
Bill
Old 09-30-2003, 01:08 PM   #22
Homemade WRX
Member#: 33782
96 bastard child
better to be safe than sorry. I hope that's all that's wrong with the engine.
Well its not a Subaru...but it has some 13inch wide JDM wheels on it... IMPORTIMAGE Member's Car Gallery 93 11-09-2006 03:46 PM
It was a good run but its time to move on... NWWagon North West Impreza Club Forum -- NWIC 1 08-13-2005 11:10 PM
Name my new BITCH!.....well its really a boy ..but... Remy E. LeBeau Off-Topic 29 05-31-2005 11:02 PM
Well its not a car, but its fast 00 TL1000R SubeSTIle Private Vehicle 'For Sale' Classifieds 5 02-27-2005 01:34 PM
well its white and i am not sure i don't hate it bill harvey New England Impreza Club Forum -- NESIC 14 05-23-2000 09:54 PM
