Old 09-18-2003, 05:02 AM   #1
Daemonic
Member#: 43695
Default MAF tricks?
ok, despite all the feelings about the usfullness in a ram tube and CAI, my friend and i have one installed for the most part... but the MAF is getting in the way. Is there any way to bypass it? the car sounds awesome with only the aluminum tube and filter (no resonators or sensor/plastic tube to get in the way)
There was a trick for civics where you just put a resistor in the plug to keep the ecu thinking its getting data from the sensor.
Is there a similar trick for a 99 Legacy GT? or is there a better way?
Daemonic is offline   Reply With Quote
Old 09-18-2003, 08:50 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Unplug your maf = car doesn't run above 3-4000 rpm and runs super crappy.
The MAF sensor is probably one of the most important sensors on your car in terms of providing feedback to the ECU to control air/fuel mixture. Only way to get rid of MAF sensor is to replace it with a MAP based system......and I don't think you want to do that.....
Legacy777 is offline   Reply With Quote
Old 09-18-2003, 04:34 PM   #3
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
how about these MAF sensor adaptes that work for CAI's like the one below
NiTRoN is offline   Reply With Quote
Old 09-18-2003, 04:55 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Civic owners actually disable the MAF? I thought I heard everything.
Wouldnt that be like disabling the brakes so they wouldnt make you slower?
Old 09-18-2003, 05:01 PM   #5
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Brake pad drag is a biatch! I like to spray my rotors with grease to lessen the drag.
And I also Armor-All my tire treads. And my tires are pumped up to 60 psi.
Nuthin's worse than having those pesky sensors "get in the way" of the airflow.
But my Tornado Fuel Saver works wonders!
-Brian
KD7000 is offline   Reply With Quote
Old 09-18-2003, 05:40 PM   #6
Legacy777
Member#: 4800
This allows for the fitment of an open style intake....which I think the original poster is installing.....so in theory.....he should already have one of these.
Old 09-19-2003, 01:54 AM   #7
Daemonic
Member#: 43695
Default LOL
[email protected] posts...
yeah, we have one.... but the sensor tube section makes the whole assembly about 4 or 5 inches too long...
we thought about trying to remove the sensor from the tube peice, and stick it in one of the opening in the ram tube... but it looks like its a sealed unit...
and about the MAP conversion, why wouldnt we want to do it? is it similar to speed density conversion? or is that EXACTLY what it is? LoL
im not too worried about the sensor obstructing airflow so much as the peice makes everything fit rather akwardly and without the filter (makes me nervous too, as it is getting colder and wetter out).
Old 09-19-2003, 02:02 AM   #8
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Default Re: LOL
are you running no air filter? that is bad, very very very bad. ifyou drive next to a corn field a corn husk could get sucked into your motor, or even a bird.
dont take pills and then drink beer.
subiekid is offline   Reply With Quote
Old 09-19-2003, 08:45 AM   #9
Legacy777
Member#: 4800
I haven't necessarily seen a "conversion" kit for MAF to MAP. Usually it involves a new ECU...
Old 09-19-2003, 07:54 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
Issue is that the opening is calibrated. The sensor measures how much air is passing over a small section. The tuning of the ECU takes into account the size of the tube around it. If you moved the sensor to a larger tube the sensor would be reading LESS air than whats entering the engine. If you put the sensor in a larger tube it would be reading MORE air.
If you still want to, does anyone remember when alot of people kept getting air flow meter failures and someone found the part number for the sensor itself, instead of purchasing the entire tube?
Old 09-19-2003, 11:10 PM   #11
Daemonic
Member#: 43695
Default corn?
well the MAF does have a screen on it which will block out large things (like ears of corn? in Colorado? hmm..) but yeah, i know its bad... which is why i need to get the MAF assembly out of the way so i CAN put the filter on
and about the tube being too big... the ram tube im using is actually the same size as the rest of the intake assembly... so no worries there
Old 09-20-2003, 12:13 AM   #12
subiekid
Member#: 25516
hahahhahahhahahhahahahaha. a bird at 80 miles an hour would wipe that screen out.
ya know even some grains of sand could have deadly effects on a motor. just think of that when you are driving behind a gravel truck.
that cool sound is gona cost you your motor. why dont you just waint and do it the right way.
what kinda of intake are you trying to use anyways?
Old 09-20-2003, 01:21 AM   #13
Daemonic
Member#: 43695
Default ???
a bird at 80mph is gonna fly under the car, make an upwards 90 degree turn, past all the belts and fan, make another 90 degree turn, and find its way to the 3 inch tube on the passenger side of the car all while still going 80 mph... DAMN! thats some bird....
but anyway, this is all besides the point.... im trying to figure out how to put the filter ON....
i dont mind having the MAF on if i can make the assembly fit somehow... i was just hoping someone had an idea
the filter is just a cone air filter that fits on the end of any 3 inch tube...
Old 09-20-2003, 04:52 AM   #14
noahr
Member#: 15434
98 legacy gt
caucasian
take a picture for us if you can. that should lessen the amount of random comments. come on y'all, he's posting in the legacy forum. yeah he brought up a civic, but there are few and far between legacy owners out there. give him a little love
anyway, the maf gets feedback and loses horsepower in everything but wide open throttle when you get rid of the box on top of the throttle body and the intake tube. you can easily replace all of the crap before the maf with a cone filter using the previously shown adapter and gain the most power, and still get the great sound. the intake produces a sort of "hum" sound with the factory intake tube that has been talked about much in the past. it is interesting that AEM now sells an intake that produces a hum and produces more hp that their previous top of the line model. in other words, replace the intake box and snorkus before the maf, and keep the rest. no check engine lights this way.
i think the trick you are talking about tells the maf that is it getting wide open throttle airflow all the time and this tells the ecu to fire the injectors accoordingly, giving the engine full fuel throughout the powerband. this might not be as noticable on a 1.6 liter motor but you will notice horrible fuel economy on a 2.5 liter not to mention very little power gains over the previously described method. the maf is there for a reason. learn to love it. wrx's have them now, and have had them anyways.
any questions, let me know.
-noah
noahr is offline   Reply With Quote
Old 09-20-2003, 07:32 AM   #15
Z1 Performance
Member#: 9327
I think what you'll find in the end is that the stock intake is really the best design for these cars..especially on a 99 spec car which is known for its notoriously weak MAF. If you want, fit a simple cone K&N with one of the MAF adapters above, and call it a day. You have to be very careful with placement of the MAF in the overall intake design, as the pipe diamter will alter the readings it sends back to the ecu.
As for doing a MAP conversion (MAP= Speed Density), it is possible with an aftermarket ecu but you are talking quite a little investment in time and parts.
I have never heard of people using a resistor in the MAP (Hondas are Speed Density) - that is the most retarded thing I think I have ever heard of!!! Something like a SAFC is the proper way to alter the MAF singal, as at least you can make it rpm and TPS dependant....a resistor is going to be there all the time, unless you start wiring in a whole mess of resistors....
Z1 Performance is offline   Reply With Quote
Old 09-20-2003, 06:31 PM   #16
Daemonic
Member#: 43695
(i'll try and have pictures soon)
yeah, my feelings about the resistor are the same...
i got rid of the the stock air box(2 resinators), and snorkle peice(1 resinator) and it sounded better and felt better too... i guess the real problem is that the ram tub was never designed for this car... but as money is a bit tight at the moment, i was hoping i could get it to work... right now i have the tube out, and just using the snorkle from the throttle body to the MAF to the filter.. doesnt sound the same... but atleast its safer that running no filter
and as for the stock intake setup being the best... you ever look in to that little assembly in the fender? it goes from an oval 3" x 1" opening, to a 1" opening, to a box, with another 1" opening, which changes to a 3" tub that connects to the filter assembly... that has got to be the most restrictive setup i have ever seen...
anyway... if i can remove the sensor and pop it in the ram tube, that would do just fine... the ram tube is a 3" opening just like the tube the sensor sits in... it shouldnt be a problem
one other question while you all try to decipher my ramblings above =P
anyone know what "bank 1 fuel trim" would be refering to?
MAF Excellent MAF 02-07 MAF $100 Shipped jdmstuff Engine/Power/Exhaust 3 02-12-2007 10:41 AM
GP Moto MAF, Perrin MAF, or Samco MAF hose? dpk777 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-13-2005 05:17 AM
Larger diameter intakes (to trick MAF sensor) Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 11-05-2003 11:39 AM
MAF and MOD MAF on UTEC logs Zackbo Engine Management & Tuning 1 10-28-2003 09:51 AM
Need DIY Cone-Air intake "prop-up-device" tips for MAF EJ18 (or any MAF car) Kostamojen Normally Aspirated Powertrain 24 04-11-2002 03:00 PM
