Old 09-18-2003, 01:23 PM   #1
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default Rear Brake Upgrade...DONE!!!
...and it is sweet!!!
In the front, WRX 4-pot with DBA 295mm vented-slotted rotors cadmium coated grey!
In the back, H6 upgrade provided by SUBYSOUTH (thanks SUBYSOUTH for the great deal!!!) 1-pot with DBA 290mm vented-slotted rotors cadmium coated grey!
I didn't paint the calipers, because I like the look of grey rotors and calipers complementing the gunmetal LE37K!
...but I need to know of what pad I should use to replace the stock Subaru OEM pads.
SUBYSOUTH- which pads for the rear are you using??? or which pad shoud I be looking for???
I need a front set and a rear set...before and after pics coming soon!!!
I want the pads to bite and not fade...in particular at low to mild speeds20-30 mph to 60-80mph...street pad not racing pad
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 09-18-2003, 01:40 PM   #2
SUBE555
Member#: 24043
2005 Legacy GT Sedan
Could always look into ceramic pads, little dust and screeching but good overall heat range and bite. I run Tire Rack's Akebono ProACT ceramics on my stock calipers w/ SS lines and it works great for AutoX and high-speed handling. You might want to check out what Carbotech has though finding the rear pads might be a little more of a challenge, just not for sure on that. Look to see if TR carries the ProACT's for a late model OB.
SUBE555 is offline   Reply With Quote
Old 09-18-2003, 02:24 PM   #3
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default GRAT-SEE
SUBE555...I'll check out tirerack!
CRAZY KEN
Old 09-18-2003, 02:34 PM   #4
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
aren't you selling your car, Ken?
monovich is offline   Reply With Quote
Old 09-19-2003, 07:48 AM   #5
etam
Member#: 439
www
Hey Ken, finally got the rear vented rotors? The rear pad is same as newer style rear 1pot caliper which starts from 99? RS but for sure same as WRX one.
How do you like them? less brake dive, right?
etam is offline   Reply With Quote
Old 09-20-2003, 12:58 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The H6 rotors are just larger, they're not vented. As far as I know the only vented rotors are the 1st gen Legacy turbo rotors (same size as stock BD/BG 2.5GT rear, but vented rather than solid) and then whatever expensive, exotic STi stuff is available now.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 09-20-2003, 10:25 AM   #7
etam
Member#: 439
www
Pat, actually, Ken meant to say H6 radial sized rear rotors (290x18).. technically, this is a JDM B4 rear brake setup.
http://members.rogers.com/manual/rear_vented_1pot.jpg
those are just red rust paint.. but now covered with brake dust...
Old 09-20-2003, 02:21 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Oops, my bad! I guess if I had actually read what he wrote in his original post I would have seen you were right.
Pat
Old 09-20-2003, 03:29 PM   #9
etam
Member#: 439
www
this is a secret brake weapon by subysouth! just keep it within the Leg club!
Old 09-22-2003, 12:09 PM   #10
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Sounds great Ken!
Yep the setup Ken has got is a rare bird indeed.
I sent you back a PM on the brake pad question. I am using the oem pads currently. Like I said in the email Legacy777 and I had both done the math on this setup recently and the bias adjustment of this setup on a BD-BG Legacy GTs is nigh on perfect. If you do the math you will find that the 4pots using the 294mm rotor output nearly indentical torque to the stock Legacy GT 2pots with the 277mm front rotors. This is due to larger piston size in the 2pots balanced against the larger rotor with the 4pots. The rear upgrade increases rear torque ~10% thereby shifting bias slightly rearward for more balanced braking. So my thoughts are to use identical compounds front and rear to start with as the setup is inherently well-balanced. Consider oem or less expensive off-the-shelf products if fade is not a prob and you want low noise/dust. If you want performance pads, there are a lot of great pads out there. DBASteve said they had done some pretty extensive testing and the Hawk pads faired really well.
On a side note, Steve's(monovich) 4/2 pot setup shares this same exact bias setup as well, because the rear single pots Kens has and the STi(non-Brembo) 2pots have the same piston diameter.
I am really glad to hear you got the rotors you wanted from DBA. They should be a perfect match for the fronts.
ss
subysouth is offline   Reply With Quote
Old 09-22-2003, 09:32 PM   #11
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Sort of on that note of doing all those calcs.
I finally got around to doing all my brake work. Swapped the MC, and proportioning valve, & installed an MRT brake booster brace.
Initial results are very good. Pedal travel definitely decreased, and the overal braking of the car does feel more balanced out. I need to do some more agressive braking tests. Hopefully will be able to do that this weekend, and post a more detailed post in the brake & susp forum.
Just a quick note on the MRT brake booster bracket. That f@#kin thing is the biggest pain in the arse to install. I had to drill out one of the holes, so I could get all the bolts in. Then one of the bolts was stripped on the end due to all the monkeying around. I finally got it in. I spent more time on the brake booster bracket then I did on the MC & prop valve combined. However I measured the booster/MC movement without & with the brace.
Without the brace the assembly moved ~0.0050"
With the brace the assembly moved ~0.0025"
Legacy777 is offline   Reply With Quote
Old 09-22-2003, 09:52 PM   #12
etam
Member#: 439
www
Hmm.. I guess if I don't go to track day.. maybe I should go back to stock front brake! and I can pick up cheap wrx wheels everywhere! but having Subaru letter on the brake is so bling! (even covered with brake dust)
Old 09-23-2003, 09:32 AM   #13
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Dont do it etam, the 4pot upgrade brings more to the table than just the bling factor. Remember the vaunted Stoptech kit DROPS torque output 10% versus the stock WRX 2pot fronts, and this is a good thing because it improves front to rear brake bias. That larger rotor increases the margin of safety against pad fade and the feel and uptake are improved as well. Getting to the 294mm front rotor has been first on my brake upgrade agenda on both of my Legacys. I think that 294mm rotor is a big help in heat dissipation on even a quickly street-driven Legacy. Now that we know a lot more about the inherent torque these setups put out, factoring in a good rear choice to balance bias is like icing on the cake. Your 4pot front + B4/GT-B rear is(like Ken's) a excellent braking solution for the BD/G Legacys.
If youve got them I would keep them. Only time I would take them off would be to swap them to your next Subie.
ss
Old 09-23-2003, 09:38 AM   #14
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Sounds good Josh. We had a pretty spirited bias discussion a week or so ago in the Brakes forum, we missed your input. I sent a guy back to your bias thread for your .xls file on the torque calcs and the page was a no-show. But we got it sorted.
Glad to hear your mods are working.
ss
Old 09-23-2003, 06:02 PM   #15
Legacy777
Member#: 4800
ss
You got the link to thread?
I've been re-organizing my server and such, so file structure has changed. I thought I changed the links.....but I must have missed that one.
Old 09-23-2003, 06:43 PM   #16
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Here it tis:
http://forums.nasioc.com/forums/show...hreadid=415361
Sorry for the brief hijack Ken.
ss
Old 09-24-2003, 09:06 AM   #17
Legacy777
Member#: 4800
Here it tis:
ss
tanka.....
Old 09-24-2003, 01:09 PM   #18
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default SO...
...As per subysouth's recommendation, I should get front brake pads from a '96 Nissan 300ZX and rear pads from a '02+ WRX...wierd ayyy! He recommends stock pads, but I have stock pads already and would like to see the difference of a more aggressive pad. Any recommendations??? Somethings that bites and doesn't fade at low and mid range speeds (city/HWY driving)...25mph-80mph!
Thanks,
CRAZY KEN
Old 09-25-2003, 12:32 PM   #19
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Ken - Do you have rear brake parts you are getting rid of?
I am trying to do a rear disc conversion on my Impreza L that currently has drum brakes. If you have anything you would be willing to get rid of please let me know.
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 09-25-2003, 05:34 PM   #20
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default MY992.5GT
Yes sir, I still have it!!!
How much do you want for it?
CRAZY KEN
Old 09-25-2003, 06:02 PM   #21
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
you guys have problems with the DBA rotors making a clanking noise? a local wrx has them on the front and they make a clanking noise and its really anoying.
subiekid is offline   Reply With Quote
Old 09-25-2003, 06:31 PM   #22
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default clunking!
subekid: no clunking noise here... I love my dba slotted rotors and 4-pot! More so with the matching rear dba, vented and slotted rotors.
I just ordered front brake pads for a '96 nissan 300zx turbo and rear brake pads for a 2002 subaru wrx...
Do i also need to get these???
4 Pot Brakepad Hardware Kit
STi 4 Piston Brake Clips
STi 4 Pot Slide Pins
OEM Brakepad Hardware Kit
'02+ RS And WRX Rear
BTW, subysouth, my rear brake kit i bought from you doesn't have any hardware...is this a big concern???
CRAZY KEN
Old 09-25-2003, 07:34 PM   #23
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Great news Ken.
What parts did you take off to do the conversion. What parts can you get rid of?
Brad
Old 09-26-2003, 12:00 AM   #24
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Ken your 4pots should have the cross-shaped parts and the pins. The plate-looking things are shims which snap to the back of the pads and can reduce noise(squeal) if you are having that prob.
The rear kit I sold you should have also have come with both the pad clips(they are snapped into the caliper brackets) and the shims(they are snapped onto the back of the pads.) If not PM me and I will see if I can locate them here.
ss
Old 09-26-2003, 07:43 AM   #25
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default oh shiatzu...
...no hardware...ss...does that mean i am damaging my rear brakes, cause I don't got those clips or shims! I did notice a couple of times when i am coming to a stop that the rear brakes moaned. Well when I get my new pads...I'll installed the rear brake hardware and rear surface the rotors as well!
CRAZY KEN
FS - MD: - H6 / DBA rear brake upgrade & 04 WRX rear brakes MD04WRX Suspension/Brakes/Handling 10 03-20-2009 03:46 PM
Has anyone done the Legacy Turbo Rear Brake Upgrade on their WRX? scooby888 Brakes, Steering & Suspension 2 05-10-2007 03:17 PM
First stage brake upgrade done mdex Brakes, Steering & Suspension 2 05-30-2003 06:09 PM
Rear Brake upgrade done. tselway Forester Forum 6 09-03-2002 09:40 AM
Front Brake upgrade done. tselway Forester Forum 19 08-30-2002 12:14 PM
