#1 |
Member#: 6752
I know its possible, I just don't want to have to remove my dash. I'm trying to remove the cluster on my 97 GT so I can pull the airbag light...cause my car needs to be inspected. Any other ideas for getting the airbag light to turn off? Am I correct in thinking that the 97 is OBDII so it has a electronic speedo?, not that wire thing that plugs into the back of the speedo? Anyways, I pulled the gauge bezel off, and but the cluster itself doesn't seem to pull far enough out that one can get to the electrical connectors on the back, so I can remove the cluster to get to the airbag light. On my 91 legacy turbo, one could reach around behind the cluster and pull the electrical connectors, then if you gave the whole cluster a good yank, the speedo connector would come undone. I'm at a loss here, as I have been driving for a couple weeks with no inspection, and really need to fix this light so I can get it inspected. Any ideas?
thanks Micum
#2 |
Member#: 25516
NWIC
Vehicle:1995 Legacy TURBO!!! EJ22T/TEC3 & 06 MCS |
is your air bag popped? if so you should replace it. and i thougth messing around with that stuff was a federal crime? or maybe its just selling a car with a popped/faulty air bag. ah yes its a 10k fine and prison time.
you can take the cluster out, its easy 1. take out 2 screws on bottom ( close to where your knees are) 2. take 2 screws out from top ( above where spedo is) 3. yank. i think thats it. cant remember to well. if you yank it and have not gotten all the scews and bust something its not my fault |
#3 |
Member#: 6752
Federal crime shmedral crime...I spit upon the federal goverment and their capitalist running dog lackey pigs.
As for you subiekid, I'm a gonna sit on my drivers seat, put my feet up on the dashboard, either side of the instrument cluster, grab it will both hands, and pull, and push with my legs. And then i'm gooing to sue you when I break it! No...its been one of those days... I already pulled the bezel around the cluster and then took the mounting screws off from the cluster. It just seems like there are electrical connectors holding it in, that I can't reach around the cluster to disconnect. So just so I make sure I've got this right, once you pull the bezel, then undo the four screws, you can just pull/yank the whole cluster out? Without undoing any electrical connectors first? Pulling the cluster will undo the electrical connectors without breaking them? Will I be able to reattach those connectors in the same manner, reversed? ie, pushing the cluster back in hard? thanks so much... Micum |
#4 |
Member#: 6752
ne1? Bueller? Anyone?
thanks micum |
#5 |
Member#: 1353
Vehicle:2001 Impreza 2.5RS Silver |
It's been awhile, but it seems to me that you can't get it very far out without disconnecting the electrical connections. You have to pull it pretty firmly out from the topside, with the steering wheel tilted down, and pull the connectors that you can reach, which will give you a little more room to reach the others. That's just from old, rusty memory though.
Rich |
#6 |
Member#: 19681
RMIC
Vehicle:1998 Legacy Wagon GT Green |
I've only pulled the cluster out of my '91, not my '98, so I can't help you there.
BUT.. it is only illegal to modify SOMEONE ELSE'S airbag system. You can screw yours up all you want to, and it is perfectly LEGAL. But you CANNOT have someone else do it. Paying someone to modify the airbag system is VERY ILLEGAL. So have at it! I know I'm going to be pulling my steering wheel off after I get my '91's Momo wheel recovered. ![]() |
#7 |
Member#: 6752
Ok...I got it. It seems that you can't pull it out very far, but if you pull from the top, tilting the top towards you and keeping the bottom of the cluster pushed inwards...it will come out far enough so I think one can disconnect the connectors. I was able to just reach around after doing that and pull out the airbag bulb, not even too hard to find it.
Has anyone tried modifying their display so the speedo, tach, fuel, and temp gauges show up red instead of green? Or any other colour? I was assuming their is probably a green coating on the backside of the gauge faces...and that maybe their are condoms on the bulbs too, maybe not. I figure you'd have to remove the green coating and then could either apply a red one, or use condoms, or both. Anyone done it? Thanks all Micum |
#8 | |
Member#: 5034
NWIC
Vehicle:2004 Money Pit silverish-mud |
-E |
#9 |
Member#: 1353
The lamps for the cluster have green condoms. Not sure about tint of lense or background.
Rich |
#10 |
Member#: 25516
NWIC
heehehhehe.... i forgot to tell you to tilt it so you could unplug the electical conectors. my bad
its been over a year since i had mine out as far as the air bag light, i thought that it was in a group of other lights. so like the cel, airbag, at oil temp would not work. maybe i am wrong. i have some pics of the damn thing some place. |
#11 |
Member#: 25516
NWIC
also, you can get the condoms at most auto parts store and radio shack. blue looks the best, i tried red condoms and it looked like poo. but with blue condoms its still got a greenish tint.
and you can just buy new bulbs from radio shack for like a dollar for 2 and then insert them into the old plastic housings instead of paying 4 bucks for one bulb at the dealership. |
#12 |
Member#: 7518
NESIC
Vehicle:1994 Legacy SS Aegean Blue Metallic |
just a thought, i searched the vt dmv website for simialr information, but here is the information on airbags from the mass site. good luck:
The airbag light is on in my vehicle, am I going to fail inspection? No, airbags are not part of the state inspection. We do, however, recommend that you have your vehicle checked if the airbag light is on. For more information about airbags and airbag safety, CLICK HERE. http://www.state.ma.us/rmv/inspect/question.htm call the dmv and ask them. i would think that it is not a required system. i just got my legacy inspected with an abs light on, same deal, its not a required system. they didnt even tell me to get it looked at GOOD LUCK |
| Thread Tools | |
| Display Modes | |
| WTB: 04 sti gauge cluster, and possibly jdm lights | L80Killa87 | Private 'Wanted' Classifieds | 1 | 08-09-2006 08:36 AM |
| CEL From Removing Gauge Cluster? | spoolinsuby | Electrical & Lighting | 3 | 01-30-2005 01:35 AM |
| gauge cluster swap - wrx -> 2001 porsche boxster - possible? | maaw | Interior & Exterior Modification | 1 | 02-21-2004 03:01 PM |
| Removing gauge cluster reset odometer? | beta | Electrical & Lighting | 2 | 11-29-2003 07:59 PM |
| Is it possible to install 98+ gauge cluster on a pre 97 impreza?? >>> | KaZ | General Forum Archive | 0 | 02-26-2001 09:35 PM |
