Old 09-18-2003, 08:44 PM   #1
04subaru
Member#: 41539
04' Impreza Wrx
Question 2004 wrx turn signal bulb
Can anyone tell me what the bulb number is for the turn signal bulbs on the 04, im in the process of changing them all to piaa bulbs. The low beams are h1's, the high beams are 9005 and the parking light bulb is a 168 bulb. I cant find the turn signls anywhere not even the owners manuel! so can someone help!? thanx!
04subaru is offline   Reply With Quote
Old 09-20-2003, 02:52 AM   #2
FryRice
Member#: 38402
2004 WRX~vf34 SOLD
EVO MR
The front and rear turn signal light are the same so they are 7440 12v-21w
FYI PIAA does not make them in orange (unless you want to get pull over by cops ) I got B1 Hybrid
FryRice is offline   Reply With Quote
Old 10-03-2003, 05:36 AM   #3
NateSD
Member#: 44585
2004 WRX
Found out this week that the amber blinker bulbs are new bulbs this year so they are a b!tch to find. I believe that the number for them is 3184. I would go and check, but it is dark out now.
NateSD is offline   Reply With Quote
Old 10-05-2003, 03:01 PM   #4
mjones
Member#: 6901
2004 WRX Wagen
WR Blue
Originally posted by FryRice
...FYI PIAA does not make them in orange (unless you want to get pull over by cops)...
From the CA vehicle code:
25950. This section applies to the color of lamps and to any
reflector exhibiting or reflecting perceptible light of 0.05 candela
or more per foot-candle of incident illumination. Unless provided
otherwise, the color of lamps and reflectors upon a vehicle shall be
as follows:
(a) The emitted light from all lamps and the reflected light from
all reflectors, visible from in front of a vehicle, shall be white or
yellow, except as follows:
24953. (a) Any turn signal system used to give a signal of
intention to turn right or left shall project a flashing white or
amber light visible to the front and a flashing red or amber light
visible to the rear.
(b) Side-mounted turn signal lamps projecting a flashing amber
light to either side may be used to supplement the front and rear
turn signals. Side-mounted turn signal lamps mounted to the rear of
the center of the vehicle may project a flashing red light no part of
which shall be visible from the front.
mjones is offline   Reply With Quote
2002 WRX turn signal bulbs. Impr3zy0u Electrical & Lighting 0 03-01-2006 04:00 PM
'04 WRX turn signal bulb part number? spooledwrx Interior & Exterior Modification 4 12-01-2005 03:47 PM
04 WRX Turn Signal Bulbs ?? antidote11 Interior & Exterior Modification 10 08-07-2004 01:07 PM
WRX turn signal bulbs??? STEVESblueWRX Newbies & FAQs 2 01-03-2002 10:34 PM
('93-'01) WRX turn signal bulb size?????? BkylnWReX Impreza Forum 0 06-02-2001 06:19 PM
