#1 |
Member#: 13793
Vehicle:2007 specB, 03 Ram '92 SVX-5 speed |
Does the EJ22T use hydraulic lifters or mechanical? I'm looking at modifying my EG33 which uses hydraulic lifters and want to know what I might be able to easily adapt to work.
Thanks, Todd
#2 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
Yes, it does use hydrolic units and new units are 17$ each from 1stsubaruparts
#3 |
Member#: 13793
I'm actually looking to convert to mechanical lifters and a light weight retainer, higher spring force valvetrain to get some more revs out of the beast. I was hoping the EJ22T was mechanical. I've got some dimensions on WRX stuff and I'll play with those numbers and my extra EG33 this weekend.
Todd |
#4 |
Member#: 15543
Its possible, the ej22 and ej25 became mechanical later in years. Im pretty sure that the NA EJ22 hydros and the Turbo EJ22 are the same.
| Thread Tools | |
| Display Modes | |
| Crane Cams Chevrolet Big Block Cam, Lifter and Spring Set | VKInnovations | Non-Subaru Stuff | 0 | 02-13-2010 11:37 PM |
| 99 legacy 2.5l dohc cam lifters | suddenthomas | Normally Aspirated Powertrain | 3 | 12-30-2009 11:41 PM |
| EJ20G vs. EJ22T Cam & Crank Sensor Question | BoostAddictPL | Pre-2002 Factory Turbo Powertrain | 2 | 08-01-2007 06:24 PM |
| Future EJ22t Engine Swapping Question | ejicon | Normally Aspirated with bolt-on Forced Induction Powertrain | 11 | 05-20-2002 10:37 PM |
| solid lifters question | suberboy | Factory 2.0L Turbo Powertrain | 3 | 03-13-2002 04:01 PM |
