Old 09-18-2003, 11:47 PM   #1
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
Default ARGH!!! Can't make up my mind.....
Which strut/spring combo should i get? here are my choices:
Strut- AGX, GR2
Spring- H&R (1.2f/1.0r)--
Eibach (1.2f/1.2r)----
Whiteline (3/4f/1.0r)-----if these are all right.
i want it to have that "even" drop look and at the same time not too low. Would love to get the V5, but too much for my blood.
VOLTIS5 is offline   Reply With Quote
Old 09-19-2003, 12:05 AM   #2
etam
Member#: 439
www
here is a side shot of my car (those wheels were on my car for couple days only)
215 45 17 and V5/H&R
http://members.rogers.com/manual/side_gt.jpg
etam is offline   Reply With Quote
Old 09-19-2003, 12:06 AM   #3
Cajual
Member#: 12900
1997 Legacy GT-Turbo
Quick Silver Metallic
I don't think the specs listed for the Eibach and H&R are that accurate. I'm sure my car dropped more than 1.2" with the Eibachs/v5... anyways, comparing my car with etam's (H&R/v5), the drop looks pretty much identical. If you're considering Whiteline's, be aware that they make two different types of springs... Control (25-40mm) and Flatout (40-50mm).
I was also concerned with the "even" look when I was buying springs because I saw pictures of Legacy's that looked saggy in the back. Maybe everybody could post pictures of their lowered Legacy's and their setups so we can see what the drops look like.
Here's mine with a lowered Forester:
Cajual is offline   Reply With Quote
Old 09-19-2003, 12:34 AM   #4
moss
Member#: 10197
Wow Cajual, you car looks nice! Anyone want a 2.5RS?
keith
moss is offline   Reply With Quote
Old 09-19-2003, 12:36 AM   #5
VOLTIS5
Member#: 2353
98' LegOver GT
Now i was thinking of getting the AGX/Whiteline combo, but read that my front would end up a bit higher than the rear if i go with the AGX. Or i could just stick with the GR2......
Would the Whiteline have the least drop out of the 3 and would still give me that "even" look? And is there any rubbing issues or bottoming out with the H&R set up?
Old 09-19-2003, 01:24 AM   #6
richeich
Member#: 1353
2001 Impreza 2.5RS
H&R Springs, STi V5 struts.
richeich is offline   Reply With Quote
Old 09-19-2003, 02:15 AM   #7
lucien2
Member#: 1519
1998 Volvo V70R
werd. I had the AGX and they surely did raise the front end a little. A decent strut to be sure, but not for me as long as there is no legacy-specific option.
My car with AGX:
v5/H&R-
lucien2 is offline   Reply With Quote
Old 09-19-2003, 10:27 AM   #8
VOLTIS5
Member#: 2353
98' LegOver GT
nice ride guys
wish i had more $$$ for the V5 struts . Guess i'll stick with the GR2/H&R combo.
So does the H&R have more than a 1.2/1.0 drop to it?
Old 09-19-2003, 10:39 AM   #9
etam
Member#: 439
www
As Cajual said, I think H&R and Eibachs got around the same drop.
Old 09-19-2003, 11:04 AM   #10
VOLTIS5
Member#: 2353
98' LegOver GT
Then H&R it is (seems like most of you guys use it ). Where can i find a set for cheap?
Would this springs in this link work? H&R
Old 09-19-2003, 11:10 AM   #11
etam
Member#: 439
www
I use it because it was cheap at that time ~US$210.. but so far so good..
Yup.. that's the one.. it is for 90-98 Legacy.
Old 09-19-2003, 11:54 AM   #12
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
www.tirerack.com has those too. I ended up selling mine because I decided to keep my car all-original...
DerFahrer is offline   Reply With Quote
Old 09-19-2003, 04:52 PM   #13
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Are those prices for all 4 springs? Just wondering, b/c I was thinking of doing a few suspension mods and was getting an idea of prices.
IronMonkeyL255 is offline   Reply With Quote
Old 09-19-2003, 04:52 PM   #14
richeich
Member#: 1353
2001 Impreza 2.5RS
Eh... my pic shows up as a red X at work, so I suppose nobody else can see it. (It shows up at the home computer.) Anyway, here's a link to one in case anybody wants a look. http://www.subaru-svx.net/photos/fil...heich/2485.jpg
Rich
Old 09-20-2003, 10:32 PM   #15
VOLTIS5
Member#: 2353
98' LegOver GT
Default Whiteline
Anybody have whiteline control springs on their car? need to see if its got that same look as the H&R .
Old 09-21-2003, 03:14 AM   #16
legacyej22
Member#: 23385
My legacy had H&Rs on it, and I'm sure that it was lowered more than advertised by H&R! I was impressed with the quality though, so impressed, I bought H&Rs for my Nissan too!
Josh
legacyej22 is offline   Reply With Quote
Old 09-21-2003, 05:12 AM   #17
Cajual
Member#: 12900
Default Re: Whiteline
I think nubaru2 has the Whiteline control springs on his Wagon and jacobhorn has the Whiteline Flatout.
Old 09-21-2003, 11:39 AM   #18
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I have GR2 struts on my Legacy, and Eibach springs (340 lb/ft front, 250 lb/ft rear). I wish the GR2's had a little more damping so I could run higher spring rates. I use Ground Control "coil-overs" (actually sleeve overs) to control the drop. Here is my car at almost the maximum drop. Ground Control can also set you up to go lower but I wanted to be able to raise my car OB - style for the winter.
Here's the sleeve-over
These Ground-Control "coilovers" are barely more expensive than just buying springs alone. If you'd like to control your drop and don't want to spend too much money, it's definately the most sensible way to go.
whtlegacy is offline   Reply With Quote
Old 09-21-2003, 01:42 PM   #19
legacy2003
Member#: 38338
2003 Outback Sdn H6
My car with AGX:
v5/H&R-
lucien, when you had the agx on there did you have lowering springs too? if so how much of a drop. i'm concerned because i have a set of agx from impreza that im going to put on my legacy and i have kg/mm 1.25" drop springs. i don't want that HUGE fender gap that you had on yours.
-mike
legacy2003 is offline   Reply With Quote
Old 09-21-2003, 04:30 PM   #20
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Guess everyone is ignoring my simple question... Nevermind me... Just inquiring about prices...
Old 09-21-2003, 05:15 PM   #21
sovereignmk1
Member#: 11858
1998 Silver Legacy
Yes, that's for all four....
I know nubaru2 has Whiteline/AGX's on his Wagon, but I don't think anyone has Whiteline's on their sedan(BD) with GR2 or AGX. Nubaru2's wagon did look pretty even to me.
I know where your coming from as I'm looking to do the upgrade too and I'm stuck on the GR2/Whiteline/STI topmounts or AGX/Whiteline/no STI topmounts....
what to do....
//M
Anyone have a good site for prices on V5's?
sovereignmk1 is offline   Reply With Quote
Old 09-21-2003, 07:13 PM   #22
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
...I'm stuck on the GR2/Whiteline/STI topmounts or AGX/Whiteline/no STI topmounts...
I have Whiteline Control springs on the way to me right now, and I'm ordering up GR2's this week...
I'm hoping to find some Sti top mounts on sale/special, cause they're damn pricey!
I'll take pictures once it's all on, but that probably won't happen for about a month, as I am slowly accumulating the parts.
-Brian
KD7000 is offline   Reply With Quote
Old 09-21-2003, 08:23 PM   #23
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Thanks.
Old 09-21-2003, 08:58 PM   #24
richeich
Member#: 1353
2001 Impreza 2.5RS
I think I got my H&R's on sale from SPO Motorsports for $225. Then I just sat on them until someone had a sale on STi V5 struts. That was Troncalli Subaru in Georgia. Got them for $276 shipped. This was all back in the summer of 2001, so I'm not sure what the going rate is now.
Rich
Old 09-21-2003, 09:05 PM   #25
richeich
Member#: 1353
2001 Impreza 2.5RS
90-98? Hmmm, that's kind of a weird range for fitment, isn't it? That surprises me that the springs are the same for first and second gen. Legacy's. And if it is, shouldn't they also list it for the 99's? Not meaning to question anyone, because I really don't know. I just would hate for anybody to pick up springs that won't fit.
Rich
need your help can't make up my mind tecnica technician Brakes, Steering & Suspension 0 11-13-2007 12:45 AM
Can't make up my mind - 05 Scion tC or used s2000 jmaluso Off-Topic 96 02-25-2005 11:38 AM
Can't make up my mind STiTuner Normally Aspirated with bolt-on Forced Induction Powertrain 7 06-18-2002 01:31 AM
Can't make up my mind... BOV for sale mpaone South East Region Forum 10 02-02-2002 03:01 PM
('93-'01) I just can't make up my mind.... ELUSIVE Impreza Forum 12 07-03-2001 12:25 AM
Message Board Statistics All times are GMT -4. The time now is 11:29 PM.
