Old 09-19-2003, 12:25 AM   #1
czo79
Member#: 6752
Default climate ctrl. lights and switch lights out
Hello all...
I noticed the other day that all my climate control lights are out, except for the ones which come on to indicate if air is directed towards legs, defrost, vent, etc when the corresponding button is pressed. I can't really remember exactly what is supposed to be light on that panel. I kinda remember that a lot of the buttoms you'd think would be lighted, only have an indicator if the button is pressed.
I also don't have hazard switch lighted, or power mirrors. Defrost switch is lighted, fog has on indicator light working, but not switch light. Cruise has on indicator, but not switch light. I was just wondering if all these lights might indicate a specific wiring problem or fuse (although I didn't notice a likely candidate). But maybe I just have a crap load of bulbs to change. To I need to get all these at the stealership?
thanks
micum
czo79 is offline   Reply With Quote
Old 09-19-2003, 01:32 AM   #2
andyC
Member#: 1607
2002 Silver
double you are ecks wagon
mine are out too - and have been for a few weeks.
bump!
andyC is offline   Reply With Quote
Old 09-19-2003, 01:52 AM   #3
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
try searching. there are a few threads on it. one has instructoins.
subiekid is offline   Reply With Quote
Old 09-19-2003, 02:02 PM   #4
BoardRider
Member#: 32059
1997 Legacy GT sedan
CBR600, WR400, Z50R
Mine went out a while ago. Check out this LINK on the web. It indicates some low cost bulbs you can buy at Radio Shack to save $$$ over dealer parts, and it gives instruction on how to replace them. I did this and everything is still working great.
Like subiekid said, there are also some threads here and on ScoobyMods.com with additoinal instructions and pics.
Have fun.
BoardRider is offline   Reply With Quote
Old 09-20-2003, 07:37 AM   #5
Z1 Performance
Member#: 9327
Micum - the mirrors sound like a fuse issue..check those first.
There is no more Cruise on your car, as the STi wheel disables it since it eliminates the controls.
The climate control lights are a common issue- one of the most common things these cars have. Do a search, there are lots of threads on it
Adam
Z1 Performance is offline   Reply With Quote
Old 09-21-2003, 11:52 PM   #6
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Default Scoobymods to the rescue
Scoobymods will show you how to replace the lights in the climate controls of a BD/BG - when the light goes out on those I think the entire panel doesn't light up, except for the A/C button.
http://www.scoobymods.com/forums/sho...hp?threadid=91
jey is offline   Reply With Quote
Old 09-22-2003, 05:47 PM   #7
Oquipah
Member#: 9689
1998 Legacy GT
Post
Scoobymods has detailed instructions and bulb/part numbers. You can either get them at RS or the dealership. They are cheap either way.
Don't pay to have the work done, it's way too easy to do.
Peace,
Oquipah
Oquipah is offline   Reply With Quote
Old 10-01-2003, 02:13 AM   #8
JPX
Member#: 44504
1996 Legacy L Sedan
Thumbs up
I totally agree with the links above - the Radio Shack bulbs are a lot cheaper than the dealer bulbs and the work is easy.
I replaced the haz and climate lights using these posts. I even took it a step further and replaced the factory radio button backlight - not quite as simple as the others, but not impossible.
These bulbs are slightly dimmer than factory, but since they all go out you'll probably end up replacing them at the same time. Then you won't see the difference.
JPX is offline   Reply With Quote
Old 10-01-2003, 01:03 PM   #9
Oquipah
Member#: 9689
1998 Legacy GT
JPX-You don't happen to know of instructions on how to replace the radio button backlights do you? Three of the buttons "1-2-3" are out.
Thanks in advance!
Oquipah
Old 05-11-2005, 03:34 AM   #10
JPX
Member#: 44504
1996 Legacy L Sedan
Man almost 1.5 years since I logged on this board. Sorry about dredging up such an ancient thread. But I figured it was a good place to pick up where I left off.
Oquipah, by now you've either bought a new car or figured out the radio lights already. But in case you or anyone else hadn't, there is so much more info on these lights on the forums.
It was pretty simple to change the lights. It requires removing the radio and carefully removing the casing and plastic cover to get to the backside of the circuit board for the 1-2-3 (or 4-5-6) buttons. The same Radio Shack lights can be used.
Old 05-11-2005, 12:19 PM   #11
skiwagon
Member#: 43728
2007 328iT
Graphite
Default radio display backlight bulbs?
JPX, do you know if it is that simple to also change the radio station display (ie. the LCD that says "disc" or 90.9, etc.) backlight bulb too?
thanx
sw
skiwagon is offline   Reply With Quote
Old 05-22-2005, 02:44 AM   #12
JPX
Member#: 44504
1996 Legacy L Sedan
thanx
sw
I think it is about the same as the rest. There is probably the one board the display is soldered to that might need to be peeled back to get to the bulbs. I've done this type of repair on a home stereo LCD - just a pain with the small leads.
Old 06-01-2006, 12:54 PM   #13
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
Wow... you guys are awesome.. I just lost my cruise control backlight for the icon ... red part still works when pressed now thanks to this I can fix it without replacign a perfectly good working switch Thanks boys
Kcwiro is offline   Reply With Quote
Old 06-02-2006, 10:23 AM   #14
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Here's a great DIY which can save some money. .
http://www.sl-i.net/FORUM/viewtopic.php?t=1904
vitai0 is offline   Reply With Quote
Old 06-05-2006, 04:27 PM   #15
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
Nice PDF really detailed and helpful ty
License plate lights and trunk light out TBone7281 Electrical & Lighting 6 05-17-2009 01:35 AM
Dash lights and brake lights out RCPC Electrical & Lighting 1 03-12-2009 12:02 AM
WTB 93 to 01 impreza glove box light and switch 2slofouru Private 'Wanted' Classifieds 1 07-15-2007 12:49 AM
Diagram: Dome, Door, lights and Switch Circuit, 95 Impreza t3hWIT Electrical & Lighting 0 01-17-2007 07:15 PM
Factory trunk light and switch SilverSuby General Forum Archive 1 07-20-2000 10:59 AM
