Old 09-19-2003, 04:13 AM   #1
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Question Idle Air Controller
So what does this little hose do that has the power to stall the car when not hooked to the air box?
I found that out one night.. I drove home without it on and the AT oil light was flashing that I threw a code..
SubaruImpreza_power is offline   Reply With Quote
Old 09-19-2003, 10:22 AM   #2
Hawk296
Member#: 14555
1995 Impreza L
Baja
so which hose, where was it connected to and why did you pull it off? pics would also help.
Hawk296 is offline   Reply With Quote
Old 09-19-2003, 01:01 PM   #3
Puckaveli
Member#: 1518
00 2.5RS
The idle air control soleniod valve regulates the amount of intake air which bypasses the throttle valve built into the throttle body. The hose was either from the IACS to the air assist injector soleniod valve or the hose from the AAISV to the air assist injector, basicly the by-pass hoses.
Puckaveli is offline   Reply With Quote
Old 09-19-2003, 02:04 PM   #4
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
I did not know it slipped off.. I was checking the Air Filter and I pulled the top part of the airbox up too high and it just popped off.
Idle Air Control Valve: Anyone had this replaced? IceClimber Service & Maintenance 7 04-04-2015 05:33 PM
Idle Air Controller Yotsuya Normally Aspirated Powertrain 15 06-27-2004 07:56 PM
IDLE AIR CONTROL for '02 WRX WRX-Mike110 Private 'Wanted' Classifieds 0 01-03-2004 04:59 AM
WRX Idle/Air control valve djerickd Private 'Wanted' Classifieds 11 12-02-2003 11:37 AM
idle air control valve, after a turbo mod mild_se7en Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-10-2002 07:45 AM
