Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 09-19-2003, 09:34 AM   #1
subarurabbit
Member#: 4083
2011 OB 3.6R
Default legacy turbo clutch pedal travel
so, other owners of Legacy turbo's -
how much free clutch pedal travel do you have?
mine goes quite a bit (about 1/2 travel) before i know I'm disconnecting. Letting the pedal up - the clutch engages very close to the floor.
any ideas?
air in system?
bad damper?
bad activator?
worn master cyllinder?
play with adjuster on end of master cyllinder rod?
tia,
Roger
subarurabbit is offline   Reply With Quote
Old 09-19-2003, 10:49 AM   #2
Mgardenier
Member#: 7518
1994 Legacy SS
Aegean Blue Metallic
there is very little play in my clutch on my legacy, the overall pedal movement is 1/3 what the movement is on my obs. it is amazing the difference in the cable and hydro. if you are going to the dinner on the 24th, you can drive my car and see if its like yours or not.
Mgardenier is offline   Reply With Quote
Old 09-19-2003, 01:25 PM   #3
subarurabbit
Member#: 4083
2011 OB 3.6R
ok cool - cause there is some other stuff I want to check to.
mainly, why my clutch return spring keeps coming off of the fork.
I did see this one the act site:
On some applications when a Heavy Duty ACT pressure plate is installed the engage/release point may become closer to the floor. This change may be due to flex caused from the added forces placed on the pressure plate and linkage from the increased pressure. A disc that has excessive marcel could also cause this change. The marcel is the wavy metal between the linings that allow the disc to gradually engage. If the marcel is too wavy it takes extra travel to release and engage.
In most cases, a small adjustment of the master cylinder pushrod reducing pedal freeplay will cure the problem. This adjustment is made by screwing the pushrod farther into the master cylinder to allow it to actuate the cylinder sooner. You may also desire to increase pedal travel by adjusting the pedal stop (when equipped). You should never preload the master cylinder. Good repair manuals include instructions and adjustment specifications, which is a great starting point. Adjustments are not usually needed if you are using sintered metallic linings because the lack of a marcel allows for quicker release/engagement.
Old 09-19-2003, 10:12 PM   #4
subarurabbit
Member#: 4083
2011 OB 3.6R
tweaked it a little tonight. Still night tight like WRX...
I think I need to bleed the system. I have the FSM...
There are rebuild kits for like $40 - new cyllinder is $150...
Old 09-20-2003, 12:43 AM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
That image and intructions are also applicable for adjusting the brake pedal BTW
Old 09-22-2003, 11:53 AM   #6
subarurabbit
Member#: 4083
2011 OB 3.6R
I'm going to have a dealership (Exeter) bleed the sytem Thursday night.
Old 09-25-2003, 11:28 PM   #7
subarurabbit
Member#: 4083
2011 OB 3.6R
Exeter did it. all perfect
Old 10-14-2003, 10:51 AM   #8
subarurabbit
Member#: 4083
2011 OB 3.6R
clutch slipped Friday in 2nd gear on gas on level road - brought car back to dealership.
dealership called Monday - needs a clutch master cylinder replaced
First generation Legacy hydro clutch pedal - are other hydro pedals compatible? ciper Transmission (AT/MT) & Driveline 2 07-09-2009 11:47 AM
Clutch Pedal Travel Reduction Kits Safe? gregnice123 Transmission (AT/MT) & Driveline 8 08-28-2008 12:59 PM
Shorten clutch pedal travel? Dex Transmission (AT/MT) & Driveline 6 02-28-2008 07:43 PM
reducing clutch pedal travel bluestone Transmission (AT/MT) & Driveline 1 10-16-2003 11:24 AM
Re: Legacy Turbo Clutch Adjustment outback2.5HO Legacy Forum 9 02-07-2003 10:37 AM
