Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 09-18-2007, 11:21 AM   #1
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Question Oil Leaks??
I have a 99 LOB and Have been Encountering Issues with seals. I have only 59,300 miles and I have changed my Cam Shaft Seals and did a full tune up after that the leak resided, but its starting up again, anyone have similar issues? or oil leaks?
JoeSUBARU is offline   Reply With Quote
Old 10-15-2007, 09:43 PM   #2
DodgeDemon
Member#: 161124
97 Legacy Outback
Mica Ruby/Slate
Clean the engine, engine bay and cross member thoroughly and make sure it's the engine that is leaking. I just overhauled my 97 and after driving it a while, it started smoking. It turned out that the boot on the CV joint is cracked and spitting grease onto the exhaust.
It would have been hard to catch if I hadn't cleaned the engine bay while the engine was out. The grease spatter pattern pointed me right to the CV joint.
DodgeDemon is offline   Reply With Quote
Old 10-17-2007, 03:52 PM   #3
linsavy
Member#: 11620
1997 GF4-STiV3 clone
All the seals in that motor are crap. Cam, crank, rear main, oil separater, cam cover, cam cover bolts, etc. They all leak about now or sooner. Try some high mileage oil like Castrol GTX or just change as they leak with the new better seals.
Your headgasket will blow soon anyway so you might as well wait until then to replace all the seals.
linsavy is offline   Reply With Quote
Old 10-17-2007, 04:19 PM   #4
rockhopjohn
Member#: 76297
2004 Outback Wagon
Mystic Blue Pearl
These engines have a tendency to develop leaks in a number of locations, but the ones that pop up primarily are valve cover seals, and rear main seals. I had a 96 and 98 and they both had rear main seal leaks. It was little annoying, but it only leaked about half a qt ever 3000 miles so I ended up just changing the oil when it got low.
Like DodgeDemon said, you also want to be sure you don't have a CV boot that is cracked. Typically though, it is very easy to tell the difference between a boot leak, and an oil leak. A boot leak will sling little blobs of grease radially outward from the boot, and will look like a splatter.
Sooo, again, like DodgeDemon said, clean up your engine, and then start looking for leaks. If it is valve covers, they can be pretty easily dealt with, if it is rear main seals, or front mainseals it is quite a bit more work, and might not be worth messing with.
rockhopjohn is offline   Reply With Quote
HELP with possibly compressor oil leak? TWR3CKS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-04-2010 02:00 PM
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 07:23 PM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 04:23 PM
New Omori Oil temp install and oil leak mhbrown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-22-2003 07:10 PM
oil leak from front of engine, oil pump? drftsub Legacy Forum 14 01-06-2003 07:44 PM
