Old 11-25-2003, 01:28 AM   #51
WRXncrew
Member#: 39970
2008 LGT Spec.B
Quartz Silver Metalic
You can use one pair of either 42002 (tapered) or 42009 (gasket style) and drill a 1/2" hole through one. Or, you can do what I did, and combine them using the 42009 as the base (drill a 1/2" hole through the 42002) and make 2.
WRXncrew is offline   Reply With Quote
Old 11-25-2003, 06:10 AM   #52
VetteVert
Member#: 5961
2005 STi
CGM
As was said, as long as you drill to 1/2" or more, you should be OK. You could try leaving the hole at the bottom of the bottom if you wish. I just drilled them both out and I'm still going strong.
VV
VetteVert is offline   Reply With Quote
Old 11-25-2003, 07:19 AM   #53
TheMadScientist
Member#: 23717
2005 Big red
I just made one last night. This is going on a TXS turbo back with 1 cat. What a great mod if it works.
TheMadScientist is offline   Reply With Quote
Old 11-25-2003, 07:32 AM   #54
VetteVert
Member#: 5961
2005 STi
CGM
I would have thought you might get away with nothing since you actually have a cat (I have 0). Either way, should work for you, but post if it doesn't. I think all the results so far have been on Helix or equivalent downpipes that take the place of the DP and MP in one piece.
VV
Old 11-25-2003, 07:36 AM   #55
TheMadScientist
Member#: 23717
2005 Big red
VV
If you just do the turbo back with one cat you can get away with no fix. On three cars that were fine with just the turbo back as soon as an uppipe was installed they started throwing P0420.
I hope this works if they do then I will be building alot more of them.
Old 11-25-2003, 07:53 AM   #56
TopKatz
Member#: 36793
04 WRX
UPDATE:
I had a bung extendor fabed up for my 04. Im runing STI up and scooby sport down, stock 3rd cat.
We put the extendor in the 3rd cat. The stock cat is a bad shape for an elbow type extendor. In fact its so bad that it causes problems. My extendor was hitting the cros member, and eventualy broke the female end of the cat! It created an exhasut leak.
I pulled the extendor, welded the femal bung back to the cat, and put the sensor back into the 3rd cat in its stock config. I did this on Fri and I have not goten a CEL yet.
Im not sure if its goign to come back on or not....
so, STI up, scooby down, stock 3rd cat...no CEL.... I have some highway miles on it...so Im not sure if it will come back or not...
TopKatz is offline   Reply With Quote
Old 11-25-2003, 09:15 AM   #57
s_nold
Member#: 22649
2008 Spec.B
I have put at least 1000 miles on my car since I first did the mod, and I have yet to get a CEL...so I am happy.
I have a MRT downpipe and a gutted up-pipe....for those who care.
s_nold is offline   Reply With Quote
Old 11-25-2003, 09:38 AM   #58
VetteVert
Member#: 5961
2005 STi
CGM
No cats at all, and 2000 miles...no CEL.
Topkatz...it must be something to do with your stock third cat....possibly the angle, but I'd bet it is the backpressure created from the cat....which forces more air into the extension than those of us without cats are seeing.
VV
Old 11-27-2003, 02:05 AM   #59
speedblind
Member#: 42202
Just put this on tonight. About 20 minutes from start to finish, and possibly the best five bucks I've ever spent on the car. Got a long trip down to Tucson and back this weekend, so the car will see plenty of highway cruising. Thanks to VV and everybody else that posted the plug nonfouler specifics! I'm much happier with this solution vs. cutting the O2 sensor wires!
Of course, I'll update this thread when/if I get a CEL like everybody else. Somebody should get this mod onto scoobymods.com. VV?
speedblind is offline   Reply With Quote
Old 12-01-2003, 03:50 PM   #60
ScoobyBoy
Member#: 6418
bump.
topkatz. im going to be running the same dp as you. so you're saying that the stock 3rd cat is bad for the elbow, but do you know whether or not the spark plug thing will be fine?
any cel's yet?
ScoobyBoy is offline   Reply With Quote
Old 01-03-2004, 10:29 PM   #61
hatchy
Member#: 36852
2004 STI
Anyone know if this fix will shorten the life of the O2 sensor or the O2 controller? O2 sensors operate at a certain temp, and if take the O2 out of the exhaust stream, the O2 controller will probably trigger the heater element, and they are probably not designed to run continously.
hatchy is offline   Reply With Quote
Old 01-04-2004, 08:54 AM   #62
TopKatz
Member#: 36793
04 WRX
ScoobyBoy - Im curently running with no eliminator at all, and no cel.
Old 01-04-2004, 04:42 PM   #63
blaznasn
Member#: 6750
i don't think so, if the sensor read anything out of the ordinary then it would throw a cel. exhaust gases are still reaching it.
blaznasn is offline   Reply With Quote
Old 01-04-2004, 05:39 PM   #64
hatchy
Member#: 36852
2004 STI
Some of the gas is reaching it, that is how this mod works, but I don't think there is enough gas to keep the sensor hot enough.
Old 01-04-2004, 06:19 PM   #65
blaznasn
Member#: 6750
you could just drill out a 1/2" hole in the base too then, that might help. Since we're all catless the exhaust gases naturally become hotter. taking the sensor out of the exhaust flow and diverting some gases to the sensor that way, enables the sensor read within the boundaries that is set by our ecu. If we left the sensor in the regular exhaust flow, it would throw a cel, and yes shorten the life of the sensor. with this mod it probably shortens the life still, but not as much as just leaving it in the regular exhaust flow, and we don't get a cel. All 02 sensors will eventually fail or start to give the wrong readings anyways, especially if you race or use gas additives and such, but then if you race you continually tune your car anyways
Old 01-11-2004, 10:38 PM   #66
WRXncrew
Member#: 39970
2008 LGT Spec.B
FYI... I've been using my mechanical 02 Sensor modified bung extension CEL fix and have not gotten any new CEL after installing. It's already been several thousand miles and has been to the track and still no CEL. Don't spend $20 when you make the fix for $5 or $10 and requires NO SOLDERING or re-wiring.
Cheers and Enjoy
Old 01-16-2004, 07:23 AM   #67
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
CEL free for the last 2k miles after this fix.
rex n effect is offline   Reply With Quote
Old 01-16-2004, 12:18 PM   #68
02sedona
Member#: 46247
02 wrx w/ mods
sedona red pearl
I also have tried this fix with the 42002 kit from my local autozone. It does need to be drilled out for the o2 sensor to fit but i have rid my car of the check engine light. Thanks for the cheap tips guys
02sedona is offline   Reply With Quote
Old 01-20-2004, 02:50 AM   #69
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
This is a great idea! I had mine welded 1.4 years ago and still have not gotten a CEL.
http://forums.nasioc.com/forums/show...&highlight=cel
mattjk is offline   Reply With Quote
Old 01-23-2004, 04:04 AM   #70
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Still no CEL here..
Glad a non-weld solution was found!
Macabre is offline   Reply With Quote
Old 02-01-2004, 11:16 AM   #71
SupraScooby
Member#: 52123
05 WRB STi
04 AW STi GT30R [RIP]
Originally posted by s_nold
You only need one or the other...there is a small difference in them, I can't remember exactly what it was...they should be next to each other...and if I recall...it is somewhat obvious what the difference was from one to the other... Make sure you get two of either one...and you will have to drill out the center so that the O2 sensor will fit...The MINIMUM diameter of the hole should be NO LESS THAN 1/2" you will have to drill both peices out for everything to fit.
so you do have to drill a 1/2" hole in BOTH....? alryte about to try this trick very soon on my 04 STi
SupraScooby is offline   Reply With Quote
Old 02-01-2004, 12:11 PM   #72
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Yes, and you're welcome
Old 02-01-2004, 07:45 PM   #73
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
$15 is a good price for something like that - but this is the first I've heard of it. Do they have it on their website? I looked but couldn't find it. Do you have to buy an exhaust system from them to get it?
Old 02-02-2004, 12:43 PM   #74
Prairie Dawg
Member#: 16598
'09 Civic Si
Redline Orange
I only drilled out one fitting, and my sensor fit just fine...
Prairie Dawg is offline   Reply With Quote
Old 02-02-2004, 09:55 PM   #75
blaznasn
Member#: 6750
yeah just one atleast, so the sensor can fit in all the way, some people drill out the second, some don't, it works either way.
mechanical rear O2 CEL fix sesjptj Private 'For Sale' Classifieds 0 08-08-2005 11:03 AM
FS: Mechanical Rear O2 Sensor Fix spankaveli Private 'For Sale' Classifieds 75 03-02-2004 05:55 PM
Mechanical Rear 02 CEL Fix fliz Private 'For Sale' Classifieds 6 02-04-2004 12:18 PM
Non-permanent mechanical rear O2 CEL fix yjack Private 'For Sale' Classifieds 10 11-25-2003 10:09 AM
Rear O2 CEL Fix Thumper23 Private 'Wanted' Classifieds 4 11-07-2003 02:44 PM
