Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-20-2003, 05:17 PM   #1
veilside_scooby
Member#: 41640
1995 Impreza LX
Green
Default sti 6-speed conversion
i was just curious if any one has attempted a sti 6speed conversion in a gc8 bodystyle? if so what parts are needed? and last but not least what all is envolved in converting an AT to a MT?
-allan
veilside_scooby is offline   Reply With Quote
Old 09-20-2003, 05:43 PM   #2
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
A few people have done it, I'm sure they'll chime in or someone will mention their names. As far as fitment, you just need to bang out a rib or two in the tranny tunnel.
garface is offline   Reply With Quote
Old 09-20-2003, 06:55 PM   #3
veilside_scooby
Member#: 41640
1995 Impreza LX
Green
Bang out , gotta love the technical terminology i'm really curious if the new sti 6-speed would fit an ej22. if not what MT's will and which is the strongest for an ej22-t?
Old 09-20-2003, 07:32 PM   #4
garface
Member#: 1581
MY00 RS/STi7
The 6 speed will fit any EJ series engine.
Old 09-20-2003, 08:29 PM   #5
veilside_scooby
Member#: 41640
1995 Impreza LX
Green
ok now i have a stiffy now besides a tranny, clutch pedal assembly and resevior what else do i need?
Old 09-21-2003, 08:23 PM   #6
WickedRydaX
Member#: 31900
The tranny and a lot of time to do it. Or money to pay someone to do it.
MCL
WickedRydaX is online now   Reply With Quote
Old 09-21-2003, 10:40 PM   #7
Hawk296
Member#: 14555
1995 Impreza L
Baja
you are going to need the tranny, the flywheel/clutch. Your going to have to get the hydraulic pedalbox assembly, resevoir, lines etc. Ive heard you need to messag the tunnel, you are going to need new mounts for the trans. You are going to need the matching rear differetntial, then axles (hubs?) and propshaft. its can be done for 6k with new parts. If you want the DCCD version you will also need the controler, switch and associated wiring. I am looking into doing this on my L but need to locate proper funds first.
Hawk296 is offline   Reply With Quote
Old 10-07-2003, 05:10 AM   #8
morpheous
Member#: 37122
94 legacy
how much power can the six speed handle. does any one know if it can be converted to front wheel drive only?
morpheous is offline   Reply With Quote
Old 10-07-2003, 11:45 AM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
1-As much as you can throw at it.
2-Not that I'm aware of. Any manual transmission cannot be converted easily. Besides, why on earth would you want to?
-Jon
Old 10-07-2003, 03:08 PM   #10
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Crawford/I-Speed is offline   Reply With Quote
Old 10-07-2003, 04:04 PM   #11
morpheous
Member#: 37122
94 legacy
-Jon
1-are you serious, all the power you can throw at it? 450hp?
2-it would be for a mid engine 914 porsche. that way i can have a six speed . im already putting a 2.2 closed deck in it but with a porsche tranny. i would love to have the six speed though but it would have to be converted to FWD. how do you shift the six speed? is it a cable shifter?
thanks.
Old 10-07-2003, 05:06 PM   #12
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The transmission was redesigned from the ground up and is vastly superior to any previous Subaru transmissions. I would feel comfortable pushing 450hp through it.
The transmission is shifted via linkage attached directly to the shift forks. There are no cables.
I'm not sure how practical it would be to permanently convert the transmission to FWD. It was originally designed as an AWD transmission and you would probably be throwing some of the design contraints out the window in doing so.
-Jon
Old 10-07-2003, 05:14 PM   #13
morpheous
Member#: 37122
94 legacy
i guess im stuck with the rudimentary 5000.00 porsche tranny th. im going to contact kennedy engine to see if they have already made an adapter for the boxster transmission to a suby EJ. that is my last hope. ITs an awsome tranny it can take 700hp.
thanks for the scoop.
Old 10-07-2003, 08:25 PM   #14
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Originally posted by I-Speed USA
You do not need to smash or bang any part of the tunnel to fit a 6-speed into an impreza. The 6-speed will fit with no modifications.
IMHO I think the problem arises when people try to install the tranny with the engine still in. If that’s the case….there may be some hammering going on.
Chris
I-Speed USA
[email protected]
how much would you charge to install a new 6 speed with the DCCD, into a 95 legacy that has an ej22T in it? t
thanks
dustin
subiekid is offline   Reply With Quote
Old 10-07-2003, 08:27 PM   #15
subiekid
Member#: 25516
forgot to add that the car has the 95 AT in it right now.
Old 10-07-2003, 08:57 PM   #16
WickedRydaX
Member#: 31900
The boxster one can handle 700hp? Man I need to start working on that car, not mine.
MCL
Old 10-07-2003, 10:31 PM   #17
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
You would be hard pressed to get all the necessary parts for the STi 6speed for $5k so I would probably go with the Porsche tranny.
-Jon
Old 10-09-2003, 07:59 PM   #18
stever
Member#: 1512
99 2.5RS
Rally Blue and Black
You can make it FWD by taking out the center diff and replacing it with a something like a spool. I don't know if anyone makes one, but you should be able to have someone fabricate it ... it's pretty simple. You basically want something that'll lock the input and ouput shafts together. Then just cap off the output where the driveshaft normally goes. It's not the optimum but I guess it's cheaper than buying a 6 speed Porsche box.
Or you could just weld the center diff solid somehow but that's a lot of extra weight. Spools are pretty light.
-Steve
[email protected]
stever is offline   Reply With Quote
2001 RS STI 6 speed conversion (R180 rear diff question) Texas25RS Subaru Conversions 7 09-12-2007 07:09 PM
Any local WRX 5-speed to STi 6-speed conversion veterans? TampaWRX South East Region Forum 2 09-26-2006 07:47 AM
01 RS to STi 6 speed conversion question/info needed Texas25RS Transmission (AT/MT) & Driveline 2 05-17-2005 01:43 PM
usdm sti 6 speed conversion hybrid gti 2 Private 'Wanted' Classifieds 0 04-10-2005 12:43 AM
STi 6-speed Conversion Info stimpy Subaru Conversions 2 08-22-2003 11:21 AM
