Notices
Old 09-20-2003, 05:36 PM   #1
cronic
Member#: 9749
Default what parts are needed for 6spd?
I have searched on this but not found the awnser that i am looking for.. I want to put the sti 6spd in my 02wrx.. I was told if i got the sti6spd driveshaft front axles and the ring and pinion off a 91-94 turbo legacy it would work.. Can anyone confirm that for me? Also will there be any drawbacks to doing the install like that over getting the whole sti rearend?
Thanks
Dave
cronic is offline   Reply With Quote
Old 09-22-2003, 04:23 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
http://forums.nasioc.com/forums/show...&highlight=6mt
You are a little confused here, it seems. The automatic driveshaft or the STi 6speed driveshaft will work. Front axles will bolt right in to the transmissions. Rear axles are needed only if you go for the R180 (STi) rear diff. The rear axles are needed because the R180 is physically bigger and requires shorter axles. If you grab the ring and pinion off of a Legacy turbo, then you can convert your 3.545 rear diff into a 3.90 final drive that you need for the 6mt.
The drawbacks for retaining your rearend will be a weaker rear diff. The R180 is physically larger so it will hold more fluid, but it also contains a much better Suretrack limited slip. The drawback to putting in the R180, however, is that you need the STi axles. If you get the STi axles, then you need the R180 hubs. If you get the R180 hubs, then I believe you need the bigger brakes: commonly the Brembos. Cost increases almost $2k to install the R180.
-Jon
Old 09-23-2003, 12:51 PM   #3
Z1 Performance
Member#: 9327
IIRC you do not need the Brembos to do the rear hubs.....R180's were used on pre 6 speed STi's as well remember....
Z1 Performance is offline   Reply With Quote
2.5rs swap. what parts are needed? ILwrx Subaru Conversions 2 10-03-2005 04:58 PM
What parts are needed to turbo a MAP sensored RS? Homemade WRX Normally Aspirated with bolt-on Forced Induction Powertrain 19 12-10-2003 12:21 AM
What parts are needed for Headgasket change? Cusco Service & Maintenance 3 05-24-2003 02:56 AM
what other parts are needed for turbo conversion halftendril Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-14-2003 12:57 AM
What parts are needed for Autometer Ultralite A/F guage install? Robmat Normally Aspirated Powertrain 4 03-03-2002 06:45 AM
