Old 09-21-2003, 09:44 AM   #1
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
Thumbs up Deadbolt Monster TD 04 with Port and Polish
one word- Awesome.
so far I'm getting useable boost around at most 2500 rpms- yes I did samco hoses at the same time, but I don't think those would have dropped the boost that much. Feels stronger when pulling. You can hear the extra flow from it when on boost. It also elimated the boost creep I was experiencing with the Boost Monkey.
I'll have pics of the difference, the ones on Deadbolt's site aren't that great
edit- full boost by 3200
speed safely
Brian
Slvrblt is offline   Reply With Quote
Old 09-21-2003, 07:00 PM   #2
Mushashi
Member Sales Rating: (2)
Member#: 40396
Thanks for sharing Brian, I am waiting for mine too. I will be GP Moto headers and turbo back along with a Vishnu stg 1 ecu.
Please post those pictures, I'll be posting my review about the Deadbolt Monster TD04 as soon as I get it back and have had a change to feel out the car's new setup on the Road Race Course.
Mushashi is offline   Reply With Quote
Old 11-18-2003, 02:50 PM   #3
hatchy
Member#: 36852
2004 STI
Do you have dyno before and after results?
hatchy is offline   Reply With Quote
Old 11-23-2003, 02:18 PM   #4
billmidd08
Member Sales Rating: (3)
Member#: 39599
08 STI Hatch
where are those pics???
billmidd08 is offline   Reply With Quote
Old 11-24-2003, 04:04 AM   #5
Spooled
Member Sales Rating: (16)
Member#: 14958
1991 318is
I'm wondering too, I want to do this to my turbo.
Spooled is offline   Reply With Quote
Old 11-25-2003, 12:50 AM   #6
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
wow, totally forgot about this post. Unfortunately I didn't take any pics with my camera, but I'll try to hunt down the person that did. as for Dyno plots, I can do that kind of- I added the below in addition with the Deadbolt turbo
Monster TD04 with Port and Polish in addition to STi UP-pipe, Samco Hoses
speed RPM WHP A/F
80 6403 176.2 10.8
Lambda PSI
0.74 10.8
Before with just Boost monkey, 3/16th mod, and straightpipe
whp- 179.3 @ 15ish PSI
I don't have a text version of the other stuff
also note- I replaced the 3/16th with the stock connector again
in other words- 4 less PSI but only 3WHP less
as for spool- the graphs don't make sense- but before- full boost ~5250
after ~3500
hope that helps
speed safely
Brian
Old 11-29-2003, 04:49 PM   #7
exhacker
Member#: 33725
2008 Impreza WRX 5dr
so..... what's making you get *less* boost ?!?
exhacker is offline   Reply With Quote
Old 12-01-2003, 09:45 AM   #8
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
I think it's the stock connector vs the 3/16th mod. I took it out because I didn't like the way it threw the psi from extremes. It's more stable now with the stock connector
ok, and as promised- pics finally
Inlet
exhaust
in each pic- the Monster is on the left- or if you will, in my right hand, should be pretty obvious though
speed safely
Brian
Old 12-02-2003, 12:41 AM   #9
sonicowrx03
Member#: 41566
Hello,
When I first read your thread about your turbo being ported and polished I was very enthusiastic, I couldnot wait for the result since you mentioned that your turbo felt like no other.
Now you are telling me that you made 3hp less and 10psi of boost? How? the info that you gave us is very confusing, none of the info provided makes sense, the only quote that makes sense if that you say that now you get full boost at 3500rpm.
I don't know what to tell you, I was very excited about doing the same thing to muy turbo but now I am holding on that.
The pics are not very drastic either, the turbo with the port and polish looks almost as bad as the stock one(really dirty and oily by the way).
Please do some more research and let me know because I want to port and polish mine but so far you are not impresing me.
Thanks
sonicowrx03 is offline   Reply With Quote
Old 12-02-2003, 01:45 AM   #10
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
the psi issue is an engine mgt issue- my boost control wavers drastically, I truthfully don't know why it went all the way down to 10 but whatever.
the dirty look on the monster is a coating in order to protect it during shipping- if you look closely, you can see a definate and huge difference in the size of the housings and smoothness
luckily, KTR put the dyno graphs on their website- this should make it a little easier to understand:
Dyno Graph
I'm not trying to convince anyone of anything- if you don't think it's for you, don't get it
speed safely
Brian
Old 12-02-2003, 01:49 AM   #11
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
the rest of the info just got compressed, maybe that's why some are confused
speed= 80 MPH
RPM= 6403
WHP= 176.2
A/F= 10.8
Lambda= .74
PSI= 10.8
hope that clears it up
speed safely
Brian
Old 12-02-2003, 01:51 AM   #12
harvey oh
Member#: 23516
thanks for the post. i assume you reflashed/tuned. do you have 3" downpipe exhaust system? do you have stock injectors and fuel pump, is it necessary to upgrade? thanks!!!
harvey oh is offline   Reply With Quote
Old 12-02-2003, 09:08 AM   #13
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
stock engine mgt still- but that will change shortly. my boost control is the culprit, but I don't want to get into that
no, I don't have a 3" yet that'll be in by the spring
and yes, stock injectors and pump- I don't think it'd be necessary since it's just a stock turbo that flows a lot better- you can hear the difference
hope that answers the questions
speed safely
Brian
Old 12-02-2003, 02:40 PM   #14
harvey oh
Member#: 23516
thanks brian! much appreciated. harvey
Old 12-02-2003, 03:19 PM   #15
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
I also have a clutch that's going, if you look at the plot- you can see where it slipped
no problem harvey
speed safely
Brian
Old 12-02-2003, 08:32 PM   #16
0260B4U
Member Sales Rating: (1)
Member#: 33249
2003 WRX
white
i got one and couldnt be happier no grapsh or anything did TBE upipe and MRT inlet at the same time. But couldnt be happier. Once I get mgt things should be much better. I also got a 5 degree clip on mine.
And you can hear my turbo spool form like 4 blocks on a quiet night, its loud now.
0260B4U is offline   Reply With Quote
Old 12-03-2003, 01:49 AM   #17
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
especially with it being extremely cold like it was tonight
can't wait to get some engine mgt, but have to replace the clutch first
speed safely
Brian
Old 12-17-2003, 07:48 PM   #18
DeadBolt Enterprises
Vendor
Vendor Sales Rating: (16)
Member#: 34272
2005 STi
Crystal Grey
Glad you guys are happy with them!
Let us know if you need anything!
DeadBolt Enterprises is offline   Reply With Quote
Old 05-25-2004, 10:20 PM   #19
Unabomber
👌 Big Ron 👌
Member Sales Rating: (11)
Member#: 18062
on car parts so PM
me b4 j00 buy
Prior to receiving my turbo, I had the following mods:
2004 Subaru WRX Sports Wagon
Perrin Pulley
Used Vishnu non-flex uppipe
TurboXS Stealthback no cat version
Prodrive axle back muffler
Cobb AccessECU Stage 2 93 octane map
Borla Headers
JDM Ver. 7 STi Intercooler
2004 STi hoodscoop
2004 STi splitter
2004 STi shroud
2004 STi IC sprayer nozzle
2004 STi IC water spray switch
Cobb AccessPort upgrade
Needless to say, I have maxed out what Cobb's Stage 2 can support.
Having heard what a Monster P&P does to a stock turbo, I was very interested in this modification. Further research showed my that Deadbolt also offers clipping services and internal port and polishing. I emailed Jerry about these services and decided the internal P&P was right for me as well. Jerry also recommended against the clipping based on my desires. These two services, I feel, don't receive enough attention on his website or on NASIOC, so I specifically mentioned them here to spread the word.
I ordered a Monster P&P with an internal P&P. I bought, received, and installed it without really knowing wether I would feel or see any changes to be honest. For a stock turbo car, they don't come much more modified that what I already have. I wasn't sure if the great gains seen by lesser modified WRXs would show through or not.
After installation, I reset the ECU, reflashed Stage 2 with my Cobb Accessport and drove for 3-4 days. Driving was a mix of place to place and "spirited driving". I am actually more impressed than I thought I would be. Impressions so far:
1. Noise reduction. The stock turbo whistled like crazy inside my TurboXS Stealthback (Stealthbacks are famous for accentuating the turbo whistle). The turbo whistle is decreased by at least half if not more. This is a good thing in my opinion, but may be a "bad thing" for people who enjoy the whistle sound.
2. Quicker spool. The boost needle definately moves quicker and earlier than it used to.
3. Low end torque. Quicker boost equates to more low end torque.
I am very happy with my decision at this point. Every time I drive, it feels a little better. This is probably due to the Cobb ECU which is famous for getting better and better in the days following a reset. I intended to wait a week or two for the "best" review based on a longer impression, but I am currently being PM'd to death by people wanting to hear my opinion to help with their decision process!
My opinion is this:
If you want more power without the additional expense of an aftermarket turbo, this is a great deal! $200 gets you the Monster service if you have a spare, or Deadbolt offers a core exchange for a larger initial investment.
If you are interested in more low end torque or quicker spool, this turbo is great. Even on a nicely modded car like mine, I felt what this turbo had to offer, so I think the impression on a more stock car will be even better than mine.
Aside from the standard Monster service, I recommend you discuss via PM or email with Deadbolt the possibility of adding clipping or an internal P&P as well. They may be worth the few extra dollars depending on your goals.
I am personally very satisfied with the turbo and my buying experience. I would recommend Deadbolt's services to anyone.
Stock left, Deadbolt right:
Installed turbo
The silver metallic stuff on the Deadbolt turbo is Thermo Tec turbo wrap. My review of it.
Old 05-26-2004, 02:28 AM   #20
InfamousDX
Member Sales Rating: (184)
Member#: 25413
So when does your full boost hit now Unabomber?
Old 06-06-2004, 12:31 AM   #21
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I can't really say for certain now. I am having some boost issues due to the Cobb reflash. I think I finally worked it all out today by using their latest reflash and adjusting the wastegate arm. I believe that for me, full boost is around 3800rpm or so. I have headers, so that takes away from what the average user would see though.
I am twice as happy today with this turbo than on 5/25/04 when I originally put it on!!! Since I am now fully boosting my smile factor is much higher. Much of this can be attributed to more boost, but I am really loving the power my car makes now.
Old 06-21-2004, 06:26 PM   #22
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
That Deadbolt P&P looks sexy. Look at now nicely the area around the exhaust turbine is smoothed out, and the intake-outlet is nicely smoothed out as well. The price is right, too!
Now if he starts selling ported/polished IC inlet pipes (combo it with a silicon piece, too!) he will have another winning product on his hands, although I suspect any gains from this piece would be pretty minor but I'm sure that plenty of people would buy it to get the complete package.
drees is offline   Reply With Quote
Old 07-15-2004, 03:15 PM   #23
STUDAndring
Member#: 61891
04 WRX
Pearl Blue
I would like to get it done. Maybe someone could send me some info on this PNP.
STUDAndring is offline   Reply With Quote
Old 07-15-2004, 05:03 PM   #24
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
unabomber,can you please give a update to your review. still like it and recommend it. Have you had a chance to dyno it? I am cobb stage 2 too, do you think it is holding back it potential, custom tune might be necessary?
I am interested in quicker spool for auto-x so this seems like a decent option.
Jeff_DML is offline   Reply With Quote
Old 07-15-2004, 05:58 PM   #25
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I am still a big fan of this mod. I haven't dyno'd yet as there isn't one local, but hopefully we should have a local one next month. I am VERY interested to see what my wagon puts to the wheels. No custom tune is necessary as Cobb said it will work fine with their reflash. I am maxed out to the max with their stage two to include uppipe, headers, P&P turbo, lightweight pulley, and bigger TMIC. All of these items are "supported", but a few crazy souls such as myself have lumped them all together. Teh wagon runs VERY fine though.
CA: Built Heads DPR Stage 3 AVCS Cams with Port and Polish, Axis Stage 1 Valve-train. Shaved Engine/Power/Exhaust 5 05-04-2008 01:36 AM
deadbolt monster td04 w/ injectors and pump WrexFactor36 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 09-25-2005 08:39 PM
Access stg 2//deadbolts monster port and polish jagcars26 Engine Management & Tuning 16 07-29-2005 11:12 PM
TD04 Deadbolt Monster Port and Polished + ceramic coat, Fastest Spooling WRX Turbo! YinUCSD Private 'For Sale' Classifieds 12 02-22-2005 10:48 AM
Deadbolt monster td04 with Cobb stage 2? 31105015 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-09-2003 07:59 PM
