Old 09-21-2003, 05:09 PM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default FWD-->AWD turbo hydro trans swap compete!!!
word. i have completed my AWD conversion
the car:
93 FWD impreza L. cable actulated clutch, FWD axels, FWD small diameter clutch/friction disc, flyhweel
what went in:
94 WRX-STI 4.11 turbo trans, hydro pull style clutch,
GDA USDM WRX exedy clutch and light flywheel,
springs and clips and misc hardware from 94 legacy turbo
97 JDM 4.11 rear LSD diff, axels,
94 JDM driveshaft,
02-03 USDM GDA sti transmission mount,
94 JDM trans H-member(centre/front brace)
01 RS trans h-member rear brace
94 JDM WRX-STI shift linkage
99 USDM 2.5 RS hydro pedalbox, modifitted JDM Clutch MC (shaft should be shortened 2.25 inches) with silly RHD heat shield
stainless steel custom clutch line (fabbed locally)
95 impreza L AWD diff x-member and braces/brackets
1 front axel from 96 legacy 2.2L
1 front axel from JDM 94 WRX
parts already in the car from previous AWD rear end conversion:
98 outback hubs, rear x-member, lateral links,
96 impreza outback e-brake cables,
94 impreza AWD gas tank,
whiteline endlinks, fram mount pads
20mm STI rear sway bar
STI v6 struts/springs
yeha. thats my crazy parts list. not to mention the vented 1 pot rear brake upgrade (JDM WRX or USDM legacy turbo) that went on at the same time, and the frantic business what not.
okay, so u have a FWD. u want AWD. on top of it u want a JDM gearbox from a turbo car.
#1. find about $2K or so
start collecting parts, MAD MAD MAD parts.
the break down*********
trans- the JDM 4.11 trans i got outa a front clip, it came with shift linkage, incomplete trans mount brace, worn out trans mount, slave cylinder with cut flex line, JDM RHD pedal box, RHD clutch MC with shaft too long and funny heat shield and wrong side metal line
what u need:
RHD JDM pedalbox DONT Work. the clutch MC is on the wrong side. u can reuse the clutch MC, but u need to shorten the shaft about 2.25 inches. or get a MC from a USA car. $45 is what they cost used
USA hydrolic pedalbox assembly. u need clutch/brake pedals
canidates to pillage in order of un-obtainum:
usa turbo legacy 5 speed
outback/legacy 2.5 manual
98-01 GC8 2.5 RS
GDA WRX - stimpy says it dosnt fit, ive seen it fit in a 98 2.5RS
dealer. about $350 AND u gota order a million little parts and put it all togeather. bad deal
i got mine for $100+$25 for overnight outa a 99 RS from a j-yard. 1.800.248.yard -brickyard in indiana
MC: if u use the USDM (GC8 ideal) part, get the hardline, the soft line and just plug and play it. if u use the JDM, screw the hardline adn get a custom stainless steel line. about 16" is good, cheaper than buying a hardline $15?, a bracket $15, and a soft line $27.
trans mount- FWD and AWD are completely differnt, by the time u think about doing this u should have a giant box of bolts in all sorts and sizes -HOPEFULLY,or a j-yard that u can grab everyhing at. otherwise u WILL PAY. DEARLY for thses little things.
the AWD trans has a front brace (r-L), a middle bar (F-R), and a rear brace (R-L). the trans mount hang out on the middle bar, 14mm/17mm hardware required. forgot the specs bc i have a giant box o screws/nuts. u need little cusions between the pieces and special plate things (2) one has spaces welded on it, one has 2 studs for it. go to your parts dep. and get a diagram for a 99 2.5RS or somthing. any AWD impreza should work. the pieces new are $$$. paid $75 for the rear brace and about $45 for misc crap ineeded related to it. get it form your J-yard if at all possible.
shift linkage:
im guessing the parts from a GC8 2.5RS or any AWD will work, i dont know for sure. i got my misc nuts/bolts. spacer thing at the dealer from a 94 legacy turbo. also $$$, get it intack if possible, again do the diagram thingy.
clutch:
the trans has a few things attached to it:
slave cylinder -specific to turbo car, NA wont work
giant round shaft thingy that the clutch fork pivots on
end bolt/slug that keeps the shaft in
clutch fork
spacer thingy and tab for spring guy to clip on to on the outside of the shift fork
spring to keep the clutch fork pulled forward
rubber boot - i got one from a 94 legacy turbo -$17
throwout bearing -any turbo car(legacy, usa WRX) will work
pilot bearing- all subaru is the same
flywheel- JDM GC8 turbo is same as USA wrx and legacy turbo, im using a 14# exedy USA wrx part
clutch cover - usa wrx and JDM gc8 wrx is the same. im using EXedy part for USA wrx
friction disc. same as the previous 2 things.
starter - all manual trans subaru is the same. im using OEM 1.8L FWD 5 speed one from 1993.
so the trans is taken care of.
driveshaft:
several styles of driveshaft exist. theres a kind wiht small holes and a slot on one side, theres a kind with big holes and spacer/cusions on each end, etc.
find out waht driveshaft u have and get the parts required for it. i hadthe slotted kind, supposedly all 5 speed driveshaft from impreza should work.
rear diff. if u have a 4.11, a 98-01 GC8 RS is 4.11, 00-01 is LSD, if u get LSD u need the LSD axels too. USDM AT wrx is 4.11 LSD, most likely the wagon axels are what u need, sedan may have widetrack and are longer??
u need also a rear diff Xmember, any AWD impreza will work. its got the 4 studs to bolt the diff into, the cover plate for the front, the rear mounting bolt / plate
okay. thats what i had to do
IF u havnt convered your rear end yet........
u need a AWD gas tank, AWD (disc brake) hubs lines .knuckles. calipers. rotors. the whole shabang, AWD lateral links, AWD disc e-brake cables, AWD struts/springs, might as well do the rear sway bar swap as well, get the links, the frame mounts, endlinks, the bar, etc.
yeah
that is my write up on my FWD--->awd converison. it was pretty nuts.
post if u got any q's
supermoose is offline   Reply With Quote
Old 09-22-2003, 12:32 AM   #2
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
for a couple thousand more I bought an impreza that already had AWD
Hawk296 is offline   Reply With Quote
Old 09-22-2003, 12:47 AM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
hey is your car up and running yet? I did the AWD swap too I used the wrx shifter linkage but part of the linkage is rubbing on the drive shalf. I'm intrested in covering to a hydro stytle tranny I already have AWD and I'm going to try to get a 94 wrx front clip . whats your parts list for just a hydro tranny swap? you got a front clip correct? what extra stuff did you need that wasn't on the front clip?
scobaru is offline   Reply With Quote
Old 09-22-2003, 02:51 AM   #4
supermoose
Member#: 9093
swap starr
Default narg.
yeha, ahey, yeah. buy your AWD subarus. :P
your car colour is UGLY too. i Hate it. :P!
umm parts. my clip came with a trans and driveshaft but no rear end. so i needed to get a diff/axels
some may, som may not. dep. on the clip.
i had a almost complete shift linkage, and a complete clutch minus friction disc. (which my importer lost !) and rubber boot- which they tore. also u need the pedal box assembly, so basically what u need when u get a JDM clip is:
USA pedal box, pref a new clutch, and the pieces that u are missing, random bits/ pieces of shifter, trans mounts, driveshaft, correct gearing rear diff, etc.
i guess the deal with conversion is that u get to spec exactally what u want. no dealing with poo-gear ratios and no LSD :P so technically i didnt pay for it :P
h
Old 09-22-2003, 08:31 AM   #5
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
supermoose is an INSANE guy , damn man your car is getting sicker and sicker everytime i read another one of your conversion post
cindergarden is offline   Reply With Quote
Old 09-22-2003, 01:35 PM   #6
supermoose
Member#: 9093
swap starr
Default hah.
yeah, just make a plan and run with it........
too bad theres no one pushing 250PS on a 2.5 NA.............
narg. im too poor to do that though, we're going to do a full version 1 sti ej20g swap for ~ $1500 alltogeather......
thats in progress rite now. it'll be posted once we get pix
h
Old 09-22-2003, 04:05 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Ah yes, but are you running a turbo clutch, transmission, and hydraulic clutch activation?
Great job supermoose. I take it that your clutch slave cylinder was drastically different that mine, huh?
-Jon
Old 09-22-2003, 04:17 PM   #8
supermoose
Member#: 9093
swap starr
narg. yeah, the full turbo clutch setup. slave cylinder should be the same, i dont think it cares what side drive it is, clutch MC is a differnt story though.
h
Old 09-22-2003, 04:23 PM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Sorry, I meant clutch master, not clutch slave. I KNOW that clutch slave should be fine.
-Jon
Old 09-22-2003, 05:21 PM   #10
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
what does the usa clutch box all include? were can I get one? I'm guessing it'd have to be from another hydro trans like turbo legacy?and what about the hydro clutch cable line?
thanks
Dan
Old 09-22-2003, 06:07 PM   #11
supermoose
Member#: 9093
swap starr
a pedal box includes the brake/clutch pedal and the gas pedal. u dont need the gas pedal, thers no differance. u dotn even need to remove the cable to install hte other 2.
u can get one at the dealer for a huge amount of money brand new or a J-yard like the one i listed above.
shoudl cost liek $100 or so.
what will work is listed above in the post too. u can read rite?
same with the line business.
if u get the USA GC8 2.5RS, u can use oem everything, pedalbox, clutch MC, hardline, bracket to firewall, soft line, etc.
no matter what, a turbo clutch needs a turbo slave cylinder, so it would be up to u to find a slave cylinder from a hydro clutch turbo car.
assuming the convertor is driving either
A: FWD with cable clutchimpreza, AWD impreza with cable clutch, or AWD impreza with hydro clutch and NA transmission
there are:
LHD/RHD cable clutch cars
LHD/RHD NA hydro clutch cars
LHD/RHD Turbo hydro clutch cars.
for a turbo trans:
***pedal box can use: ***
LHD hydro clutch cars
LHD hydro AND turbo clutch cars.
***clutch MC can use:***
LHD Hydro NA
LHD hydro turbo
RHD Hydro turbo - with modification to shaft
***clutch line use:***
LHD GC8 hardline/bracket/softline
LHD GDA hardline/bracket/softline --MAY NOT WORK forsure (however i think it can work - ill check it on my friends car)
RHD GC8 hardline (custom bend) LHD GC8 2.5rs bracket + soft line
OR the easiest solution. custom stainless steel line with adapter to bipass usage of hard line and 90 deg. bend at MC
***clutch slave cylinder use:***
LHD or RHD GDA WRX USDM /not USDM
LHD or RHD GC8 JDM EDM UK TDM ADM WRX (basically everywhere but USDM)
USDM Legacy turbo 91-94 EJ22
any other q's?
Old 09-22-2003, 08:47 PM   #12
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
Yes I have a question! Looks like it was raining good in your parts today. How did you like AWD with all your fancy LSDs??? Or did you not try with the wheel bearing issue?
Old 09-22-2003, 09:11 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I just wanted to tell anyone that finding a 5 speed turbo legacy transmission and parts is a dream. Few exist to begin with and any non running have been grabbed by another subaru enthusiast
Old 09-22-2003, 09:26 PM   #14
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
thanks supermoose that helped me out a lot
Old 09-22-2003, 10:35 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
Old 09-22-2003, 11:29 PM   #16
supermoose
Member#: 9093
swap starr
Default narg
wheel bearing- i took care of that yesterday, a million hits of PB blaster all day long and a mother of pipe wrench did the trick on my stock hub with WASTED WASTEED CV.
yeha. rain? LSD? what rain. i didnt even spin my tyres once today. man, i gota drift............
h
:P
Old 09-23-2003, 12:31 AM   #17
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
you mean the Legacy Turbo that was hear some odd years ago? my mom friend just gave hers to her God son.. I already asked if I could have it but it was too late.. Damn Subaru only must of built 10 of these Turbo Legacys..
SubaruImpreza_power is offline   Reply With Quote
Old 09-29-2003, 04:08 AM   #18
supermoose
Member#: 9093
swap starr
Default mm
oh yeah. i weighted my car the other day. with a FULL tank (13.9 gal tank) it was 2580 (w/o me in the car)
Old 10-20-2004, 04:53 AM   #19
supermoose
Member#: 9093
swap starr
bomp. was looking fo him, found him.
ROAR!
Old 10-20-2004, 10:15 PM   #20
linux>windows
Member#: 49517
good work man.. did you get Henry's car running yet?
linux>windows is offline   Reply With Quote
wtb: fwd impreza 5 speed trans socalximpreza Private 'Wanted' Classifieds 0 03-16-2010 06:04 PM
03 WRX trans swap to 91 Legacy SS Turbo (Keep LSD?) orpyak Subaru Conversions 6 05-28-2009 11:05 PM
FWD->AWD Which struts? calmnothing Subaru Conversions 2 02-17-2005 10:08 PM
sti turbo/trans swap on rs dr_keef Factory 2.5L Turbo Powertrain 2 10-22-2004 12:47 AM
FWD-->AWD swap info. switches supermoose Subaru Conversions 5 09-21-2003 03:41 PM
Message Board Statistics All times are GMT -4. The time now is 06:34 PM.
