Old 09-21-2003, 07:47 PM   #1
rickG888
Member#: 14820
2002 WRX wagon
Sedona Red
Default Swap underway-cooling system question
I am currently in the process of swapping a USDM EJ205 engine into my 1998 RS coupe and I have a few questions.
I have plans to upgrade to a modest 250-260whp,nothing too crazy but I want reliablity
Should I upgrade the radiator as it has alot of miles on it and was looking a little tired? What options do I have,would a stock WRX or RS rad do the job fine? Shoudl I upgrade and to what ?
What other mods can I do to make sure the engine stays extra cool under hard driving?
Thanks
rickG888 is offline   Reply With Quote
Old 09-22-2003, 01:51 AM   #2
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
oil cooler
scobaru is offline   Reply With Quote
Old 09-22-2003, 02:25 AM   #3
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
The stock rs radiator is not the best tool for the job. If you can swap in a wrx radiator that'd be better, i've heard maybe just the fans will work without modifying it, not sure. You could always get an aftermarket one. Good luck.
Soon2Bgreat is offline   Reply With Quote
Old 09-22-2003, 03:19 AM   #4
spiralsmurf
Member#: 16085
2005 STi
get an aftermarket gc8 radiator
spiralsmurf is offline   Reply With Quote
Old 09-22-2003, 05:13 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The EJ205 engine will sit closer to the radiator fans, but I think it will all fit. If you select an aftermarket GC/GM radiator then all you will have to deal with is the thicker core and the extra radiator cap. If you go for anything for the GD/GG then then the upper radiator mounts will be different and you will have to do some fab work.
The RS radiator core is 16mm thick, where the WRX core is 27mm thick. I personally have a 38mm WRX radiator sitting in my basement.
-Jon
Old 09-22-2003, 08:45 PM   #6
rickG888
Member#: 14820
2002 WRX wagon
Sedona Red
Thanks,
I will invest in an aftermarket rad unless I get a WRX rad cheap.
Any suggestions on make or supplier.
I live in Toronto,Canada so availablity may be an issue.
What do you suggest??
Old 09-22-2003, 09:16 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The only GC/GF radiator that is readily available is the C&R radiator from kastleskorner.com. Anything else like the MRT or Koyo will be special order and unavailable.
-Jon
Old 09-23-2003, 12:25 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Hi, I've completed my EJ205 swap and have been thinking about what to do for more cooling as well. Well here is my plan. I will run a FMIC and in place of the TMIC I will place an oil cooler, I also am looking to buy a performance GC radiator or even a GC WRX radiator.
Well that's my plan of action.
Take it easy, Micah
Old 09-23-2003, 01:38 AM   #9
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
homemade wrx you are doing what i've always wanted to do !! tell me how fittment is with the oil cooler I always though the piping for the front mount would get in the way.
Old 09-23-2003, 12:56 PM   #10
Homemade WRX
Member#: 33782
96 bastard child
I am at schoo now but at home I have a pic of a GC8 that actually did this.
Take it easy, Micah
My frined showed me the pic after telling him what I thought was my idea. Too late oh well.
cooling system questions dukeduster Built Motor Discussion 33 09-21-2008 03:03 PM
Cooling system question Alex_WRX Service & Maintenance 2 06-23-2006 12:56 PM
Heating/Cooling System Question WRXBlueBallz Off-Topic 8 03-08-2006 07:35 PM
cooling system questions??? donut Normally Aspirated Powertrain 24 10-09-2001 02:01 PM
Cooling System Question Spectre23 Normally Aspirated Powertrain 5 02-11-2001 09:55 PM
