Old 09-22-2003, 02:57 AM   #1
Se3n
Member#: 14268
2003 WRX
Midnight Black
Default can't find weight of OEM WRX wheels
I'm trying to decide between 17" and 18" P1's and I'm curious how the stock wheels compare in weight. Will I be losing much going to the 18" P1's performance-wise?
Se3n is offline   Reply With Quote
Old 09-22-2003, 03:02 AM   #2
Turbo X
Member#: 26249
02 Impreza WRX
16.5 pounds each just the wheel itself.
Turbo X is offline   Reply With Quote
Old 09-22-2003, 05:22 PM   #3
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
that's not bad. Going to tough to match that weight in 17" and really tough 18"
Jeff_DML is offline   Reply With Quote
Old 09-22-2003, 05:59 PM   #4
rexxer
Member#: 27624
2014 WRX
SCC uses 1lb or less/inch of diameter as the definition of a light weight wheel. What you also have to consider is that a lot more of the stock wheel's mass is nearer to the center vs. a lot of aftermarket wheels.
rexxer is offline   Reply With Quote
Old 09-22-2003, 06:09 PM   #5
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
sorry if this sounds dumb, which is better?
Old 09-22-2003, 06:11 PM   #6
Se3n
Member#: 14268
2003 WRX
Midnight Black
Well, I'm not comparing any wheels to the stock wheels because I won't have them on the car much longer regardless... I'm just trying to decide what wheels WILL be on the car.
Old 09-22-2003, 06:15 PM   #7
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
according to this
http://www.europeanspeed.com/wheelweights.htm
the P1 in 17" are 20.4 lbs so I assume the 18" are even heavier. Prodrive doesnt list the weights on their webpage, so can anybody confirm these numbers?
I like the P1 design in 17" but 20lbs is getting kind of heavy. I am shooting for 15-17lbs in a 17" rim,
Old 09-22-2003, 06:45 PM   #8
Ikonosin
Member#: 5914
2010 Legacy 3.6R
best site for most of the wheel weights = http://wheelweights.net/
Ikonosin is offline   Reply With Quote
Old 09-22-2003, 11:07 PM   #9
mch
Member#: 30039
2002 wrx wagon
dirt slvr
Keeping the weight closer to the center of rotation helps with inertia (easier to accelerate and brake the wheel).
mch is offline   Reply With Quote
Weight of 2006 WRX wheels? Heavy Fuji Tire & Wheel 13 08-17-2006 02:23 PM
Weight of OEM WRX wing? MF-DIF Interior & Exterior Modification 8 11-18-2004 11:04 AM
Whats the weight on OEM WRX wheel/tire set-up? MF-DIF Tire & Wheel 7 07-02-2004 01:15 AM
Weight of stock WRX wheels jetsiphon Tire & Wheel 6 05-01-2003 01:32 PM
Weight of stock WRX wheels, P7's, and how much difference does it make? WR-REX Brakes, Steering & Suspension 4 09-21-2001 12:05 PM
