Welcome to the North American Subaru Impreza Owners Club Wednesday April 16, 2014
Old 09-22-2003, 06:42 PM   #1
wrx2k3
Member#: 31114
2003 Subaru WRX
Default How to tell how much tread is left...
So.. as the subject states, is there an easy way to tell how much tread is left on any given tire?
Don't just say, "look at it"..
wrx2k3 is offline   Reply With Quote
Old 09-22-2003, 07:01 PM   #2
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
bigdweeb is offline   Reply With Quote
Old 09-23-2003, 09:48 AM   #3
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
U.S. coins can be substituted for a tire tread depth gauge as tires wear to the critical final few 32nds of an inch of their remaining tread depth.
Place a penny into several tread grooves across the tire. If part of Lincoln's head is always covered by the tread, you have more than 2/32" of tread depth remaining.
Place a quarter into several tread grooves across the tire. If part of Washington's head is always covered by the tread, you have more than 4/32" of tread depth remaining.
Place a penny into several tread grooves across the tire. If the top of the Lincoln Memorial is always covered by the tread, you have more than 6/32” of tread depth remaining.
The Law
According to most states’ laws, tires are legally worn out when they have worn down to 2/32" of remaining tread depth. To help warn drivers that their tires have reached that point, tires sold in North America are required to have indicators molded into their tread design called “wear bars” which run across their tread pattern from their outside shoulder to inside shoulder. Wear bars are designed to visually connect the elements of the tire’s tread pattern and warn drivers when their tires no longer meet minimum tread depth requirements.
Common Sense
However, as a tire wears it’s important to realize that the tire’s ability to perform in rain and snow will be reduced. With 2/32" of remaining tread depth, resistance to hydroplaning in the rain at highway speeds has been significantly reduced, and traction in snow has been virtually eliminated.
If rain and wet roads are a concern, you should consider replacing your tires when they reach approximately 4/32" of remaining tread depth. Since water can’t be compressed, you need enough tread depth to allow rain to escape through the tire’s grooves. If the water can’t escape fast enough, your vehicle’s tires will be forced to hydroplane (float) on top of the water, losing traction.
If snow covered roads are a concern, you should consider replacing your tires when they reach approximately 6/32" of remaining tread depth to maintain good mobility. You need more tread depth in snow because your tires need to compress the snow in their grooves and release it as the they roll. If there isn’t sufficient tread depth, the “bites” of snow your tires can take on each revolution will be reduced to “nibbles,” and your vehicle’s traction and mobility will be sacrificed. Because tread depth is such an important element for snow traction, winter tires usually start with noticeably deeper tread depths than typical All-Season or summer tires. Some winter tires even have a second series of “wear bars” molded in their tread pattern indicating approximately 6/32" remaining tread depth to warn you when your tires no longer meet the desired tread depth.
tire search page if you do indeed need new rubber
How to tell how much clutch "pad" is left? Ketchup Transmission (AT/MT) & Driveline 3 05-12-2007 01:21 AM
How to tell if your uppipe is leaking? 02wrx999 Factory 2.0L Turbo Powertrain 9 12-16-2002 08:34 AM
How to tell if O2 sensor is bad paulw Factory 2.0L Turbo Powertrain 4 11-03-2002 02:07 PM
How to tell if O2 sensor is corrupt? tmarcel Factory 2.0L Turbo Powertrain 1 03-20-2002 01:32 PM
How to tell how much brakes left? Penphoe Brakes, Steering & Suspension 3 06-19-2001 02:08 AM
