Old 09-23-2003, 08:55 PM   #1
devinm88
Member#: 40876
2001 Legacy GT Ltd
Black Granite Pearl
Default My Fog lights has over an inch of water in it; Help.
My drivers side fog light has over an inch of water in it. Is this an easy fix (bad seal) or does the entire unit need replacing? How to I access this? From the front, from underneath, from under the hood??? If I have to, I'll use epoxy, tape, anything... Thanks in advance for you help.
devinm88 is offline   Reply With Quote
Old 09-23-2003, 09:23 PM   #2
Bill Westhead
Member#: 1095
1998 BD Legacy GT
BGP
Quick, take the light off and drain it before anything rusts inside the reflector and bulb!
This happened to me and I procrastinated (the usual: busy at work, busy with family..etc) and eventually things started to corrode - now it's completely worthless and it's $200 Cdn (approx $140 US) to replace it.
Here's what happened to me: the fog light housing is entirely plastic and is secured by a steel bracket to the inner bumper area. This plastic housing is pretty fragile in my experience and is definitely prone to cracking. I believe a simple front end impact is enough to crack the housing, such as an overly aggressive parking n00b.
Anyways, a crack on the upper side of the housing will slowly admit water as the car is driven in the rain and/or from overspray during car wash activities.
I suggest you remove the light, drain it and drying it throroughly before sealing it up with silicone to prevent further leaks.
Good luck,
Bill
Bill Westhead is offline   Reply With Quote
Old 09-23-2003, 09:26 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If you dont mind keeping the car perfect you could drill a small hole in the lowest spot of the housing to let the water escape. The fog light heat would be enough to remove any remaining moisture.
Old 09-23-2003, 09:34 PM   #4
devinm88
Member#: 40876
2001 Legacy GT Ltd
Black Granite Pearl
Thank you Bill. I will take care of this immediatlely. However, how do I take the light off, how do i access this? From underneath, from under the hood, from the front...?
Old 09-23-2003, 10:03 PM   #5
aross
Member#: 831
11 Blurple WRX
03 BH MBP
I believe it is accessed from below, you have to remove part of the plastic fender protector.
See this link on Scoobymods..
It is for an ob- basically the same instructions though, just replace the big round fog with your rectangular ones.
scoobymods
aross is offline   Reply With Quote
Old 09-23-2003, 10:44 PM   #6
Schludwiller
Member#: 22066
1999 BD-GT 30Yr Std
I don't know if the bulbs are Halogen (not likely with their poor output), but I find cleaning them with rubbing alcohol gets the bulb nice and clean with no oil deposits which would cause them to burn out.
Schludwiller is offline   Reply With Quote
Fog light has water in it sykosoft Electrical & Lighting 1 04-19-2010 08:18 PM
My fog lights in my 04 keep blowing, please help Jay04WRX Electrical & Lighting 7 09-15-2009 11:01 AM
Switching to boxer briefs has created an aura of calm in my junkular region Fach Off-Topic 61 08-09-2005 05:03 PM
Small chunk of glass from inside my fog light foureyedlameo Interior & Exterior Modification 12 07-18-2005 01:25 PM
So I was washing my car and saw a hole in my fog light... cavymeister Mid Atlantic Impreza Club -- MAIC 4 06-16-2003 10:51 AM
