Old 09-24-2003, 05:22 AM   #1
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Default Oil Analysis: 7,247mi on Mobil1 5w30 (WRX)
Iron wear jumped up a bit over last time, but still pretty low. Oil appears to be holding up ok. Could probably extend oil drains further to 8-9000 miles without trouble, but will probably keep the changes between 7000-7500 miles for now.
The change at 11999 miles used a mix of Syntec, M1 and Castrol GTX, the change at 6,660 miles was using M1 0w30.
drees is offline   Reply With Quote
Old 09-24-2003, 11:20 AM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
what's your driving habit like during those 7200 miles?
the more i look at these oil analysis, the more i'm thinking my 5k mi change interval can be extended
i do do some spirited canyon run bout 2 times a month, then again, i do have an oil cooler........hmmmm
btw, i also have a wrx wagon, on mobil1, actually, all my fluids, except brake and clutch is mobil1 product
vile is offline   Reply With Quote
Old 09-24-2003, 12:50 PM   #3
drees
Member#: 25905
2003 Silver Wagon
The car is my daily driver, so I drive it a bit over 40 miles every day. Most of those miles are cruising on the freeway at 70-80 mph. I will typically do one full throttle run though most of 3rd gear getting on the freeway if traffic permits. I'm probably fairly easy on the oil.
It looks like the 5w30 Mobil1 will start degrading in performance soon, but I could probably get at least 8-10k miles out of it and still be OK.
From what I understand 10w30 should hold up better under longer drain intervals because it needs less viscosity improvers.
Safe to run 10w30 here in Socal, too.
Old 09-24-2003, 01:13 PM   #4
bluesubie
Member#: 767
04 FXT
Thumbs up
Great report!
-Dennis
Old 10-17-2003, 12:15 AM   #5
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
How much was the oil analysis if you don't mind me asking?
SupaSizeFries is offline   Reply With Quote
Old 10-17-2003, 02:20 AM   #6
Charlie
Member#: 23751
2003 Passat W8 Wagon
Reflex Silver
it runs ~ $20, and an extra $10 if you want the TBN calculated. TBN tells you how much active additive is left in the oil when you drained it. This is an indicator of whether you could've run the oil a bit longer.
Charlie
Charlie is offline   Reply With Quote
Old 10-17-2003, 03:02 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I just wish it were easier to change just the filter without so much oil loss/mess. I have been changing the filter every 4k miles and topping up the level to 8k and then doing a complete change. Changing syn oil every 3k is such a waste.
Old 10-17-2003, 05:12 AM   #8
drees
Member#: 25905
2003 Silver Wagon
That's one of the reasons I had oil analysis done. Now I know I can go at least 7k miles on M1 without worries with my driving habits.
Old 10-17-2003, 01:30 PM   #9
element533
Member#: 37575
2012 WRX Std 4D
How do you collect the oil to send it in for analysis? It seems like it would be really easy to get dirt in with the used oil and foul the analysis...? Whenever I drain my oil, it's a complete MESS: dirt, dust, cat hair, road scum and grease from my gloves/hands...
Not to mention that I don't have a clean oil tray.
element533 is offline   Reply With Quote
Old 10-17-2003, 02:28 PM   #10
drees
Member#: 25905
2003 Silver Wagon
I have a a Fumoto Valve to help with my oil drains, but the process is nearly the same with or without it.
1. Warm up engine
2. Take off drain plug or open valve, have your oil sample container ready.
3. While oil is coming out hold the container into the stream until almost full, then pull away. This won't take long, the sample is only a few ounces.
4. Let rest of oil drain out.
I've used this procedure on multiple cars and I've been able to get a sample without spilling a drop every time. The trick is to angle the sample container into the stream at about a 45 degree angle.
If I lay something down on the ground, I can change the oil with only getting a bit of oil on my hands when I change the filter. With some latex gloves on, I don't even have to wash up when I'm done!
Old 10-17-2003, 03:07 PM   #11
element533
Member#: 37575
2012 WRX Std 4D
That sounds easy... Do you just buy your sample containers at the store, or does the analysis company send them to you? I'm assuming you use a brand new one each time.
Old 10-17-2003, 03:28 PM   #12
drees
Member#: 25905
2003 Silver Wagon
Yep brand new sample container each time.
Blackstone Labs will send you 2 for free to get you started.
Old 10-19-2003, 02:34 PM   #13
VSG
Member#: 19435
do you use the OEM oil filter with your car?
VSG is offline   Reply With Quote
Old 10-19-2003, 03:10 PM   #14
drees
Member#: 25905
2003 Silver Wagon
I've been using the cheap Proline filter from PepBoys (same as the Purolator filter).
Old 10-21-2003, 07:36 PM   #15
Electronsmurf
Member#: 14523
Blue -239.9WHP 247.7WTQ-
how long is a filter good for? can it go 6000 miles?
Electronsmurf is offline   Reply With Quote
Old 10-21-2003, 07:42 PM   #16
drees
Member#: 25905
2003 Silver Wagon
How long a filter or oil can go can greatly vary depending on the oil you're using and the quality of the filter and the type of driving you do.
In my case, it seems that even cheap filters can go at least 7247 miles.
Old 10-22-2003, 12:16 AM   #17
esteve
Member#: 28716
2006 STI
What does the "TBN=5.1" tell you? Someone mentioned it has to do with how many active additives are left, but the report doesn't give any comparison numbers.
Thanks for the helpful report, I was thinking of going 5K mile intervals but I'll probably extend it to 7.5K now with absolutely no guilt or worry!
esteve is offline   Reply With Quote
Old 10-22-2003, 03:26 PM   #18
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 10-23-2003, 02:12 AM   #19
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Thanks for the link, I will be testing my oil which has been in for 13,000 miles.
Tim Sanderson is offline   Reply With Quote
Oil Analysis: 8400mi on M1 5w30 - 03 WRX drees Service & Maintenance 51 12-19-2007 06:31 PM
Oil Analysis: 8400mi on M1 5w30 - WRX drees Service & Maintenance 8 12-22-2006 03:48 AM
Oil Analysis: 7500mi on M1 10w30 - WRX drees Service & Maintenance 14 06-22-2006 12:30 AM
Oil Analysis: Amsoil ASL 5w30, 2003 Subaru WRX 2.0T, 7,382 mi, 34,294 mi total drees Service & Maintenance 13 08-11-2004 12:32 AM
Oil Analysis: 7600mi on M1 5w30 - WRX drees Service & Maintenance 3 03-02-2004 01:39 AM
