Welcome to the North American Subaru Impreza Owners Club Thursday September 18, 2014
Old 09-24-2003, 06:49 PM   #1
underground-mpyre
Member#: 30351
1999 GC8 STI V7 6spd
Silver Coupe
Default EJ20 X-member, do I need to go with WRX control arms on my GC8.
I am finally getting my swap together, M+T are in. But the GC8 control arms are shorter than they need to be. I have positive camber by using my turbo X-member from a GDB sti. So what I need to know is, do I need to go with a WRX control arms to get the camber out? Help.
underground-mpyre is offline   Reply With Quote
Old 09-25-2003, 02:40 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
just use washers to space out the control arms, you will prolly need the WRX mounting bolts though.
Jeremy
Old 09-25-2003, 10:51 AM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
That goes against everything I have heard. If you use a GD/GG crossmember on a GC/GF/GM chassis, then you will need to use the GC/GF/GM front control arms since the attachment point is the same distance from the center of the car for both chassis orientations. Washers are used because the GD/GG chassis has a wider front control arm front bushing. Sedan control arms will be wider and give you more negative camber, but they shouldn't be used on a GC/GF/GM chassis.
-Jon
Old 09-25-2003, 11:44 AM   #4
underground-mpyre
Member#: 30351
Silver Coupe
Hell I can't even drive my car if i wanted to, because slight toe in, and too much positive camber.
Old 09-25-2003, 11:57 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
are you sur eyou don't have lots of positive on one wheel and lots of negative on the other??
jeremy
Old 09-25-2003, 11:59 AM   #6
underground-mpyre
Member#: 30351
Silver Coupe
Yep, I have only positive camber.
Old 09-25-2003, 12:02 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I used the GD WRX crossmember with my GC8 control arms!!
Homemade WRX is online now   Reply With Quote
Old 09-25-2003, 12:20 PM   #8
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
i just hacked the whole idea of using a GD member and went with a Turbo Legacy crossmember for the car.
It works great and looks like it may actualy be the same part that was used on the GC STi's.
I have had no problem with it at all using the stock A-arms and the aluminum ones.
Billyqua
rally driven.................
RS22b is offline   Reply With Quote
Old 09-25-2003, 12:39 PM   #9
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
Default what struts?
from what i understand, the differences between sedan & wagon/or gc is
1)the control arm track length,
2)width of control arm front bushing,
3)and strut body camber bolt arrangement. attatchment tabs are different on gd sedans.
others who've used the gc arms on gd x-member w/ gc suspension seem to come out okay.
when they say space out the arms, the reference is to the front bushing. spacer washers or a bushing replacemnt (like from gd poly kits energy or grp N) should do it.
your alignment prob does'nt sound like it should be coming from the control arm length though if your x-member is the same dimensions as wrx ones.
tbd is offline   Reply With Quote
help me, i need to buy a lower control arm R side for 04 wrx. pengmao MWSOC Private Classifieds 2 02-27-2008 04:23 PM
Labor hours to replace front WRX control arms with STi aluminum? superg Brakes, Steering & Suspension 17 12-04-2007 03:45 AM
99RS which swaybar do i need w/swap and alumn control arms? 992.5RS Subaru Conversions 3 05-29-2005 12:08 PM
So I bent my control arm on my '02 wagon kenny08 Brakes, Steering & Suspension 12 03-17-2005 12:14 PM
How many of you with aluminum control arms on your WRX modvp Brakes, Steering & Suspension 12 01-02-2004 01:37 PM
