Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Closed Thread
Old 09-25-2003, 10:22 AM   #1
AutoSpeedWRX
Member#: 15334
2002 Wrx Sedan
11.????
Default Loud whistling noise after downpipe install....leak?
I installed a new downpipe and now i can hear a reall loud whistling noise coming from around the turbo. When i get on the gas it kinda sounds like "a spooling turbo". Do i have a leak, should i buy all new gaskets and do all the work over again. Help im scared.
frank
AutoSpeedWRX is offline
Old 09-25-2003, 10:33 AM   #2
postban
Member#: 37871
2002 WRX Wagon
03 COBRA uber:modded
You will definetly be hearing LOTS more turbo now. Probably what it is.
Are you catless?
Much more "whistle" or spool sound if that is the case.
Mine is the same way
______________________________
Current mods: UP/TBE/UTEC/IC Hoses
02 WRX Wagon Silver 214WHP~220WTQ Stage 2+ WRX PICS/ WRX VIDEOS
03 Cobra Convertible Sonic Blue 417RWHP COBRA PICS/VIDEOS
postban is offline
Old 09-25-2003, 12:50 PM   #3
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
Mine did the same thing after I installed my downpipe. It's sounds great. Chances are, that's what it is. You could try putting your hand around the seal between the dp and the turbo and feel for any air.
02R6 is offline
Old 09-25-2003, 01:55 PM   #4
AutoSpeedWRX
Member#: 15334
2002 Wrx Sedan
11.????
Old 09-25-2003, 02:30 PM   #5
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Default Re: Loud whistling noise after downpipe install....leak?
Does it sound like "WOO-WOOO!"?
djerickd is offline
Old 09-25-2003, 04:44 PM   #6
T-WREXX
Member#: 40835
2002 Impreza WRX
For Sale Silver
a good way to test for an exhaust leak is to let the car idle and walk around the car and listen from different angles. if you still hear that sound at idle you may have an exhaust leak, otherwise it is just your turbo spooling that you hear.
T-WREXX is offline
Old 09-25-2003, 06:31 PM   #7
TexRex2002
Member#: 36303
06 Evo IX
An exhaust leak on the downpipe often sounds like a hissing, even at idle. An up-pipe leak whistles (screams) like crazy, especially under load, as the pressure gets pretty high in there. Since you hopefully didn't unbolt the turbo, it's unlikely that it is an up-pipe leak. You didn't accidentally loosen the turbo and then torque it back down, did you?
The turbo spooling whistle in my experience is made louder by intake modifications, and is most heard in like a parking garage with the windows down when the car is kind of cold. It sounds a little bit like an 18 wheeler taking off from a stoplight: a real high pitched whistle that follows the load closely, definitely a whistle that a 100,000+ rpm turbine might make. If it sounds like you or me whistling "Dixie" or something (badly), you probably have an odd downpipe exhaust leak.
When I really get on the gas the turbine whistle is usually drowned out by the air intake "whoosh," and the exhaust note, but that's just my car...
Hope this helps a little.
TexRex2002 is offline
Old 10-16-2003, 12:59 AM   #8
2002WRX_5speed
Member#: 6895
2002 02 Impreza WRX
I am not sure if it is a leak or not but I hear a whistle around 2000 RPM. When I let go of the gas pedal, it goes away and of course when I step on the gas pedal, I hear the whistle again.
Is it the turbine spinning? or leak in the uppipe? I have not checked the uppipe yet for a leak. Oh, when WOT, it sounds like I have a leak but I am not sure if it really is or just a sound of more air flowing to the pipe. I hear a surge of air--sounds heavy. Can someone diagnose this problem.
Here is my setup:
ScoobySport DP
Stock Uppipe
ScoobySport Midpipe
Scorpion Exhaust
2002WRX_5speed is offline
Old 10-16-2003, 01:29 AM   #9
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
The whistle is your turbo and is normal after doing a downpipe. You just removed a ton of "insulation" (heatshields) from the factory setup, and at least 1 cat. The noise is now amplified and unimpeded. The "leak" you think you are hearing at WOT is most likely just the wastegate flapping.
Wade-O is offline
Old 10-16-2003, 01:31 AM   #10
2002WRX_5speed
Member#: 6895
2002 02 Impreza WRX
Talking
thanks.....makes sense. Maybe a Cobb Stage 2 will fix the problem
Old 10-16-2003, 01:32 AM   #11
Mr. Fancypants
Member#: 17626
2005 STI
Sounds normal. Like someone said above, when you start it up one morning, just feel around the area downpipe --> turbo and see if you can feel air leaking out. But what you describe really sounds normal with a new DP.
EDIT: well my response is a little late
Mr. Fancypants is offline
Old 10-16-2003, 05:55 AM   #12
DemiGod
Member#: 44323
Default Re: Re: Loud whistling noise after downpipe install....leak?
DemiGod is offline
Old 10-16-2003, 10:07 AM   #13
AutoSpeedWRX
Member#: 15334
2002 Wrx Sedan
11.????
KInda Funny this post lasted so long. I wasnt serious, i was making fun of the fact that there is a new post like this twice a day.
Old 10-16-2003, 10:27 AM   #14
TopKatz
Member#: 36793
04 WRX
It sort of sounded that way...
maybe based on the fact that you got a bunch of people to respond honestly to this post you should refrain from trying to make a point in such a subtle way?
How about instead of adding to the problem of duplicate posts, you post on a thread you know that there are ansers to, and explain to the newbie how to find them?
just a thought......
TopKatz is offline
Old 10-16-2003, 01:01 PM   #15
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
Some of us don't spend a lot of time here, because of all the smartass elitists on this board. Boy, you really taught me a lesson
Wade-O is offline
Old 10-21-2003, 01:15 AM   #16
OvRclockR
Member#: 20671
2002 Wrx sedan
I installed a bosal downpipe and vishnu uppipe last weekend. I dont knoow how to find an exhaust leak. It sounds fine to me but I would like an expert to confirm. I'm gonna go to a subaru meet soon and ask fellow suby owners around and see what they think.
OvRclockR is offline
Old 10-21-2003, 02:38 AM   #17
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Remember...one smartass elitist, but 10 people genuinely trying to help! Don't go...STAY!!! WE LOVE YOU!
mexicanpizza is offline
Old 10-21-2003, 08:13 AM   #18
BlackEye
Member#: 36203
2003 WRX
Platinum Silver Met.
Default Oh...
"I am afraid that the deflector shield will be quite operational!"
No, speaking from experience the COBB stage 2 cannot make mechanical noise dissapate.
The whine from the turbo will still be there, and some wastegate flutter depending on the downpipe.
Sorry
Russ
BlackEye is offline
Old 10-21-2003, 11:29 AM   #19
Rickyh
Member#: 40453
I did a catless downpipe a few days ago. I had an exhaust leak from the dp/turbo flange. It could be heard at idle and you could feel it when you put your hand near the turbo. I just removed and reinstalled the dp this am and it is gone. There is still a whine/whistle when at boost, but nothing at idle and no air leaking. And yes it seems like a lot of people who have been here a while are quick to call people such as myself noobs. I say screw em
Rickyh is offline
Old 10-21-2003, 11:43 AM   #20
BYE V8
Member#: 40924
'02 WRX Black Pearl
Project: BYE V8
nah man!! "dats only in da mornin..people should be up cookin breakfast or something by then..."
Sorry I couldn't resist
BYE V8 is offline
Old 10-21-2003, 03:55 PM   #21
Maicca
Member#: 29143
2000 IMPreza
Camo
"..but Bub Rubb and Lil Sis say it's all for show........"
Maicca is offline
Old 10-22-2003, 09:36 AM   #22
KanosWRX
Member#: 17904
010 STI
I have a scooby sport DP as well, hooked up to a Prodrive Midpipe. I know for certain I have a leak at the DP/Midpipe Flanges because I took out the gasket to replace it and I could see where the gasses were escaping because of the soot. I really have no clue on how to solve this, I even tried gasket sealant, which worked for about 30 min, then the leak came back. Mine sounded more like a fluttering noise once I got past 00 mpa and started building boost.
KanosWRX is offline
Old 10-23-2003, 03:04 PM   #23
tubbytreat
Member#: 37092
2002 WRX Sedan
Midnight Black Pearl
I have a ScoobySport uppipe and am having the leak there between my exhaust manifold and my header or between my exhaust manifold and uppipe. I took it to my local Subie dealer today to have someone look at it and he suggested I crank down on all my gaskets to ensure a nice tight seal.
I am wondering if my SubyDude gaskets will be ruined and need replacement now. Any ideas on how to determine if I need new gaskets?
tubbytreat is offline
Old 11-01-2008, 09:20 PM   #24
wrx1321
Member#: 193146
07 wrx
wrb
Smile
hi sir im new to this site i was reading tjis and i had a hks downpipe installed a few days ago and i hear same sound like a whistle ir flutter wen im on 2000 rpm is this really normal im just curios but on idle i dont hear that sound thanks for d good advices
wrx1321 is offline
Old 11-01-2008, 09:22 PM   #25
wrx1321
Member#: 193146
07 wrx
wrb
a flutter sound during 2000 rpm n coming from my turbo how do i know if i have turbo to downpipe leaks
wrx1321 is offline
Closed Thread
install complete-loud whistling noise nation1979 Newbies & FAQs 12 08-30-2009 12:17 AM
Loud Clunking noise after Coilover install SPOOLME Brakes, Steering & Suspension 4 12-18-2008 12:33 PM
Whistle sound after downpipe install? JKrieger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 09-21-2008 11:52 AM
new noise after downpipe installation zer0_thirteen Newbies & FAQs 5 07-30-2006 09:52 AM
loud ticking noise after turbo installed? RS2000 Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-09-2002 08:51 PM
