Old 09-25-2003, 05:21 PM   #1
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Unhappy time to replace CV joint and Cv boots..
On my 95 Impreza L.. I found out where the clicking is coming from and thats the Right front wheel. their is a fairly large hole. Does anyone know what the price is to replace it and to put new boots on?
SubaruImpreza_power is offline   Reply With Quote
Old 09-25-2003, 07:02 PM   #2
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Here is the pic to go with it..
Old 09-25-2003, 08:58 PM   #3
avk
Member#: 17252
'06 WX8
59E
This looks like an inboard joint. I replaced the same right-side boot last weekend. That boot seems the first to fail because it's right above the catalytic converter. Are you sure the clicking sound comes from the joint? There 's still some grease left as far as I can tell. Any idea how long the boot has been torn?
avk is offline   Reply With Quote
Old 09-25-2003, 10:05 PM   #4
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Not the inboard... The one hooked to the wheel.. The inboard one is fine and so is the Left side boot closest to the wheel.
I dunno how long the boot as been torn but I can say I had the car about 2 months now...
Old 09-25-2003, 11:05 PM   #5
avk
Member#: 17252
'06 WX8
59E
Was hard to make from the photo which one it was, but I thought it was the inboard because an outboard OE boot should have rubber rings in two larger "valleys". Anyhow, a reman. axle from Subaruparts is $106 with a $60 core charge. I had one on order but cancelled and bought a boot instead.
Old 09-25-2003, 11:26 PM   #6
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
How about from the dealer?
I don't know how you remove the Axel off the car Besides I still don't have a floor jack ot jack stands.
Old 09-26-2003, 12:40 AM   #7
avk
Member#: 17252
'06 WX8
59E
My estimate for having an axle replaced by the dealer would be around $200, using the list price for a Subaru reman. axle and adding labor which shouldn't be more than 30 min. But somehow this figure seems optimistic. Anyone had it done?
Old 09-26-2003, 01:50 PM   #8
Dealer Xing
Member#: 4673
forget about the dealer, go to Autozone get a re-man axle for $60 w/ lifetime warranty, pay another $50 to a street mechanic to change it.
Dealer Xing is offline   Reply With Quote
Old 09-27-2003, 10:26 AM   #9
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
This core charge is only for orders over the internet I take it?
Old 09-27-2003, 11:41 AM   #10
avk
Member#: 17252
'06 WX8
59E
Likely. Those known to have the charge are Subaruparts and some direct-sell rebuilders recommended here in the past.
Old 09-27-2003, 11:44 AM   #11
Hawk296
Member#: 14555
1995 Impreza L
Baja
I had my outer front boots fail within a week of each other. But i caught them lterally a few minutes after it happened (easy to see the grease all over my P7s) and didnt drive it till i could get it to the dealer (was at school and had no place or tools to do it myself ). To remove the axle, remove the old boot, rebuilt/inspect the CV joint, repack itwith grease and add a new boot It was $140.
A week later the 2nd one went and It was the same price.
Add the price of a halfshaft into that. Ide get the whole halfshaf replaced if youve been driving like that. YOuve most likely contaminated it already.
Hawk296 is offline   Reply With Quote
Old 09-27-2003, 05:10 PM   #12
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
thats what I was going to do.. It's like $76 at Advance Auto.. I would order from the internet but $76 + $56 core charge.. Forgive me but thats stupid.. For every part I buy I gotta send the old one back to get the core charge money back? Damn I just wanted the part..
Old 09-28-2003, 04:47 PM   #13
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
my right rear cv boot has the big tear and grease all over....most of the things im reading here are for removal of the front axel with the cv boot..anyone tackled the rear one themselfs...please help....i have ordered the reman one from subaru...230$!!! canadian....plus 100cnd core charge.....i just need to to what steps are involved for replacment of it....any help thanks
saar is offline   Reply With Quote
Old 09-30-2003, 03:37 PM   #14
ImpSP
Member#: 29223
97 Impreza
white
I recieved a spare cv boot from a subaru dealer to replace my torn right front. I was able to take the axel out and replace it the same day using a Chiltons Subaru book. It was a great learning expeirence and best of all I spent $0.
ImpSP is offline   Reply With Quote
Old 10-02-2003, 10:13 AM   #15
LarryNH914
Member#: 44223
Default Spacial tools to remove and replace axle?
Hi, I have a bad boot, and at $60 for a reman axle, I would rather replace the shaft than get a split boot kit (which I never seem to get 100% right anyhow...).
I have been looking at the shop manual, and they show two "special tools", one to press out the axle from the wheel housing (they say use "if necessary", that means it is not alway's necessary??????) and one to pull the new axle into the wheel.
Did you get these tools, or is there another way, or similar tools to use? I will have to ask at the parts store, where they will loan proper tools, but I am not sure if they would have this one...
What does the tool to pull in the new axle do? Is it to prevent stress on the bearing when inserting? Can the same thing be done with washers that do not go past the inner part of the bearing housing and tightening the bolt (and removing these when the axle is in place)?
Thanks,
Larry
LarryNH914 is offline   Reply With Quote
CV Joints and Boots Mr. Adovnik 'Old School' Subaru Forum 3 01-08-2008 12:46 AM
Time to replace or upgrade pads and rotors? Dub02 Brakes, Steering & Suspension 5 05-05-2007 12:23 PM
Clutch is going in 4th and 5th, time to replace Chewy-WRX Transmission (AT/MT) & Driveline 2 07-11-2003 12:33 PM
Shaking and vibration at speed; time to replace my front rotors? Kaiser Brakes, Steering & Suspension 13 07-15-2002 04:20 PM
How to desttroy CV joint and how much is a new one? garface Brakes, Steering & Suspension 4 10-01-2001 10:33 PM
