Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 09-25-2003, 08:29 PM   #1
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Default new sti injectors?
will the new sti injectors work in our cars? because the are side feed as well.
if not, how hard would it be to rig up another set of injectors so that i have 2 per cyl. and then with a % of throttle the others kick in?
i will be running a tec 3 so they can controll the extra injectors, but i was wondering about the physical part of it.
subiekid is offline   Reply With Quote
Old 09-28-2003, 03:03 PM   #2
-k-
Member#: 43881
01 25RS
What engine are you running? You can get 440cc side feed off a 90 something WRX (not in the US) I think Z1 said they could get them. There might be aftermarket higher flow as well, I'd ask MRT www.mrtrally.com.au. Or I'd guess that it wouldn't be that hard to get a US WRX intake manifold to fit on your engine. Nate at www.ss-ms.com was talking about doing that, give him try.
-k- is offline   Reply With Quote
Old 09-29-2003, 01:20 AM   #3
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
I believe he is running an EJ22T.
Subiekid - how much did you pay for the TEC3?
BAC5.2 is offline   Reply With Quote
Old 09-29-2003, 01:38 AM   #4
subiekid
Member#: 25516
tec 3 was 2 grand from austin. they pop up every once in a while for about that much.
you can also get a link plus and road tune it. but they dont pop up very offten. but dont get a link you cant road tune them worth a biach.
special K, yea i know about the 480 yellow injectors, but thought the new sti ones would be better and cheaper. but i was told they are actually bottom feed, but the source will not expand on that idea. so they are some what different
and i am running an ej22t with a 95 ej22 manifold, custom intake....
you can get the wrx intake manifold to work with the ej22T so i might do that and just get an older pair of 550 sti injectors.
http://forums.nasioc.com/forums/show...hreadid=426987
look at this guys set up. he is running an ej22T block and wrx inatke manifold ( dont pay attention to the giant water/air ic)
if i do that then wrx injectors would be used because they are so much easier to get. when i asked the 480 injectors were as much as the 550 sti and that is for used.(cant get new)
Old 10-10-2003, 02:02 PM   #5
imposter
Member#: 10642
95 Impreza EJ22T
What about nissan injectors? I've heard that some will drop right in, and I know nissan and subaru share some other parts as well. Does anybody know which ones will work?
Jim
imposter is offline   Reply With Quote
Old 10-12-2003, 12:05 AM   #6
subiekid
Member#: 25516
yes, there are some like 480 injectors from nissan that work. i cant remember what they are out of. i willl ask another member who knows for sure.
Old 10-12-2003, 08:03 PM   #7
subiekid
Member#: 25516
nismo 555 injectors for the tt 350z should be the ones that work. they are for the older like 90 to 96 (not sure on last year?) i will find some and get back to you on if they fit.
Old 10-12-2003, 08:22 PM   #8
subiekid
Member#: 25516
http://www.courtesyparts.com/Merchan...de=16600-RR701
they look a bit different. but not a bad price.
Old 05-03-2005, 01:59 PM   #9
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
if the side-feeds will work then we could also use something like Perrin's fail rail for the STi.
HeMan1320 is offline   Reply With Quote
Old 05-04-2005, 12:42 AM   #10
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I believe one of the legacycentral guys found that the new STi injectors will fit in a '92-'94 N/A fuel rail, but NOT the turbo rail.
IronMonkeyL255 is offline   Reply With Quote
Old 05-04-2005, 03:01 AM   #11
subiekid
Member#: 25516
Wow, this is an old thread.
I doubt it, the new STI injectors are really funky. It is easier to just get some nismo 555 injectors and put them into the n/a fuel rail.
Old 05-04-2005, 01:24 PM   #12
s13rb25det
Member#: 76419
2012 Impreza WRX Sti
satin white pearl
ditto a friend of mine had big problems trying to get his sti injectors to work
s13rb25det is offline   Reply With Quote
Old 05-04-2005, 05:14 PM   #13
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
We did have a guy over on LC that said the new STI injectors dropped right into the '92-'94 N/A rails. The Nismo injectors should drop into the '92-'94 rails too. The old 440cc yellowtops are supposed to drop right into the above mentioned rails also.
legacy92ej22t is offline   Reply With Quote
Old 10-22-2008, 11:40 AM   #14
dvsone775
Member#: 192309
2004 WRX
Default New STi Injectors
Are there any suggestions or tips when installing new injectors into an 04' WRX with a Perrin Fuel Rail?
dvsone775 is offline   Reply With Quote
FS: NEW sti injectors "pinks" NEW!!!! hodgeswrxshop Private 'For Sale' Classifieds 10 02-28-2006 07:38 PM
new sti injectors side feed? subiekid Subaru Conversions 5 09-27-2003 01:22 AM
FS: Brand new STI Injectors still in box View Askew Bay Area Impreza Club Forum -- BAIC 10 03-31-2003 02:07 PM
FS: new sti injectors and vishnu unichip! GDA Bay Area Impreza Club Forum -- BAIC 0 11-21-2002 01:10 PM
New STI injectors smell like gas BYBYV8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-09-2002 02:38 PM
