Old 09-25-2003, 09:39 PM   #1
jetsiphon
Member#: 31070
2002 WRX Sedan
W.R. Blue
Question Knock with cold start
I have a knock that starts with a cold start and fades usually after the car warms up. However, the knock continued today well after the car warmed up. Then, poof it was gone. Any ideas??
jetsiphon is offline   Reply With Quote
Old 09-25-2003, 11:33 PM   #2
carpetsloth
Member#: 17863
2002 Impreza WRX
If it sounds like a dull knock it's most likely piston slap. Pretty common on subarus. The turbo EJ20 has pretty short piston skirts and the pistons sit on their sides so they are more succeptable to 'slap'. If it goes away when it's warm it's not too serious. If you make a point of complaining to your dealer or subaru rep they may give you a new short block if your car's under warranty. I've been told that it's harmless but I personally think any mechanical knock sound is not good.
carpetsloth is offline   Reply With Quote
Old 09-26-2003, 01:09 AM   #3
sevenhead
Member#: 15073
2002 WRX Sedan
Lotus Seven, A-H 3000
try a search "cam belt tensioner". quite a few cars have had defective ones and been replaced under warranty.
sevenhead is offline   Reply With Quote
Old 09-26-2003, 01:53 AM   #4
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
most likely the sound of solid valve lifters when they are cold.
Samirr76 is offline   Reply With Quote
possible piston slap or knock at cold start?? Flyin_Hayn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-31-2009 05:57 PM
Rod knock on cold start blitzmr2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 06-19-2008 11:38 AM
Knock at cold start shm777 Normally Aspirated Powertrain 13 03-19-2005 07:41 PM
Knocking on cold start-up Dm0n3y002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 01-20-2005 11:56 AM
Autronic users: Need help with cold start my02wrx Engine Management & Tuning 3 04-16-2004 02:41 AM
