09-25-2003, 08:57 PM | #1 |
Member#: 33249
South East
Vehicle:2003 WRX white |
MY cables wont reach?
Put an Optima yellow top in but my cables were too short. What can I do?
09-25-2003, 09:14 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Not sure about the terminal position with the Yellow Top but when I installed my Red Top the ground wire reached just fine and so did the positive wire to the fuse box, but the wire to the starter was too short and I had to replace it.
Search for threads on "Optima" with my user name, there are several that discuss this. |
09-25-2003, 09:25 PM | #3 |
Member#: 33249
South East
yeah i looked at the red top and it seems the terminals are in the same place
09-26-2003, 11:01 AM | #4 |
Member#: 34054
Oh yeah been there, done that. You need to go to an auto store and get the materials to make a new line from the posi side to the starter...it is cake...if you don't feel like going undermneath the car, removing the TMIC leaves you with lots of work room.
09-27-2003, 03:36 PM | #5 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
Another possibility, which I just did with my Exide Orbital install, is to get one of those "green knob" battery cutoff switches, bolt the OEM positive *ring terminal* ends to one end of it and hook the other end over the battery terminal. This gives you an extra 1.5 to 2 inches of length. (just remove the OEM ring terminal ends from the OEM cylindrical battery connector first)
Lotus Evora won't reach U.S. roads until 2010 | AVANTI R5 | Non-Subaru News & Rumors | 9 | 03-02-2010 07:58 AM |
So I was minding my own business, reaching into my mailbox to get my mail... | 24 | Off-Topic | 89 | 08-21-2009 10:34 PM |
E-Brake cables don't reach!!! Help | Rallly2000 | Brakes, Steering & Suspension | 13 | 06-05-2008 01:21 AM |
Help me make my Turbo Forester reach 13's | agent007kimball | Normally Aspirated with bolt-on Forced Induction Powertrain | 16 | 07-31-2002 09:05 PM |
i need 4wd impreza with disc brake E-brake Cables. can i modify my cable? | supermoose | Brakes, Steering & Suspension | 0 | 09-30-2001 09:43 PM |
